• kommt später gibts aber schon ... muss nur halbwegs auf deutsch bekommen
    Mit dem folgenden Mod kann man Rotation um 360° in allen Screens, inkl. Lockscreen, aktivieren. CRT Off geht wohl noch nicht.
    Zitat:
    Zitat von The Undertakerr
    Hey guys!
    I Decompiled the LE9 stock framework-res and enabled some features in it...
    Not a very big deal, but nice to have.
    -Enabled all rotations, the screen will rotate 360degrees.
    -Enabled LockScreen Rotation, Lockscreen will rotate 360degrees.
    -Disabled Keyboard Switch icon in Statusbar when typing.
    -Enabled the CRT OFF(Old TV Effect) in the framework. But it is not working. Normally we set for crt-off:
    Code:
    <bool name="config_animateScreenLights">false</bool>
    But like I said, this doesn't seem to work on an S3.
    So I tried a modded libsurfaceflinger.so from the S2 to make it work, but that failed also.
    The "old television effect" is going to be a problem, to make that work on the S3, I can predict that!
    -Sip/VOIP calling is allready activated on the S3, also over 3G, so I didn't have to activate that!
    I fixed all the plurals, to be able to recompile the framework an recompiled it.
    (So this framework-res can, from now on, be easily de and recompiled)
    Downloadlink flashable zip:
    Download
    Downloadlink RESTORE Original LE9 framework-res:
    Download
    I advise to put both zips on your internal sdcard. If you don't like the mod or for some reason, it's not working for you, you can reboot to recovery and flash the restore zip!
    -You will need a CWMrecovery to be able to flash this zip.
    -It can be flashed on both Odexed & Deodexed LE9 Rom.
    Have Fun!
    Ps: I don't own an S3 but an S2. I tested this on my girl's phone.
    Maybe this weekend I will make an extended powermenu for you guys, with the options reboot to recovery and download mode...
    xda: [MOD]4-way Reboot Extended PowerMenu+All rotations+Lockscreen Rotation enabled on LE9 - xda-developers
    Mit diesem Mod erweitert man das Powermenü um die Punkte "Boot in Recovery" und "Boot in Download".
    Ok guys,
    Made you an Extended Powermenu with reboot to Recovery and Download mode in it.
    When press the on/off button for a few seconds, your extended powermenu shows up.
    After flashing this zip, in that menu, under the restart button, you should find the options: "Recovery" and "Download" mode...
    This mod is untested, because my girl Essie is allready sound asleep.
    Edit: Now tested and working!
    So if you want to test it, you would be the first!
    I also included a RESTORE zip, this zip will restore things when somethings goes wrong!
    If this mod is not working, reboot to recovery using the 3 button combo and flash the restore zip, ok?
    Downloadlink extended powermenu:
    Download
    Downloadlink RESTORE zip(In case the above zip is not working):
    Download
    I advise to put both zips on your internal sdcard. If the mod is not working for you, you can reboot to recovery using the 3 button combo and flash the restore zip!
    -Only flash this on DEODEXED LE9!!
    -You will be needing to have CWMrecovery to be able to flash this zip.
    Big thanks to Kahvitahra for the S2 sources to make a 4-way reboot extended powermenu!
