Bisher hat bei mir nix gelaggt.
[ROM][AOSPA][20.SEP] PARANOIDANDROID 3.99 | HALO 2.0 (4.3 | JWR66V)
Von G+:
everyone, new alpha coming out in a couple of hours ---
first one with options for reversed mode (longpress/doubletap = drag or task), +hide halo from sight completely after x seconds.
shows all icons while you task, the indexing was wrong -
Die sind ja fleißig heute
N4 ftw!!!
Update ist da!
PDroid kommt auch gleich!
ZitatAlles anzeigenHALO alpha 4 rolling out
This perhaps can be called a pre-beta already as it marks a big step from the previous alphas. I guess this is the first time that even very picky people will start to use it - although much work needs to be done for sure.
I give you a small rundown:
- This is the first HALO build with options, you find them under Settings/Toolbars/Statusbar
- Option #1 can hide HALO from sight completely after inactivity, its for those that want to use it as a ticker.
- Option #2 can reverse the gestures that drive its interaction. Its set to reversed by default now, that means tap-drag selects tasks, doubletap-drag or longpress-drag can move it around. Unchecking the options reverses that. In either way, a single tap launches the current halo'ed task and when dragging through tasks if you lift your finger tasks will be launched as well. if you drag back while tasking the last real notification that came in will pop (but not launch).
- When selecting tasks HALO will temporarily show all statusbar icons to make it easier for you. That should be your point of reference, just follow the icons as they light up and select what you want.
- Minor fixes, it dims a little again, some things that wouldnt cause HALO to pop do now, tasking is more straight forward and probably bug-less by now.
Rom is ready for mako, others will follow.
As we slowly wrap up Phase 3 this is what will happen now
1. We divide our efforts. Our designer +Arz Bhatia will start to dress it up. Everyone not involved with design will go low level and weed out activity-related issues (HALO apps dont react to orientation changes, some get dimmed inside, some still cause a black screen for a sec when popping up, the install-button-overlay-gate, etc.).
2. When these things are cleared it will get a few more options, especially a WHITELIST which users might be able to turn into a black-list by themselves. HALO will be offically beta by then.
3. We will try to get this through Googles compatibility test suite. If we are 100% sure that our work is safe and clean we will release source. We flag the feature as stable,move on and invent the next big thing.
One last thing, it has come to our attention that the root scene is already trying to pull the "for all roms" thing again on us. HALO is impossible to do as an app, you will loose all the integration and floating/multitasking capabilities. Do not fall for this low bullshit riding our wave. This project will be open source and available to all roms as always!We are here, doing all this work for free, to push Androids boundaries. That's why we put so much effort into design, integration and execution - to the point of obsession.
We could rip people off easily by putting up half assed "chathead" root apps into the market and get rich. We chose not to, do your part and support actual innovation.[size=8]-- Beitrag Aktualisiert um 15:19 Uhr -- Vorheriger Beitrag war von 14:52 Uhr --[/SIZE]
PDroid auch online
Es gab einen ReUpload seitens des PA Teams! Alle Files sind wieder online. Auch ein neuer Patch!
Gibt es von der aktuellen Version ein Mirror?
Steht im Startpost unter Mirror oder du nimmst den Link in meiner Sigi und sucht es dir selbst raus
Update
ZitatAlles anzeigenHALO))) + HALOALPHA5 rolling out
First things first,
https://play.google.com/store/apps/det…m.paranoid.halo
you guys asked for a solution to dial in your favourite apps anywhere you go. Now Halo is supposed to be simple and straight forward, we never liked this padding-everything-out-with-options business but a modular app is perhaps a nice way to do it.
It integrates well with todays alpha, that means added apps will not clutter your notification curtain. You'll see them through Halo.
Things that were changed in alpha5 are:
- style adaption
- flicking through ongoing tasks gives you the message content, too
- minor clean up and less resource usageIts pretty minor.
Have fun with that app, it's basic but we can sure add functionality to it. We made it free btw and it works for all roms.
*Rom als Mirror & PDroid Patch online*
bin jetzt nach längerer Abstinenz wieder bei PA.
Zu Halo hätte ich noch eine Frage
Kann ich es, wenn ich im Expanded Desktop Mode bin irgendwo aktivieren oder geht das noch nicht ?Gesendet von meinem Nexus 4
Ne musst du vorher aktivieren. Einfach in den quicksettings pie ausschalten Dann aktivieren und dann pie wieder einschalten
N4 ftw!!!
okay, danke.
Halo behält immer das Icon der letzten Benachrichtigung ?Gesendet von meinem Nexus 4
Aktuell noch, ja.
N4 ftw!!!
Gut, Halo funktioniert bis jetzt sehr gut
Die neuen Google Apps vin gestern kann ich aber nicht verwenden/installieren oder ? Dann funktioniert Halo wahrscheinlich nicht mehr ?
Wieso? Halo hat doch nichts mit den Gapps zu tun
Ich habe irgendwo (xda?) gelesen, dass die Multiwindow Funktionen dann nicht mehr funktionieren. Also zumindest für die Gapps, weil sie für Halo angepasst sind.
Ein User auf XDA hat ein gapps package mit den neuen apps bereitgestellt:
[DLMURL]http://forum.xda-developers.com/showthread.php?p=41473844[/DLMURL]
Halo hat nichts mit den Gapps zu tun.
Pro behauptet zwar auch immer, das die PA gapps multi dpi optimiert sind, aber auch das seh ich kritisch^^
Hangout funzt bei mir auch mit Halo ohne Probs -
[...]die PA gapps multi dpi optimiert sind[...]
Sind sie nicht. In den PA Gapps sind immer nur alle möglichen Google Apps reingeknallt, damit es sich wie "Stock" anfühlt. Die GAPPS Packages von goo.im die man mit CM und Konsorten nutzt haben viele Apps nicht drinne.
Das hat moles imho schon mehrmals gesagt.
ChriZer: Das neueste Gapps Package sollte keinerlei Probleme machen. Merhans hat absolut recht.
okay, danke für die info
Neuigkeiten vom PA Team:
ZitatAlles anzeigenParanoid Android • vor 14 Minuten • Öffentlich
HALO)))1.2 // Franco Kernel // Arz Bhatia // Yamil Ghazi
We are such poor suckers, couldn't score I/O tickets. No drinking contests. Next year then. Anyway, since 4.3 seems to be in the loop we're worrying about our own stuff and there's some exciting news, too.
HALO)))1.2 is rolling out, you should receive an update notice from Google Play. Couple of things have been fixed, mainly reboot receiver, start-up woes, theme.
+Francisco Franco will make dedicated kernels for this project. Think of it as a friendship or an endorsement on both sides. We will not add kernel tweaking to the rom but his custom made PA kernel will expose all needed interfaces if you want to go into that. If not you can expect a faster experience, usually better battery life, all the things people love about his kernels. This should theoretically happen for all Nexus platforms which is great.
+Arz Bhatia will help us with the design from now on. You probably know him, he's the guy that designed logos for Xylon and AK Kernel. He'll take over the HALO project in a couple of days and give it a professional grade look. I think Tina's (krbsmlk.de) drawings go well with polygons and abstract forms.
+Yamil Ghazi will be joining us. You know him from Beerbong perhaps. He's been adding more and more cool things to PA over the last weeks/months, for example Androids first multi-UI launcher, he fixed the higher layouts for contacts/dialer and calendar, etc. Probably will also do parts of the HALO backend.
Well, enjoy your I/O. (-:
Franco Kernel. Klasse
neues Build online.
Version 3.55
[DLMURL]http://goo.im/devs/paranoidandroid/roms/mako/alpha/pa_mako-3.55-19MAY2013-185039.zip[/DLMURL]
[size=8]-- Beitrag Aktualisiert um 02:04 Uhr -- Vorheriger Beitrag war von 01:55 Uhr --[/SIZE]
und der g+ post dazu:
ZitatAlles anzeigenHALO6 // HALO)))1.3 // Franco Mako Kernel // Kbrsmlk T-Shirts
So this one is PACKED. I am actually trying to keep it short. : D
Paranoid Android 3.55
Fresh new rom + fresh PA-GAPPS ([DLMURL]http://goo.gl/sAv9L[/DLMURL])
HALO sees first style re-touches (decent looking bubble, shadows, etc.), + images and avatars shouldn't be pixelated. App crashes (twicca, etc.) are fixed, it was all the same error causing this.
+Yamil Ghazi fixed his launcher, had some padding issues and there are several bugfixes for the calendar, which we track ourselves from now on to fix Googles higher layout bugs.
HALO)))
HALO)))1.3 delivers cleaner images.
You can get it for free from Google Play: [DLMURL]http://goo.gl/Jk8d6[/DLMURL]CUSTOM KERNEL
+Francisco Franco made a custom PA kernel. The kernel is kept simple from the looks of it, uses PA colors, has all needed interfaces exposed if you want to tweak it. You can tweak with his app ([DLMURL]http://goo.gl/H1pES[/DLMURL]) and calibrate, if you dislike the colors still, with that one: [DLMURL]http://goo.gl/zDUVo[/DLMURL] --- there are also free alternatives like trickster, perhaps with a little less functionality: [DLMURL]http://goo.gl/aknmi[/DLMURL]
Here's the fulll changelog:
- Less msm_hsic_host wakelock count after merging CAF patches
- Merged latest Ondemand from CAF
- Toggle on/off fsync()
- Sound Control: path: /sys/class/misc/soundcontrol/
- Gamma Control: path: /sys/class/misc/gammacontrol/ (as always, needs screen off for changes to apply)
- Two IO patches from Linux Kernel to improve efficiency of IO operations
- Ditched thermald and uses Francos custom msm_thermal Kernel driver. Possibility to choose the threshold temperature in /sys/module/msm_thermal/parameters/temp_threshold
- Proper partition mounts for better IO performance
- Cleaned DEBUG crap from the Kernel config
- FastchargeExpect longer lasting battery, better benchmark scores and it should not heat up so fast. All Nexus platforms will eventually see these optimizations, for now Mako is the first guineapig, give it a little time.
Again, big thanks to him from all of us. Let's keep in mind, he did it just like that. Offering to make us a competitive kernel. I'm kind of stunned by this as i'm not used to developers coming out and lending a hand - and for him that meant a fricking weekend gone.
PA SHIRTS
Last but not least, some of you have been asking for shirts and +Tina Krebina has heard you. She's made some and you can get them here: http://www.zazzle.de/krebsmilk
Pricing is all done by Zazzle, this is standard fare. She basically provides the design and collects a pocket change, the bulk goes to Zazzle but at least they print, do the sale and ship everywhere.Expect more designs to come. What's in there right now is PA retro, the iconic green ... thing which graced our first ever topics. We will keep you updated when Tina or +Arz Bhatia make new stuff.
Should anyone get one, make pictures!!! We'll be so damn proud! : D
