ZitatAlles anzeigen[size=14][FONT=Century Gothic][COLOR=#222225]This thread is a placeholder for all possible firmwares we can get from official Jelly Bean OTA's.[/COLOR][/FONT][/SIZE]
[size=10][FONT=Century Gothic][COLOR=#222225]Your CID number must be [/COLOR][/FONT][/SIZE][COLOR=red][size=10][FONT=Century Gothic]exactly[/FONT][/SIZE][/COLOR][size=10][FONT=Century Gothic][COLOR=#222225] the same. If it's written "HTC__001" it means you can't flash it, if your CID is "02__001". [/COLOR][/FONT][/SIZE][size=10][FONT=Century Gothic][COLOR=#222225]The whole text must match![/COLOR][/FONT][/SIZE]
[size=10][FONT=Century Gothic][COLOR=#222225][COLOR=red][size=24]Please READ this small F.A.Q. before continuing![/SIZE][/COLOR][/COLOR][/FONT][/SIZE]
[size=10][FONT=Century Gothic][COLOR=#222225][/COLOR][/FONT][/SIZE]
What is firmware.zip?
Firmware.zip is a part of each OTA update from HTC. It contains important part of the firmware like radio, bootloader, recovery, kernel etc..Why it's important to flash firmware.zip and when should I flash it?
It is recommended to have flashed latest firmware on your device for best modem performance and system stability. Sometimes it's necessary to have latest bootloader flashed because otherwise your device might not work well with new system update.Does firmware.zip contains radio?
Yes, it does contain radio, and for S-ON devices the only method to update radio is to flash latest firmware.zipWhy it's important to flash it before flashing custom ROM?
Because firmware.zip contains boot.img (ramdisk and kernel) that will replace custom boot.img from any custom ROM you have. That's why you have to flash firmware.zip first, because otherwise boot.img will be overwritten with stock one.
If you already flashed firmware.zip after flashing custom ROM, just flash this particular custom ROM again.Does firmware.zip contains recovery?
Yes, it does contain recovery image, that's why after flashing firmware.zip you will have to flash custom recovery again, to be able to flash custom ROM afterwards.Can I flash this firmware.zip on any HTC One?
Not if your device is S-ON. To be able to flash it on S-ON device, your modelid (example: PN0710000) and cidnum (example: HTC__001) must match the firmware.zip version you are about to flash.If my modelid or cidnum doesn't match, can I brick my device if I try to flash firmware.zip anyway?
As long as your device is S-ON flashing firmware.zip with non matching modelid or cidnum will result in error and nothing will be flashed, so there is no risk of brick.Do I need to have locked, unlocked or relocked bootloader to be able to flash firmware.zip?
Your bootloader needs to be relocked.If I can't flash newest firmware.zip because of wrong modeid (MID) or cidnum (CID) does it mean I can't use custom ROM based on the latest HTC update?
In most cases you should be able to run any custom ROM as long as hboot update is not mandatory.What if there is no firmware.zip for my MID/CID?
Try to find latest OTA update for your original stock ROM and send it to me. I will post firmware.zip here.[/COLOR][/FONT][/SIZE]
[INDENT][size=10][FONT=Century Gothic][COLOR=#222225]x.xx.401.x - World Wide English (WWE)[/COLOR][/FONT][/SIZE]
[INDENT][size=10][size=10][FONT=Century Gothic][COLOR=#222225]modelid: PN0710000
cidnum: HTC__001
cidnum: HTC__E11
cidnum: HTC__102
cidnum: HTC__203
cidnum: HTC__405
cidnum: HTC__Y13
cidnum: HTC__304
cidnum: HTC__032
cidnum: HTC__A07
cidnum: HTC__J15
cidnum: HTC__016[/COLOR][/FONT][/SIZE][/SIZE][/INDENT]
[FONT=Century Gothic]Download:[/FONT]
[size=10][FONT=Century Gothic][COLOR=#222225][COLOR=#d38339]firmware.zip from 2.24.401.12[/COLOR][/COLOR]
[COLOR=#222225]MD5:
774DB3DAA7A91FDB243E8D1BDC27E578
x.xx.709.x - Asia TW (Taiwan)[/COLOR][/FONT][/SIZE]
[INDENT][size=10][size=10][FONT=Century Gothic][COLOR=#222225]modelid: PN0711000
cidnum: HTC__621[/COLOR][/FONT][/SIZE][/SIZE][/INDENT]
[size=10][FONT=Century Gothic][COLOR=#222225][COLOR=#d38339]firmware.zip from 2.24.709.1[/COLOR][/COLOR]
[COLOR=#222225]MD5:
1591DF9AA3528A11C01DC9E66C707CD0
x.xx.111.x - T-Mobile DE (Germany)[/COLOR][/FONT][/SIZE]
cidnum: T-MOB101[/COLOR][/FONT][/SIZE][/SIZE][/INDENT]
[size=10][FONT=Century Gothic][COLOR=#222225][COLOR=#d38339]firmware.zip from 1.29.111.11[/COLOR][/COLOR]
[COLOR=#222225]MD5:
44E69229678B3487BE81851384B18ABF
x.xx.206.x - O2 UK (United Kingdom)[/COLOR][/FONT][/SIZE]
[size=10][FONT=Century Gothic][COLOR=#222225][COLOR=#d38339]firmware.zip from 1.29.206.11[/COLOR][/COLOR]
[COLOR=#222225]MD5:
50D39873827CD1EE5FFFADB21A1FC914[/COLOR][/FONT][/SIZE][/INDENT][size=10][FONT=Century Gothic][COLOR=#222225]The rest will follow! [/COLOR][/FONT][/SIZE]
How to flash?
(bootloader needs to be relocked)
- Re-lock your bootloader ([COLOR=red]this will most probably wipe content of your device[/COLOR])
- Copy downloaded .zip to fastboot.exe location (e.g. c:/SDK/platform-tools/fastboot.exe)
- Re-name .zip file to firmware.zip
- Open command prompt
- Boot your device in fastboot mode (vol down + power ===> fastboot)
- Connect device to the PC
- In command prompt cd to fastboot.exe location
- Make sure you have correct modeid and cidnum (type: [COLOR=#a0522d]fastboot getvar all[/COLOR])
- Type: [COLOR=#a0522d]fastboot oem lock[/COLOR] (if your device is not relocked yet)
- Type: [COLOR=#a0522d]fastboot oem rebootRUU[/COLOR] and wait for device to reboot
- Type: [COLOR=#a0522d]fastboot flash zip firmware.zip[/COLOR] and wait for process to complete
- Sometimes flashing for the first time doesn't work, so flash firmware.zip again just to make sure.
- Type: [COLOR=#a0522d]fastboot reboot[/COLOR]
- Unlock your bootloader and flash custom recovery if you are going to use custom ROM.
[/FONT]
[size=10][FONT=Century Gothic][COLOR=#222225]RUUs variants:[/COLOR][/FONT][/SIZE]
[size=10][FONT=Century Gothic][COLOR=#222225]Click [/COLOR][COLOR=#d38339]here[/COLOR][/FONT][/SIZE]
ZitatAlles anzeigen
[COLOR=navy]Custom firmware[/COLOR]
[INDENT][size=10][FONT=Century Gothic][COLOR=#222225]Overview[/COLOR][/FONT][/SIZE]
[INDENT][size=10][FONT=Century Gothic][COLOR=#222225] [/COLOR][/FONT][/SIZE]
- Custom firmware - firmware.zip package built from RUU with the changed content (adsp.img, rpm.img, hboot.img and others).
- These packages are not signed, so you need S-OFF in order to flash it.
- I take no responsibility for any damaged caused to your device, you flash it at your own risk.
- Flashing process is the same as for official firmware.zip taken from HTC OTA package.
[/FONT]
[/INDENT][/INDENT]
Firmware package from 2.17.401.1 RUU
- There are new touch panel drivers inside this firmware that breaks touch in custom recoveries. You can flash it and use only hardware keys in custom recovery or you can remove tp_SYN3202.img from inside the package before flashing.
- This device should work with no issue on any M7_UL PN0710000 device, however it might work on others too. You flash it at your own risk. More details here - [COLOR=#d38339]HTC One variants [U/UL/WL][/COLOR]
- If you want to add more modelid or cidnum open and edit android-info.txt inside firmware.zip package. Be careful with adding different modelid because you might end up with a bricked device.
- Basically there is no clear reason why you should update this firmware, because it seems that all 4.2.2 custom ROMs are working perfectly fine with old firmware.
- Read [COLOR=#d38339]this[/COLOR] and [COLOR=#d38339]this[/COLOR]
- By default android-info.txt comes with the following modelid and cidnum:
cidnum: 11111111
cidnum: HTC__001
cidnum: HTC__E11
cidnum: HTC__102
cidnum: HTC__203
cidnum: HTC__405
cidnum: HTC__Y13
cidnum: HTC__304
cidnum: HTC__032
cidnum: HTC__A07
cidnum: HTC__J15
cidnum: HTC__016[/COLOR][/FONT][/SIZE]Download link
[size=10][FONT=Century Gothic][COLOR=#222225]MD5: 44222F608CF87050263BB8B59A013F5F[/COLOR][/FONT][/SIZE]
Quelle:
