[size=36]Team Custom Freaks presents - PaRaNOiA RoM[/SIZE]
Credits:
- PA für die BASEROM
- customworx
- Einsteinno1
- Sakaschi [Anti RamBug Script]
- Invi
- Team Custom Freaks
- und alle anderen
Dieser Rom hat als Basis wie der Name vlt schon erahnen lässt [Cm10 Hybrid] Paranoidandroid.
Veränderungen entnehmt ihr bitte aus der Changelog !!
Wird immer auf die aktuellen Paranoidandroid aktuellen Versionen Updated.
Aktuelle Changelog von der jeweiligen Basis entnehmt ihr Bitte auf Paranoid Android - Home ...
Video-How To Install PARANOIDANDROID Hybrid ROM
[DLMURL="
[size=36][COLOR=Blue]PaRaNOiA RoM V[size=36]7[/SIZE].[size=36]3[/SIZE].0[/COLOR][/SIZE]
PaRaNOiA RoM V7.3
[size=36][COLOR=#ff0000]Download[/COLOR][/SIZE]
Team Custom Freaks JB 4.2 Gapps
Whats New V7.2 to V7.3
PaRaNOiA RoM V7.3
Added:
SiyahKernel v1.8.4
Update System Apps to New Version
Ported CPU UV tab from AndreiLux’s STweaks config
Dynamic generation of STweaks config and initial GPU voltages are set correctly (mostly based on AndreiLux’s uci.sh script interface while trying to keep the changes minimum to support other guys using my scripts as base)
Workaround for CRT animation problem (at the bottom of the screen tab in STweaks)
fixed the problem of copying large files that some users experience
removed custom modifications from pegasusq governor and changed the tweaked values a little
v1.8.4: reverted VM_MAX_READAHEAD commit. adjusted cpu hotplug in/out rates in pegasusq because they were just too low after decreasing the sampling time.
Changelog from 7.2 -->>> 7.3
This Version will fixed most Problem
Fix Sound in Spotify etc..
Added in Data/App
RootBrowser New Version
SdIncrease SDCard Boost
SD-Card speed improvement
Floating Popup Browser
Dolphin Browser Beta (Fast Browser-Gesture Features)
Floating Banner
Popup Video Player
Super Manager V3.0(For PopUp Video Player)
4.2 JellyBean Full Emoji-Keyboard
....and all that I have forgotten
7.1 to 7.2
-Complete system has been revised, so any Gapps flashable
-New Team Custom Freaks 4.2 Gapps Full
-Including NFC FIX in the Rom
-Update to new PA v2.5 Rom
-Update to new Super SU
-Update Holo Launcher HD to new Version
-Siyah 1.7 RC3 Kernel / Dualboot
[DLMURL="http://www.android-hilfe.de/custom-roms-fuer-samsung-galaxy-s3/295330-aosp-rom-jb-4-1-2-paranoia-rom-cm10hybrid-155.html#post4443240"]Hot Plugging Script (battery)[/DLMURL]
Reading That
Neue PaRaNOiA RoM Aroma Apps
Download
[size=36]Installation
CWM -- Wipe Data/Factory Reset --
Wipe Dalvik Cache -- Flash Rom --
Wipe Cache -- Wipe Dalvik --
Fix Battery Stat. -- Fix Permission
Reboot [/SIZE]
Installation
[COLOR=#00ff00]!!! Keine Gapps oder Compuser Installieren .ALLES bereits im Rom enthalten !!![/color][COLOR=#00ff00][/COLOR]
[COLOR=#0000ff]CWM -- Wipe Data/Factory Reset --
Fix Battery Stat. -- Fix Permission [/COLOR]
[COLOR=#00ff00]Reboot[/COLOR]
[COLOR=#0000ff]Div. Roms Gapps und Downloads[/COLOR]
[DLMURL="http://roms.custom-android.de/files/Roms/GalaxyS3/Team_Custom-Freaks/CM10/ParanoiaRom/roms/PaRaNOiA_RoM_V4.3.0.zip"]PaRaNOiA V4.3.0[/DLMURL]
[DLMURL="http://roms.custom-android.de/files/Roms/GalaxyS3/Team_Custom-Freaks/CM10/ParanoiaRom/Diverses/OldHWCompuser.zip"]Old Compuser[/DLMURL]
[DLMURL="http://goo.im/gapps"]Gapps[/DLMURL]
PaRaNOiA Apps Paket
- Aroma Installer
[COLOR=#0000ff]*Alle Apps und Themen, die sonst direkt in der Rom waren
könnt ihr jetzt auch einzeln mit AROMA-Installer installieren[/COLOR]
PaRaNOiA V4.3 CWM-CF-1.5 Backup für alle Fälle
Entpacken und den cllockworkmod Ordner auf die Sdcard ablegen und Restoren
I[COLOR=#0000ff]nstallation[/COLOR]
*Fullwipe -Data/Factory Reset ,Wipe cache ,wipe Dalvik
*Fix Permissions
*Flash Rom (Beim ersten Versuch die Rom zu flashen kann es vorkommen das der flash nicht funktioniert ist ein Fehler von der 1.9.9.2 ! Einfach advanced ---reboot recovery und neu flashen dann funzt es !!!)
*Flash Gapps
*Flash New or Old HW Composer
*Wipe cache
*Fix Permissions
*Reboot
[COLOR=#0000ff]HowTo Install-English[/COLOR]
CWM: YOU NEED TO FULLWIPE IF YOU WERE USING ANOTHER ROM BEFORE
Download last PaRaNOiA RoM
CWM: Install possible Mods/Patches:
New HW Composer (MIGHT be smoother, thanks to VSync. Caution: Fullscreen Video Playback hangs)
Undo=Old HW
Download [DLMURL="http://goo.im/gapps"]Gapps[/DLMURL]
Install CWM
Wipe Cache Partition
Advanced/Wipe Dalvik Cache
Reboot and edit your Apps Dpi & Layout under Settings/Paranoid Settings - DO NOT RESTORE YOUR OLD PROPERTIES FOR NOW
If you're facing issues, please Fix Permissions
[COLOR=#00ff00]Installation Anfänger gerecht[/COLOR]
Ladet euch die Zip auf eurem Pc.
Kopiert die PaRaNOiA_RoM.zip auf Eure SD-Karte.
Nun Startet ihr das SGS3 in dass Recovery System.
Führt ein Nandroid Backup aus.
Danach einen Full Wipe ausführen. (Wipe data/factory Reset, format cache, format system, format data)
Nun wählt ihr die Zip von eurer SD Karte. (install zip from sdcard -> choose zip from sdcard)
Beim ersten Versuch die Rom zu flashen kann es vorkommen das der flash nicht funktioniert ist ein Fehler von der 1.9.9.2 ! Einfach advanced —reboot recovery und neu flashen dann funzt es !!!
Installiert dann über die selbe Methode auch noch die [Gapps] Google Apps und den neuen oder alten HW Composer[Old empfohlen , sonst kann es zu Microruckler geben]
Wiped den Cache nochmal zur Sicherheit und unter Advanced findet ihr noch Wipe Dalvik und Fix Permissions, auch nur zur Sicherheit noch dazu ausführen.
Reboot und Spaß haben
[COLOR=#0000ff]PaRaNOiA RoM Changelog V4.3[/COLOR]
- OTA Update-UpdateME
- Rom mit wenigen Apps als Standart
- Div Apps , Mods ,Themes
- alles extra Installierbar mit UpdateME
- Anti Ram Bug Script @Sakaschi
- Scrolling verbessert
- 3G/UMTS verbessert
- AOSP Cam
- Faster Wifi
- Akkulaufzeit verbessert
- Bildqualität bei Anzeige verbessert
- Standart DPI 240
- Komp.-AdFree [Build.prop]
- Streaming verbessert
- Error-Reports deaktiviert
- Nutzerdatenberichte deaktiviert
- USB-Debugging Icon in der Statusleiste deaktiviert (benötigt 2x reboot!)
- Appstart verbessert
- Weniger RAM auslastung
- Homescreen im Speicher behalten aktiviert
- Dalvik Tweaks
- System stellt automatisch mehr RAM zur Verfügung wenn nötig
- mehr Performance
- Mehr Speed
- build.prop Tweaks
- SD-Speed Tweaks
- Zipalign beim Bootvorgang
- Siyah 1.5.2 Kernel Standart
- Holo Launcher HD Standart
- Adobe Flashplayer Standart
- uvm.....
[COLOR=#0000ff]Mit UpdateMe oder PaRaNOiA Aroma Apps Installierbar[/COLOR]
SVoice
Mali Staus
KTool 1.56 b1
Titanium Backup
Datei Manager
Adobe Flashplayer
Whats App Plus HOLO v1.95
Cobolt Theme blue
Cobolt Theme orange
Cobolt Theme red
uvm....
[COLOR=#0000ff]Was funktioniert Bei Base Paranoidandroid +1.992 nicht und Lösungen[/COLOR]
Front Camera stuck on front snapped pic. (No FC. Buttons functional)
You tell meWas ist zu tun wenn Wlan nicht funktioniert
** WiFi works flawlessly.
But, in case your WiFi is broken, blame your bootloader.
Try any or both of these: (thanks to CM10 discussions)SOLUTION 1: FLASH back to any OLDER ROM, like PA v1.9.8, Omega v13 or CM10 0812 or any CM9, for OLD version of bootloader, then nandroid restore PAv1.991.
SOLUTION 2: Come from any ICS bootloader based ROM. You can also install CM10 straight away from stock samsung ICS 4.0.4. Make sure you flash the 27/6 signed gapps along with CM10. (Try goo.im)
DO NOT try to flash CM10 over leaked samsung JB Roms, you will bootloop your device!
Tipp :
einstellung---display---bildschirm ausrichtung 90 180 270 0
einstellungen-----system---navigationsleiste----softbutton aktivieren
einstellung--design ---theme wählen
einstellungen ---paranoid setting ---workspace und auf med tablet ui
[COLOR=#ff0000]Weder Ich Das Team Custom Freaks noch Paranoidandroid ist verantwortlich für SCHÄDEN die ihr euch beim Flashen zufügen könntet ..
Hier gilt wie auch bei allen anderen Custom Roms. Nur ihr seit für euer handeln verantwortlich!!
Wenn euch ,der PaRaNOiA Rom gefällt und ihr den Rom auch benützt drückt doch BITTE einfach Danke ![/COLOR]
