[COLOR=Blue][size=18]* * * * * * * * * * * * * * * * * * * * * * * * *
Cataclysm Rom for Mako
Android 4.4.2 KitKat
Build: KOT49H
* * * * * * * * * * * * * * * * * * * * * * * * *[/SIZE][/COLOR]
[COLOR=Blue]Ich möchte euch hier eine Rom von Atl4ntis von XDA vorstellen, ziemlich genial...[/COLOR]
Dies ist ein neues Konzept für Roms. Die Stabilität des Google Stock-Roms mit den nützlichen Funktionen und der Power von AOSP. Dies ist meine Vorstellung wie ein Stock-Rom aussehen sollte.
Features:
[COLOR=Blue]Smart Radio:[/COLOR][COLOR=Blue] "Gimme moar juice!"
- Automatically manage your 2g/2g3g connection:
- It auto switch to 2g when 3g is not needed and switches back when needed.
- When 3G is "needed" you can also choose to switch to 2G on screen OFF and back on Screen ON.
- Now it automatically switch on Low Battery and when charging aswell.
- Optional Force 3G Only network mode.
- More features and details here.
InCall Blocker: "This is a phone afterall..."
- You can silently block incoming calls for:
- ALL
- RESTRICTED
- UNKNOWN
- NON CONTACT
- ALL CONTACT
- SINGLE CONTACT
- You can choose Pickup/Hangup mode instead of normal Reject.
- Blocked Calls appear in Call Log.
- White list mode.
- Optional StatusBar Icon, Notification and associated QuickToggle.
- AutoHide your phone number to Non Contacts.
- More details here.
Quick Toggles ™: "The original ones..."
- You can enable/disable/resize/rearrange any toggles, including system and temp ones;
- Optional 4 columns layout;
- You can remove text labels and enable haptic feedback;
- Pull Quick Toggles with just one finger if no ongoing or no clearable notifications, or from left/right.
- Wifi : onClick ON/OFF ; onLongclick wifi settings;
- Bluetooth: onClick ON/OFF ; onLongclick bluetooth settings;
- Mobile Data: onClick ON/OFF ; onLongclick data usage;
- 2G3G: onClick 2G/2G3G ; onLongclick Smart3G settings; Optional Force 3G Only network mode;
- Screen Suspend: onClick alwaysON/OFF ; onLongclick display settings;
- GPS: onClick ON/OFF ; onLongclick location settings;
- NFC: onClick ON/OFF ; onLongclick nfc settings;
- Hot Reboot: onLongClick Hot reboot; (requires SystemUI as root)
- Sync: onClick ON/OFF ; onLongclick sync settings;
- Wifi Hotspot: onClick ON/OFF ; onLongclick Tethering settings;
- Torch: onClick ON/OFF ; onLongclick Brightness popup;
- Rotation Lock; onClick Locked/Unlocked; onLongclick force Landscape/Portrait;
- Force USB Fast Charge;
- ADB over Wi-Fi: onClick ON/OFF ; onLongclick developer options; (requires SystemUI as root)
- Ringer Mode: Silent/Normal/Vibrate;
- Screenshot: onClick Collapse + Screenshot; onLongclick Screenshot;
- InCall Blocker: onClick goes through all the blocking modes; onLongclick InCall Blocker settings;
- Hide NavBar: onClick Hide/Unhide the Navigation Bar;
- USB Tethering: onClick ON/OFF ; onLongclick Tethering settings;
- Volume: onClick Volume slider; onLongclick Volume settings;
- Ime: onClick input method selection;
- System Monitor - Cpu speed/temp - Battery temp;
- Network Speed Monitor;
More Features:
- Softkeys Fade Mod
- Custom Lockscreen Wallpaper (normal/dimmed)
- % Textbattery + Icon / Text Only / Circle battery / Hide
- Nfc polling mode (S-On Locked/S-On Unlocked/S-Off). Disable Nfc sounds (vibrate instead)
- Expandable Volume Overlay + unlink notification volume
- Remember Volume levels when plugging Headset and auto-adjust them
- Navigation Bar resizable (portrait/landscape or portrait only)
- Full screen caller - consistent Answer with SMS
- Custom Lockscreen Targets
- Clear all recents and Sleep Button (longpress for PowerMenu)
- Speaker volume boost
- Keyboard customization (size and rows) (QWERTY only)
- Sim Toolkit (Stk) Compatible
- Volume Rocker Wake (VolUp + VolDown if music is playing)
- Volume Rocker Music Control
- Volume Rocker Cursor Control
- Longpress Back to kill foreground app
- Optional vibration on remote call connect/disconnect
- Mms with Unicode support - Inverted version available
- Longpress Home to app drawer (Currently supports Nova, Holo, Holo HD, Aphex)
- Quick PIN Unlock
- Led notification support for missed calls. Led pulse shortened to 3sec.
- Extended Power Menu
- Expanded Desktop Mode with and without StatusBar
- onClick and onLongClick actions to StatusBar Clock/Date
- H+ UI Support
- Rom settings backup support
- 3G Only network mode
- Go Home after a phone call
- Forces phone to sleep after a missed call
- Announce caller over earphones/headsets (tts).
- Allow only one lockscreen widget to avoid bars/plus/swipe
- National data roaming only
- Lockscreen rotation
- Optional CRT animation - Landscape animation
- Center statusbar clock - AM/PM Style - Disable StatusBar clock
- Longpress recents go to last task
- One click default app picker
- Hide incoming sms/mms text subject/body on statusbar notification
- Start lockscreen widgets maximized
- Disable lockscreen camera
- Disable proximity sensor in call
- Disable Safe Headset volume warning
- Disable beep on volume adjust
- Disable Ime Switcher
- Disable USB Debugging notifications
- Disable GoogleNow swipe gesture
- Deodex, ADB Root, init.d support
- Custom 4.3 Kernel:
- Stock kernel with some useful features, aimed to be stable.
- No SoD or reboots with this one. Source GIT.
- Color Control (Ezekeel)
- Sound Control (Ezekeel)
- Fsync Control (Ezekeel)
- Row i/o sched (Qualcomm)
- Optional WiFi PM Fast
- Fast Charge (Chad Froebel) Toggle / Widget
- Improved Fast Charge (doesn't disable usb mtp) (Joshua Wise)
- Voltage Control (Michael Huang)
- Slightly overclocked GPU
- CIFS
- Compatible with Trickster MOD and PGM
[/COLOR]
Changelog seit letztem Build:
Dec 12, 2013: Sources updated to android-4.4.2_r1. Cataclysm Dec 12, 2013 release.
Dec 12, 2013: Fixed immersive mode confirmation popping sometimes for a moment.
Dec 12, 2013: Added option to show touches while screen recording.
Dec 12, 2013: (Re)Added ability to open AppOps from outside.
Dec 12, 2013: More consistent screen recording notification with dedicated stop button and elapsed time.
Dec 12, 2013: Screen recorder max limit bumped to 30 min.
Dec 12, 2013: Fixed lag when powering off torch after screen timed out.
Dec 12, 2013: More consistent reboot menu / high res clear recents pic.
Dec 12, 2013: Removed force sleep after missed call being obsolete in 4.4.x
Dec 12, 2013: InCallBlocker: fixed pickup/hangup mode showing the call for a moment.
Dec 12, 2013: Fixed Google dialer not showing nearby place pictures.
Dec 06, 2013: Sources updated to android-4.4.1_r1.
Dec 06, 2013: Google dialer: incoming call ui revamped with bigger picture.
Dec 06, 2013: Google dialer: answer with text more consistent.
Dec 06, 2013: Misc: disable fullscreen landscape keyboard, better implementation.
Dec 06, 2013: Fixed bottom portrait keyboard gap on immersive mode.
Dec 06, 2013: Misc: added statusbar brightness control.
Dec 06, 2013: Exposed App Ops in Cataclysm settings.
Dec 06, 2013: Added screen recorder toggle.
Dec 06, 2013: Added delete and share action to screen recorder notification.
Dec 06, 2013: Added screenrecorder service and native lib (0xD34D). Power + volUp to start/stop recording.
Dec 06, 2013: Text inside circle battery is now centered correctly.
Dec 06, 2013: Disabling SmartRadio will reset radio to default power mode.
Dec 06, 2013: Longpress backilling an app will remove it from recents most of the time.
Dec 06, 2013: Disabled internal OTA receiver.
Nov 26, 2013: Fixed recent button lag.
Nov 26, 2013: Clear recents button will place itself correctly with no navbar or when immersive mode is active.
Download Rom:
Cataclysm KitKat release Dez 12 - 2013 @ Dev-Host
Cataclysm KitKat release Dez 12 - 2013 @ Goo.im
[COLOR=Red]Google Apps sind in der Rom enthalten.[/COLOR]
Installation:
[COLOR=Blue]1.[/COLOR] [COLOR=RoyalBlue]Cataclysm.zip auf den Internen Speicher packen.[/COLOR]
[COLOR=blue]2.[/COLOR] [COLOR=RoyalBlue]In das Recovery booten.[/COLOR]
[COLOR=blue]3.[/COLOR] [COLOR=RoyalBlue]Factory Reset durchführen.[/COLOR]
[COLOR=blue]4.[/COLOR] [COLOR=RoyalBlue]Install zip from SD-Card und die Cataclysm.zip auswählen.[/COLOR]
[COLOR=blue]6.[/COLOR] [COLOR=RoyalBlue]Reboot ins System[/COLOR]
[COLOR=SeaGreen]Wer den neuen Google Experience Launcher nutzen möchte, der kann sich die apk hier herunterladen und manuell installieren.
Ich empfehle eine Nutzung der Rom mit dem hells-Core. Eine zusammenarbeit von Rom und Kernel habe ich in dieser Form noch nicht gehabt. Einfach unschlagbar![/COLOR]
[COLOR=Red]Vielen Dank an Atl4ntis für seine Arbeit.
Ich möchte diese nur mit diesem Thread bei uns im deutschen Raum würdigen.[/COLOR]
[size=14]* * * * * * * * * * * * * * * * * * * * * * * * *
XDA-THREAD
