Nee noch nicht, wird aber hoffentlich die Woche passieren, wenn ich mehr Zeit habe.
CM11 - temasek's UNOFFICIAL BUILD - V161 - 17.11.2014 [4.4.4 - KTU84P]
V61
Revert "Active Display" - Total of 39 commits, OMG!
Didn't realised CMUpdater sneaked in again. I'll remove it from source building on next build (again).
- This commit just reintroduce CMUpdater which I had removed from building long ago.
- I just commited (again) the removal of building CMUpdater from source.
- For now you can just delete the file "CMUpdater.apk" from /system/app and reboot.
- If not then u can leave it alone. But it will consume some unnecessary memory since we don't use it.
- Affected i9300 only - my tilapia & grouper not affected.Updated cm source
md5sum: 07eb108b7397ba4d47b21e10afde8329
Und heute gibt es V62
Build V62
md5sum: 2eadb1763f9817c8a0180c30a534189f- Updated cm source only
- Too tired after resolving the build issue
Inzwischen sind wir bei V64.
Changelogs von V63 und V64:
TEMASEK's CM 10.2 V64
Revert "dynamic PIE menu button + navbar menu logic cleanup" by SlimROM
By user request - The return of MENU key in navigation bar
- Also Retained dynamic MENU key in PIEFIX SystemUI FC when using inverted UI or toggling Dark Droid - @Cristiano Matos
Updated cm source
md5sum: 70cb7218d66ca42f756ee16ebd8f3bf4
TEMASEK's CM 10.2 V63
• Those on V62 should update it asap.
Telephony related fixes.
I've added an overlay for i9300 for "Smart cover wake" feature.
- NOT tested on phones, ie i9300
- Tested working great on tablets, ie my tilapia.Updated cm source
md5sum: ea0b8cfb48fa50ba7eebbee76f347ac9
Weiter geht es heute mit der V65
TEMASEK's CM 10.2 V65
WARNING:
Temasek kernel users, pls backup your profile before flashing temasek kernel over V65.Clobbered build.
Advanced Display making a comeback.
- Settings -> Display & lights -> Advanced Display
- Because of the above, those on AndreiLux's display settings via kernel tweaks may have to re-enable your settings via STWeaks.Lots of merged stuffs, read on your own.
Updated cm source
md5sum: 59401cb742e89e76366330f664f1fd6b
I'm kinda busy both at work and family atm so excuse me if I'm not very active for sometime.
Seit heute gibt es V66:
Some important bug fixing in cm sources.
Clobbered build
Updated cm source
md5sum: 5a34a6d4d7586188230e8b7f141a70f2
Und schon sind wir bei V67.
Build V67
md5sum: e34902cb1fc04666183b16319e7d05fd- Traffic meter enhance coding style - @Cristiano Matos
- Consolidate code;
- Move all traffic meter options to one commom class;
- Recoding color and reset color features;
- Some other changes and a clean up in status_bar.xml;
- Pls re-toggle your options due to coding changes - Halo colors - David96
- Halo colors enhacement - @Cristiano Matos
- Recoding to consolidate the code;
- ability to reset all stock colors even with custom colors enabled; - Revert "Reboot tile to QS"
- Add "Power Menu to QS Tile" - @Cristiano Matos
- Updated cm source
Available for i9300 / tilapia / grouper
Nach V67 folgt V68:
Build V68
md5sum: 87760a4a2cf361f4166685ab529bde9c- Revert "Network Traffic Meter"
- Added "Network usage stats to status bar" - 0xD34D
- ul/dl indicators - NetStats: Don't update stats when screen is off
- Network stats custom colors - @Cristiano Matos
- smdk4412-common: camera: Block out endlessly looping focus clause
- capture_auto_focus_result isn't updated from any realtime focus callback, so waiting for it to change in order to complete the capture introduces delay, and in some cases an infinite loop.
- Remove the focus state verification, at least until such a callback can be put in place. - Updated cm source
Heute geht es mit der V70 weiter.
V70Spoiler anzeigen
TEMASEK's CM 10.2 V70
NetStats lights out mode - @Cristiano Matos
frameworks - speed up orientation change (a little)
smdk4412 camera commits - See for yourself.
- [DLMURL]https://github.com/temasek/android_d...ommits/cm-10.2[/DLMURL]Updated cm source
md5sum: 2fbaa8106bf7f75d0a87908876aecf85
Mini Update für V70Spoiler anzeigen
V70 TINY UPDATE
V70-UPDATE-temasek-i9300.zip
FIXED- FC on HALO Settings due to wrong path in Settings header xml file.
Instructions:- Flash over V70
Available in both sites.
Und die V71
CURRENT CHANGELOGTEMASEK's CM 10.2 V70 & V71
- [DLMURL]https://github.com/temasek/android_d...ommits/cm-10.2[/DLMURL]Updated cm source (On V71 aswell)
V70 md5sum: 2fbaa8106bf7f75d0a87908876aecf85
V71 md5sum: 3360c7a363387aee664668b0b82bbecb -
Der 71 folgt die 72:
Build V72
md5sum: b2b76cc35f8e5f7fc260ef9aab203f6a- Updated cm source
Available for i9300 / tilapia / grouperEnjoy
Auch verfügbar für die beiden 2012er Nexus 7 Modelle grouper und tilapia.
V73 gibt es nur für das S3.
Build V73
md5sum: ab9622e1342a22b725a5b0e6c7e47363Available for i9300 only
Heute gibt es keinen neuen CM10.2 Build, aber dafür ne CM11 Preview.
Läuft wohl noch nicht so rund (Wifi und Kamera Probleme), aber das dauert sicher nicht mehr lange.Spoiler anzeigen
Build - PREVIEW (CM11)
md5sum: 037669da9d8499f5be882ee8574b971eTHIS IS AN UNTESTED BUILD - Too sleepy to test.
Pls feedback if it even boots up or other issues. I would highly suggest u do a nandroid backup.
Flash over cm10.2 is ok.
Instructions:
Wipe /system
Flash cm11
Flash correct gapps for kk
Reboot -
Mit CM10.2 war es das wohl erstmal, heute gibt es Preview 2 von CM11.
CM11 PREVIEW 2 is up
WIFI Still doesn't work on Stock CM Kernel. If you wanna try, either use the fix that is lying around or use my temasek cm11 kernel without SELinux.
I'll take a rest for the day.
Later guys
Weiter geht's
PREVIEW - 13 NOV (2nd release)
md5sum: 022b93cf0f02c3ad1866ddcfe551a2f5For those who missed the changelog. Here is a recap.
Instructions:-
1. Use latest Official CWM Recovery 6.0.4.4
2. Boot to recovery
3. If you are from stock sammy, do a FULL WIPE then flash cm11
4. If you are from cm-10.2, just flash cm11
5. Flash correct gapps (you may use my gapps in misc folder or PA GAPPS)
6. Flash temasek cm11 kernel (Recommended)
7. RebootCHANGELOG SINCE 1st PREVIEW
- Most of the ports will now be in "temasek spare parts"
- Status bar clock style from SlimROM
- Network traffic meter
- Brightness control from SlimROM
- Notification background & transparency
- Notification shortcuts
- Low battery warning options
- Screen-On Notification light option
- CRT animation from SlimROM
- cm native crt animation commented out from source - Use Alt default app grid
- Show CPU info
- Restart SystemUI
- Dark UI (TRDS 2.0) from SlimROM
- I will progressively bring TRDS to many parts of the system. - Ensure restart SystemUI will not replace your current wallpaper.
- Screenshot QuickTrash
- .....I forgotten the rest
- Temasek CM11 Bootanimation by @2uk3y
- I will temporary use this till something better comes about
- That doesn't mean I don't like it. Thanks to @2uk3y - Updated cm source
- Revert "vold: mount ext4 with forced SELinux context"
- Added "libhardware: Add ifdef around allocSize"
Some initial ports were from @Cristiano Matos sources so pls give him a hug. I was late in starting cm11
Available for i9300, tilapia & grouper
Enjoy
Schon ist es vorbei mit den Previews, heute gibt es V1.
BUILD - V1
md5sum: 74b7dd2f81edad6f1c433539d6de7edeThis is the first unofficial official build.
You are NO LONGER required to use my temasek cm11 kernel as WIFI/Camera/external sdcard will WORK out of the box without any external fixes or custom kernels.
Instructions:-
2. Boot to recovery
7. RebootFULL CHANGELOG SINCE 1st PREVIEW
- Show CPU info
- Restart SystemUI
- That doesn't mean I don't like it. Thanks to @2uk3y - Custom System Animations by AOKP
- Battery Styles with colors by SlimROM
- Ability to use data over VOICE - Untested
- FIXED - Camera FC on 1st run
- Updated cm source
Available for i9300 (tilapia & grouper coming soon)
Download Sites
http://temasek.hopto.org/ ( i9300 / tilapia )
http://d-h.st/users/temasek ( i9300 / tilapia / grouper )
2uk3y ( i9300 )Enjoy
Und schon gibt es V2.
TEMASEK's CM11 V2
Added QS & QS Ribbons - This is NOT the finalised release. I had to make some adjustments to make it work.
frameworks - "ExternalStorageProvider: Add support for root and external storage" from Omni (xplodwild)
- Comments by xplod "Google decided to only show the emulated (fuse) internal storage in ExternalStorageProvider. This provider is used to display storages in DocumentsUI, the Kitkat file picker, that can be used by apps. It would be a shame if you can't pick the pictures that are on your external SDcard.QuickSettings: Invert long click and click actions - Omni (xplodwild)
Quicksettings: swap the behaviour of the wifi tile.
- onClick on/off
- onLongClick open wifi settingsAdded "Clear all recents" - Bottom left corner
Updated cm source
md5sum: 3689250bc6524d49c04fc4c47581b248
Edit:
Mini-Update für V2.
Zitat -
Und schon gibt es V3
Build V3
md5sum: 1ffc4d885bf427aa578020ebdad9c076CHANGELOG for V3
* This is a clobbered build
* FIXED - SystemUI FC on changing network via QS
* Update all QS drawables to fit KitKat - CM
* Added option to enable/disable QS Ribbons - CM
* Lockscreen: Add timeout and instant lock option to slide lock - Omni
* Add battery level around unlock ring - Omni
* Lockscreen maximized widgets - Omni
* fb: follow new 4.4 transition on center clock and circle battery - SlimROM
* Delete media tests - SlimROM
- Media files take up a lot of spce. Deleting them cuts the size of frameworks
almost in half
* fb: follow on seekbars new UI guideline for 4.4 - SlimROM
- google forgot some things.....seekbar is one example
* fb: Slims navbar and navring customizations - CREDIT: SlimROM
- add back our navbar and navring tweeks. This is a completly overworked
version compared to the one we carry about a year now. Small glitches
we had are now all fixed. As well it does not need to register extra observers
code was much slimmed down and improved.
- Beside that we adapt the 4.4 navbar changes to our system so that it it
consistent with the new 4.4 UIThis patch adds:
- Navbar up to 5 buttons
- navring up to 5 buttons
- dynamic menu behaviour
- landscape navbar options as well now on tablets
- button glow color
- button icon color
- navrign and navbar user can set system or custom icons
- navbar height and width
- enable/disable navbar and navring
- actions are vor navbar and available for the whole system over SlimActions.java
back
custom app or activtiy
home
kill app
last app
notification drawer
ime switcher
power menu
qs pannel
recents screen
screen off
screenshot
search
torch if it is available on the device
- navring has targets for handling vib/mute/sound
- added Color class based on blk_jacks idea which first grey an icon out and then color it. This gives way better results. As well it fits now perfectly with the new 4.4 UI. Put it on a central place so that it is from everywhere available. notification shortcuts adapted to the new class place
- complete new icons thanks to kroz who has redone all for xxhdpi
- our slim special swipe drag drop press longpress options support like on 4.3 this two features
- a lot lot fixes as well on current google code
* Statusbar: Time and Date actions - Omni
- Clicking on the Time will open the alarm
- Clicking on the Date will open the calendar
* Ability to disable hardware keys via nav bar settings - temasek
* fb: correct power menu navring icon - SlimROM
- had a small jump in it when activated
* fb: correct seeker fb style for 4.4 - SlimROM
- the idea was good but bad done. A middle in the night action lol. Problem is that holo light themed app cannot handle the white seekbar of course. So add the complete seekbar into the Holo.Light switch to support both cases
- Holo: white seekbar
- Holo.Light: dark grey seekbar
* i9300: Enable LockScreen Translucent Decor
* smdk-4412 Make 80cfw +x so the script will run - Omni
- This fixes the camera for some people
* Temasek CM11 bootanimation - 1st release - CREDIT: @PartimusPrime
- @noobSU did the liaising part
* Updated cm source
- Except last 3 frameworks/settings commits
- This is due to conflicts resulting in segment failure because of my picks from Omni. I will resolve it by V4
- In the meantime, ALL TRANSLATORS PLS HOLD the translations till after V4 is released.DOWNLOAD SITES
temasek.hopto.org
Dev-Host
AndroidFileHost
MediaFireAvailable for i9300 & tilapia (grouper later tonight).
@noobSU fyna
Enjoy
Schon folgt auch V4.
md5sum: 7410e978764e667e827e065fcbe8061b
Quote:
From this build onwards, you are NO LONGER required to use only latest official CWM. You can use the recovery of your choiceCHANGELOG FOR V4
- Added "MediaScanner behavior on boot"
- Temasek spare parts -> General Settings - Updated - "Add lockscreen ring battery setting"
- moved to Lockscreen Settings - Reverted - "Lockscreen: Add timeout and instant lock option to slide lock"
- not working well - Statusbar reflect am/pm based on the global user settings 12h/24h format - SlimROM
- Fetch navbar color from systemUI - SlimROM
- Updated - Quick settings / Ribbons (Patchset 9)
- Added "Lockscreen - Customizable shortcuts"
- fb: global menu follow new 4.4 UI - SlimROM
- the sound indicator is still ICS blue...change it to white In general we should consider to change all tab_selected files into a Holo.Light switch due it is already defined in styles.xml - fb: change alert dialog to new 4.4 UI - SlimROM
- and add Holo / Holo.Light switch to reflect it proper on the different app styles - fb: do not call every time settings on clock intents - SlimROM
- only needed for configuration change - fb: fix rounding issues and take density into account - SlimROM
- we are a multiDpi rom...and on 4.2 and 4.3 already the text in the circle battery icon was on lower dpi a small bit up. The original author compensated this with just a +1 to the Y value. Thats not the right way...calculate the current dpi into the offset and all is well.
- We want a perfect 4.4...so this nitpicks even if we are talking about 0.5dp maybe should be fixed. - fb: Follow new 4.4 transition on Network Stats - @Cristiano Matos
- fb: Fix in glowpad disapearing targets when longpressed - @Cristiano Matos
- fb: Set persist.sys.dalvik.vm.lib at system server startup - SlimROM
- Bug: 11463182 - fb: Move set of persist.sys.dalvik.vm.lib to SystemServer only
- Bug: 11463182
- Bug: 11479647 - fb: Improve scrolling cache - Pawit Pornkitprasan
- Scrolling cache helps make short scrolls/flings smooth but will cause stutter when long flings are made. This patch disables scrolling cache when long flings are made.
- This patch also fixes a related bug where scrolling cache will not be enabled properly when transitioning from flinging to scrolling.
- Patch Set 2: Calculate threshold based on maximum velocity (Sang Tae Park) - Frameworks: speed up statubar/notification drawer - IceColdJelly
- a lot user complain about slow statusbar pull down introduced with jb 4.2....this speed it up - fb: Fix to NullPointerException when activity is relaunched
- fb: Keyguard: Set WIDGET_CATEGORY_KEYGUARD when AppWidgetHostView is created
- Allows the default lockscreen widget to inherit the keyguard widget host category. Without this, only widgets added through -KeyguardActivityLauncher are assigned the correct OPTION_APPWIDGET_HOST_CATEGORY. - fb: StorageManager: fix android.process.media process stop while plug a discontinuous partitioned SD Card
- While get volume state, throw an IllegalArgumentException, catch this exception in StorageManager and return null to MtpService to avoid process stoping. - fb: Remove possible leak when exception occurred.
- fb: Fix: external storage problem NavRing and NavBar applications - SlimROM
- If the user binds an app which is located on the external sdcard and is rebooting the button icon will be left blank because the navring/navbar is already constructed before the sdcard is mounted. To avoid this we listen to the app available intents.
- If it is not available the ring target/navbar button shows the none icon. When available it shows the correct app icon. So that the user can clearly see
this app is accessable or not. As well when the user goes into mass storage mode or does unmount the sdcard or whatever case could happen that the application is not there. - Updated - QuickSettings: Update all QS drawables to fit KitKat (Patchset
- Updated cm source
DOWNLOAD SITES
temasek.hopto.org
Dev-Host
AndroidFileHost
MediaFireAvailable for i9300 ( tilapia & grouper coming up)
Enjoy
Gestern gab es auch noch 4.1.
md5sum: 681526e9fc73397aee8233ea32980763
- Removed Lockscreen shortcuts (for now)
- other misc stuffs
- fix coloringPls try this build.
Available only ALL 4 sites progressively.
