Was ist Viper Audio?
ZitatViPER's Audio is an audio enhancing software to provide everyone with better audio experiences in various platforms such as smartphones and PCs.
ViPER's Audio is founded by Euphy Wong (ViPER520). ViPER's Audio has been a popular audio mod in China. Recently, co-founder Zhu Hang extended the popularity globally through xda-developers forum. It has gained fame and made its stand in the audio mod field.
ViPER's Audio made great improvements in Bass with its dynamic bass system and ViPER Bass. ViPER's Audio also outshines in terms of Clarity with its unique ViPER Clarity and XHiFi technology. Surround sound had never been enough until the presence of field surround, differential surround or haas effect and Virtual Headphone Surround+.
Talking about audio effect, nothing is more significant than convolution. Being the first audio mod to have Convolver makes ViPER's Audio a must for effect lovers. Convolver lets you load technically any impulse response sample you have.
ViPER's Audio is concern with user's auditory health too. Auditory Protection System with the one and only Cure Tech+ reduces your ears' stress and keep you ready for longer duration of pounding musics.
Quelle: Vipersaudio Blog
Was wird benötigt:
- Full Root (no kingo root!)
- busybox
- Passende Viper app -> Download
- neue Musicfx.apk -> Download
- IRS Files (Download und weiteres Thread ende)
Installationsanleitung:
- Wir laden uns die Viper app und die Musicfx.apk runter und schieben es auf den internen speicher des handys.
- mit einen fileexplorer gehen wir nach /system/app/ und entfernen MusicFX.apk und MusicFX.odex
- nun schieben wir die heruntergeladene MusicFX.apk in /system/app/ und setzten die rechte (644)
- Jetzt installieren wir die Viper app ganz normal und befolgen die Anweißung.
- Viper will jetzt einen Treiber installieren wobei er root braucht, welchen ihr nehmt kommt auf euren Geschmack an. Ich habe den mittleren genommen
- Jetzt startet euer Handy neu und die ersten Vorbereitungen sind vollendet.
IRS Installation:
ZitatWas ist IRS?:
IRS steht für Impulse Response Samples.
Wikipedia: Impulse response - Wikipedia, the free encyclopedia
Seit Version FX v2.2.0.2, sind IR samples nicht mehr im WAV Format, sondern .IRS.
Falls ihr IR Samples im WAV Format findet, dann einfach die Dateiendung umbenennen in IRS um sie mit ViPER nutzen zu können.
- Wir laden uns die passende IRS files hier runter -> [V4A][IRS] Impulse Response Sample Index - xda-developers
- oder aus meiner Dropbox habe ich 2 rein gemacht (HTC Beats audio) -> https://www.dropbox.com/sh/f3q9d3njhjrkdk4/FCvbJY_yTq
- jetzt entpacken wir die files und packen die nach /interner speicher/ViPER4Android/Kernel/ -> hier rein
[COLOR=Red](groß klein schreibung beachten | Ist der Ordner nicht vorhanden, selber erstellen)[/COLOR]
Nun aktivieren wir in Viper den experten Modus:
- Menü Taste -> UI Settings -> Expert
- Im Bereich Convolver -> Impulse Response könnt ihr die für euch beste IRS auswählen.
Vieles müsst ihr selber testen, nicht jeder hat den gleichen Geschmack und Ohren!
Wie findet man heraus ob die Viper App mit XXX Musik player funktioniert?
- Ganz einfach ihr startet eure Lieblingsmusik app und lasst ein lied laufen.
- Nun öffnet Viper und drückt die Menü Taste -> Driver Status
- Wenn bei Processing: No steht wird die App leider nicht unterstützt, bei Yes logischerweiße schon.
Folgende Apps laufen [COLOR=Red]NICHT[/COLOR] mit Viper
- Stock Musik Player
- Stock Video Player
Empfohlene Player:
- PowerAMP (30tage free, kostet leider was)
- MX Video Player
Natürlich könnt ihr nicht Erwarten das sich die Qualität wie aus einer Stereo Anlage steigert! Mit der App kann man aber definitiv besseren Sound rausholen. Somit finde ich die Lautsprecher des Note 3 gar nicht mehr so schlecht.
Danke an zhuhang @xda für den Mod
