Titel angepasst.
[KERNEL][LP] hells-Core b68 Stable [30.12.14] - b69t3 Test
hells-Core-b31:
-Makefile: Compile Optimization Part 2
-Use pgprot_writecombine in ion_system_heap_map_kernel for optimization (IntersectRaven) -
Titel Aktuell.
JWR66V war stock und nicht aosp, oder?
Jup, genau
hells -
hells-Core-b32
Im Zeichen der Performance...!-Async I/O latency to a ssd greatly increased, 34% gain (Creds: kleikamp)
-mm: writeback: every 500ms the writeback daemon kicks in and flushes -the dirty pages into disk (franco)
-Revert "block: row: fix one of the magic values.
-Revert "block: row: hardcode magic values
-block: row-iosched idling triggered by readahead pages (Lee Susman)
-mm: change initial readahead window size calculation (Lee Susman)
-mm: pass readahead info down to the i/o scheduler (Lee Susman)
-thermal: tsens8960: Increase the polling rate (Siddartha Mohanadoss)
-cgroups: timer_slack: forward port timer_slack to 3.4 (franco)
-msm_fb: Set RR sched policy for Glupdator thread (Kalyan Thota)
-msm: don't compile MSM_RUN_QUEUE_STATS (franco)
-ARM: 7493/1: use generic unaligned.h (faux123)
-lib: Sparc's strncpy_from_user is generic enough, move under lib/ (faux123)
-lib: add generic strnlen_user() function (torvalds)
-lib: Fix generic strnlen_user for 32-bit big-endian machines (paulusmack)
-ARM: use generic strnlen_user and strncpy_from_user functions (faux123)
-kernel: Move REPEAT_BYTE definition into linux/kernel.h (faux123)
-word-at-a-time: make the interfaces truly generic (torvalds)
-arch/arm/Kconfig: enable unaligned capability for ARM (faux123)
-ARM: dcache: select DCACHE_WORD_ACCESS for little-endian ARMv6+ CPUs (Will Deacon)
-ARM: 7492/1: add strstr declaration for decompressors (Rob Herring)
-ARM: 7592/1: nommu: prevent generation of kernel unaligned memory accses (Will Deacon)
-ARM: 7593/1: nommu: do not enable DCACHE_WORD_ACCESS when !CONFIG_MMU (faux123)Viel Spass (=
hell
welchen kann ich denn noch für ne 4.2.2 rom benutzen?
b1-b29
Danke
Gesendet von meinem Nexus 4 mit Tapatalk 4 Beta
Bin jetzt ein wenig verwirrt. Also der nicht aosp funktioniert mit dem aktuellen misch masch von pa, oder?
Jwr Version wird benötigt
Gesendet von meinem cm_tenderloin mit Tapatalk 4
Und das heißt?
Welche von hells muss ich nehmen?Gesendet von meinem Nexus 4 mit Tapatalk 4 Beta
Die Stock
Dankoooo
[COLOR=#000000][FONT=Arial]hells-Core-b33-m ([/FONT][/COLOR][COLOR=#000000][FONT=Arial]m[/FONT][/COLOR][COLOR=#000000][FONT=Arial]odule Support)[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]Changelog:[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table()[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]switch the protection of percpu_counter list to spinlock[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib/vsprintf.c: "%#o",0 becomes '0' instead of '00'[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]vsprintf: correctly handle width when '#' flag used in %#p format[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]vsprintf: further optimize decimal conversion[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]vsprintf: add %pMR for Bluetooth MAC address[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib/vsprintf.c: remind people to update Documentation/printk-formats[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib/vsprintf.c: kptr_restrict: fix pK-error in SysRq show-all-timers(Q)[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]vsprintf: add support of '%*ph[CDN]'[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib: vsprintf: optimize division by 10 for small integers[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib: vsprintf: optimize division by 10000[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib: vsprintf: optimize put_dec_trunc8()[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib: vsprintf: fix broken comments[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib/vsprintf: update documentation to cover all of %p[Mm][FR][/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lib/vsprintf.c: improve standard conformance of sscanf()[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]scatterlist: add sg_alloc_table_from_pages function[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]scatterlist: atomic sg_mapping_iter() no longer needs disabled IRQs[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]tmpfs: fix mempolicy object leaks[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]Make sure PWMs are running in sync[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]lm3530: Add a toggle for the CABC PWM[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: pm-8x60: Setup memory for save/restore cpu registers early[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: hotplug: wait for hotplug completion event from secondary core[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: pm-8x60: Use relative time for events[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: pm: send notification only for SPC and PC[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm_fb: display: fix iommu page fault when iommu buffer freed[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: avs: Restore core voltage when disabling AVS[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: spm: set vdd directly for current cpu[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: pm: Add support for retention on each core[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: pm: add failed stats[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: rpm: add debug msg for rpm outstanding req[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]Staging: android: binder: Fix memory leak on thread/process exit[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: display: Add DSI clock control for MDP GDHS power collapse[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mako: Add DSI clock control for MDP GDHS power collapse[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: Fix race condition in domain lookup[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: Allow changing bus frequency for SD/eMMC cards in runtime[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: Fix some driver hangs when dealing with broken devices[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: Add load bas[/FONT][/COLOR][COLOR=#1155cc][FONT=Arial]ed clock scaling support[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: Add sysfs entries for dynamic control of clock scaling[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: claim mmc host while enabling clock scaling from userspace[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: run clock scaling only in valid card state[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: Log MMC clock frequency transitions[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: Add support for notifying host driver while scaling clocks[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: msm_sdcc: Add support for dynamic bus clock vote[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: msm_sdcc: fix a type mismatch in msmsdccc_config_dma()[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: msm_sdcc: Enable clock scaling capability[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: core: remove the polling for BKOPS completion[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: msm_bus: Fix the 64-bit division during interleaving[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: msm_bus: Change MDP port interleaved setting[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: msm_bus: Add NULL pointer checks[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: msm_bus: Explicitly clear client requests before removal[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: msm_bus: Correct the return value from register-client[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: pm-data: Enable powercollapse/suspend_enabled for non-boot cpus[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]sched: Reset rq->next_interval before going idle[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]hrtimer: Prevent hrtimer_enqueue_reprogram race[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]sched: fix reference to wrong cfs_rq[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]sched: Convert BUG_ON()s in try_to_wake_up_local() to WARN_ON_ONCE()s[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]sched: change WARN_ON_ONCE to WARN_ON in try_to_wake_up_local()[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: move printk out of spin lock low_water_lock[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm: pm: Add support to query cpu status[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mako: Add support to query cpu status[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]mmc: Urgent request support[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]msm_fb: hdmi: Resolution modes on HDMI[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]remove compilation error by changing int to uint32_t[/FONT][/COLOR]
[COLOR=#1155cc][FONT=Arial]video: msm: external: Limit HDMI to standard resolutions[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]Tweaks aus meinen S3-Zeiten im confg Script:[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]# VM-Tweaks[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "4096" > /proc/sys/vm/min_free_kbytes;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "0" > /proc/sys/vm/oom_kill_allocating_task;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "0" > /proc/sys/vm/panic_on_oom;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "0" > /proc/sys/vm/laptop_mode;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "0" > /proc/sys/vm/swappiness;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "50" > /proc/sys/vm/vfs_cache_pressure;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "90" > /proc/sys/vm/dirty_ratio;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "1" > /proc/sys/vm/overcommit_memory;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "4" > /proc/sys/vm/min_free_order_shift;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "1" > /proc/sys/vm/oom_dump_tasks;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "0" > /proc/sys/vm/swappiness[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "1000" > /proc/sys/vm/dirty_writeback_centisecs;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "500" > /proc/sys/vm/dirty_expire_centisecs;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "8" > /proc/sys/vm/page-cluster;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "3" > /proc/sys/vm/drop_caches[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]# File-System[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "10" > /proc/sys/fs/lease-break-time;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "32000" > /proc/sys/fs/inotify/max_queued_events;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "524288" > /proc/sys/fs/file-max;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "256" > /proc/sys/fs/inotify/max_user_instances;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "10240" > /proc/sys/fs/inotify/max_user_watches;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]# Kernel-Tweaks[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "1000000" > /proc/sys/kernel/sched_min_granularity_ns;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "18000000" > /proc/sys/kernel/sched_latency_ns;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "3000000" > /proc/sys/kernel/sched_wakeup_granularity_ns;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "0" > /proc/sys/kernel/panic;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "1" > /proc/sys/kernel/panic_on_oops;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "64000" > /proc/sys/kernel/msgmni;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "64000" > /proc/sys/kernel/msgmax;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "4096" > /proc/sys/kernel/shmmni;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "2097152" > /proc/sys/kernel/shmall;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "536870912" > /proc/sys/kernel/shmmax;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "524288" > /proc/sys/kernel/threads-max;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "500 512000 64 2048" > /proc/sys/kernel/sem;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "0" > /proc/sys/kernel/sched_child_runs_first;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]# Netzwerk-Tweaks[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "524288" > /proc/sys/net/core/rmem_max;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "524288" > /proc/sys/net/core/wmem_max;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "6144 87380 524288" > /proc/sys/net/ipv4/tcp_rmem;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "1" > /proc/sys/net/ipv4/tcp_tw_recycle;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]echo "6144 87380 524288" > /proc/sys/net/ipv4/tcp_wmem=;[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]Have Fun (=[/FONT][/COLOR]
[COLOR=#000000][FONT=Arial]hells[/FONT][/COLOR]
Thema ist aktuell
ist jetzt eigentlich usb otg drin und funktioniert es?
Beim 4.3er ist USB OTG nicht drin. Kann ich aber wieder einbauen
hells -
Neuer Testkernel läuft echt super!
Respekt, Hellsgod, für diesen geilen Kernel.
Super Laufzeit, verbunden mit hammermäßiger smoothness und super Support.
Mit dir können Franco, Faux und wie alle heißen nicht mithalten!
Lieben Gruß
Denis -
