[4.4.4] SlimKat [hammerhead][stable 9.0][weekly 8.20]
Download Weekly 4.2
SlimRecents fix 50ms unresponsiveness
Chamber of Secrets string edit
Chamber of Secrets add global database
Fix slow start for settigns/sound
Fix avrcp absolute volume
Do not show Home behind full screen activity
Fix Airplane mode on/off
Parallel shutdown
Great deal of fixes and optimizations for frameworks base
TWRP updated to 7.0+ (for devices with recovery in boot.zip)
Update busybox
Some updates to hardware_qcom_audio-caf
Some updates to frameworks_av
Device specifc
Mako/Geeb: Update kernel to 3.4.85 and some code fixes
Hammerhead: Massive kernel changes for video handling
Honami: Merge sony 4.4 source (we are now CAF)
Yuga: Updates to kernel
D2/JF starting unified builds
I9300/T0lte: Audio changes on rom side
G2: Major kernel changes
Changelog zur 4.4
- Frameworks: Allow Power Notification Sounds for Wireless
- Frameworks: navigation bar IME cursor control
- Frameworks: SlimRecents: Make expanded layout pretty
- Frameworks: SlimRecents: user configurable default expanded mode
- Frameworks: SlimRecents pass gesture detector to the cardslistview
- Frameworks: Don't recreate controllers.
- Cardslib: CardsListView allow to touchevents from swipetodismiss for gesture
- Cardslib: do not pass trough touch event to gesture listener during swipe
- Qcom power: Skip build if perf enabled
- Qcom power: Option for disabling input boost
- Qcom power: Make NO_TOUCH_BOOST the default
- Qcom power: This HAL is only for Google devices
- Qcom power: Additional guards
- Qcom power: Deal with TARGET_POWERHAL_VARIANT
- OpemSSL: Add heartbeat extension bounds check.
- Frameworks av/media/audio/display for caf variants got major CAF upstream
- A lot device specific kernel and device tree changes (see changelogs shipped with the builds)
- Translations
Läuft super
Was genau hat sich an den recents verändert
sent from Nexus 5 with SlimKat
Könnte vielleicht nen Mod den Titel hier mal anpassen
Ist das so i.O.?
Ja danke
Wie kann man bei der slim die Pfeiltasten während die Tastatur offen ist, entfernen? Ich meine das ist erst seit der letzten weekly
Ich hab sie mir grad mal als 2. ROM geflasht aber ich habe auch nichts gefunden um es zu deaktivieren, ich finde die Pfeile aber nicht so schlecht
Schlecht sind sie nicht, aber optisch find ich es störend, da ich sie eh nicht nutze^^
Meiner Meinung nach wäre es schön wenn man sie deaktivieren könnte.
Sieht zwar ganz gut aus aber da sie keinen Nutzen haben wäre eine Deaktivierung toll. -
es gibt eine neue experimental und neue gapps.
http://www.slimroms.net/index.php/down…/979-hammerhead
Changelog 4.6 und wichtige Hinweise
General notes:
If you want to clean flash. Just follow the usual clean flash instructionshereDirty flashers do the following: Format system manually....flash SlimKat build, flash new gapps and boot up.If you did not update the gapps which were published during the week the notes here are still validPhotosphere addon package was dropped now. The new google camera is available over the PlayStore as replacement and can be installed as second camera without problems.Device specific notes:
i9300 and t0lte got major camera driver changes. Initial tests seems to work well for us. We need now a wider test. So do a backup of the prior install, install the new build and let us know if it is working better then beforem7att, m7tmo and m7ul are unified now and for all this devices you just need to download the m7 build. m7spr and m7vzw will stay like it was.Changelog:
Framework: Shake to Temporarily Secure && FixesFramework: SystemUI: Custom Tile - add Global && Create Small APIFramework: Revert "SystemUI: Remove broadcast from QH toggles"Framework: Revert "Base: Check ProcessesReady before broadcast"Framework: Revert "Insufficient ProcessRecord cleanup when persistent process is killed"Framework: SlimRecents: fix sometimes missing first taskFrameworks: apple can do...we can do as wellVendor: Add Hondura Tigo apnVendor: Fix APN typoVendor: apns: Add type default for Sprint.Frameworks (caf): Make the default value of in-call noise suppression configurable.Frameworks (caf): Call setDirtyRect to update dirty rectangleFrameworks (caf): Display: Dirty region propagationFrameworks (caf): Fix the value type of def_noise_suppressionVendor LGE: Revert "hammerhead: change gps blobs"Telephony: Implement SIM card managementArt: Avoid unnecessary copy of dex_gc_map.Tons of device specific upstream and fixesTons of kernel ehancements.Gapps update (more google camera compatibility fixes, new YouTube)
4.6 ist online
Download Weekly 4.2 -
Hallo zusammen, wie kann ich die Dpi wieder auf Originalwerke setzen? Wie ist eigentlich der Originalwert?
gesendet von meinem Nexus 5 mit Tapatalk Pro
mit dieser App:https://play.google.com/store/apps/det….texdroider_dpi
die Original Dpi müsste 460 oder 480 sein.
Kann aber sein das es dann Probleme gibt,weil die Rom ist ja auf 370 ausgelegt,habe es aber selber noch nicht gemacht.
480 ist der Stock Wert.
Läuft mit dem Stockwert von 480 einwandfrei! Prima!!
seit ihr alle blind?
ich schraub bei jeder CR die DPI auf 380 runter
