[COLOR=Red]Dieser Kernel ist NUR für Samsung 4.1.2 ROMs oder CM10.1, AOKP, AOSP ROMs gedacht[/COLOR]
Googy-Max Kernel is initially based on the wonderful work of Gokhanmoral (Siyah Kernel) .
[COLOR=Red][size=12]Features : [/SIZE][/COLOR]
- based on Siyah Kernel 1.9.1 Sources
- Dual-booting. You can have Samsung JB and CM10.1 ROMs on a single device at the same time
- Updated to latest ramdisk
- Patched to Samsung Sources Update10
- Linux version 3.0.78
- Compiled with gcc linaro 4.7.3
- Zram with new lzo compression
- CPU OC/UC/UV
- GPU OC/UC/UV
- Audio enhancement and sound boosting for great headphone experience  (partial-port of wm8994 based implementation from project-voodoo)
- Governors : Pegasusq / Zzmoove / Lulzactiveq [default] / Ondemand / Hotplug
- I/O Schedulers : Deadline - cfq[default] - noop - row - sio - vr
- Dynamic FSync
- init.d support
- Increased values for SD ReadAhead
- Auto-root
- Kernel based gestures support by Tungstwenty
- NTFS automounting for USB sticks, mounted to /mnt/ntfs folder in Read Only mode
- ExFAT support
- mDNIe negative effect toggle with 4 consecutive press of home button
- mDNIe values can be adjusted using the interfaces in /sys/class/misc/mdnie
- Higher charging rates for AC & USB chargers (Fast Charge) [Adjustable]
- CRT-OFF support (Early Suspend) [Adjustable]
- TriangleAway support
- Almost everything is configurable via simple and free STweaks (included in the kernel)
- slide2wake (incomplete)
[COLOR=SeaGreen]Changelog : [/COLOR]
 [13/05] Version 1.2.0 :
- Updated to Linux 3.0.78
- Activated Zram with updated lzo compression
- Some pegasusq optimizations
- lulzactiveq is now set by default
- No more lags !!!
 [11/05] Version 1.1.0 :
- Fixed a LOT of mali & ump driver settings problems => Huge performance boost
- Higher Random Entropy
- Min & Max SD ReadAhead x2
- Wifi driver from i9500 sources
- Dynamic FSync
- Zzmoove 0.4
 [08/05] Version 1.0.0 (Compared to Siyah base) :
- Updated to Linux 3.0.77
- Disabled Zram
[DLMURL="http://forum.xda-developers.com/showthread.php?t=2270158"]Quelle[/DLMURL]
