[ROM][AOSPA][20.SEP] PARANOIDANDROID 3.99 | HALO 2.0 (4.3 | JWR66V)
  • Update:
    PIE:
    Statuspanel header with time, date and /// clear-all button
    Notifications one-finger swipe-open gestures
    Misc:
    AOKP's sound to vibration toggle
    +Koushik Dutta*'s SuperUser updates
    (Mako) Flickering when switching apps is gone
    (Mako) HSPAP support
  • Status update 6th-7th March
    The complete toggle implementation has been redone from scratch, of course using +CyanogenMod*'s splendid sources. It wasn't such a good idea to refactor it, we had this and that extra feature at the expense of staying up to date. Again, toggles apply to all four UI's: Phone, Phablet, Tablet and PIE.
    A new toggle to switch seamless between fullscreen/PIE & normal desktop mode. Who doesn't hate pressing the powerbutton. Its such a simple little detail, why didnt we do that earlier ....
    A new option to prevent PIE from restarting your launcher. That's the wee blackout you see when switching between modes. It still defaults to ON, because it is a safety measure against crazy launcher screw-ups. You can switch it off if you can deal with it, but don't come to us crying when your launcher messes up. (-;
    New SuperUser updates thx to +Koushik Dutta*- more detailed descriptions on his channel. Minor PIE style changes + performance and optimization tweaks.
  • Huhu,
    und hi Elting altes Haus! :)
    Sagt mal, das einzige was mich stört ist, dass beim expanded Desktop oben die Statusbar ausgeblendet wird - gibts eine Option wo das nicht passiert?
    Also das nur unten die Pfeile vom Nexus weggehen und oben die Statusbar bleibt?
  • Changelog zum Build vom 7.3:
    Battery percentage via circle battery
    (Mako) 4 Layer composition switched on again, faster redraw
    (Grouper) Fixed issues with pixels getting stuck in PIE mode
    New pie toggle icons
    Bluetooth audio sampling increase
    Der Build wurde allerdings wieder entfernt. Kommt sicher im Laufe des Tages wieder online.
  • Noch eine kleine Info von moles dazu:
    Zitat von molesarecoming
    it was very late last night, i noticed in the last moment i forgot to invalidate the % battery, so per app color wouldnt work. it worked while connected to usb because of the animation, thats why i didnt notice. i will wrap this up today and also include the new 4.2.2 latinIME that should have better predictibility + im enabling additional keyshortcuts.
  • Neue Version inkl neuer Gapps online!
    MAR07 RE-UP + NEW MAR07 GAPPS
    battery %
    updated aosp ime with gesture support and fresh libraries
    aosp mms
    4 layer compositioning ON against the sluggish scrolling
    HW overlay fix for pie against flickering when switching apps
    and the other patches that i have mentioned yesterday
  • Habt ihr alle auf das neue Baseband geupdatet ? Bei mir bricht immer der Empfang ab, bzw nach einem Reboot hab ich so lang kein Netz, bis ich meinen Provider manuell auswähle ... Hab schon alles probiert.. Rom neu geflasht, Baseband und Bootloader .. nichts hat geholfen :evil:
  • Ja, hab damals per Toolkit das Factory Image von 4.2.2 geflasht um das neue Baseband und den neuen Bootloader zu bekommen.
    Bisher hab ich keine Probleme mit dem Empfang und den letzten PA-Builds.
    Das Build von heute konnte ich bisher aber noch nicht testen...
  • Ich wer mal eine andere Rom testen, vielleicht ist es ja dann wieder gut ...
    Edit: Hab Primerunner geflasht und es hat auch nicht geholfen.. Hab dann einen Tipp im Internet gefunden, der das Problem zu lösen scheint:
    [COLOR=#000000]I did this:[/COLOR]
    Type *#*#4636#*#* and go into "phone information"
    scroll down a bit and choose LTE/GSM/CDMA auto (PRL) at the dropdown.
    [COLOR=#000000]Note that this can be illegal in some countries. [/COLOR]
    Nach einem Reboot erscheint das Dreieck mit dem Rufzeichen zwar noch immer in der Satusbar, aber danach connected es sofort.
