[ROM] Nexus 5 Purity
  • http://htcfanboys.com/download/Dario…st&folder=18975
    ♦ PURITY ROM ♦ 21/07
    Updated code to 4.4.4_r2
    Device_lge_hammerhead:
    - hammerhead: Use less aggressive mount options
    Frameworks_base:
    - Added Power button to available NavigationBar buttons …
    - Update SahlNaskh font …
    - frameworks: move safe volume warning above expanded volume panel …
    - AudioService: Show safe volume panel for non-interactive volume adjus… …
    - NavRing: Last App …
    - Missed translations..
    - QS: Make CameraTile respect locale changes for the label. …
    - base: update link ring-notifications after read user settings …
    - Update home process when home activity resumed …
    - Do not finish root activity when reset task …
    - Move top task to top in window manager …
    - Prevent potential deadlock from system error dialog… …
    - Avoid keeping restarting home when only home activi… …
    - Prevent kill a restarted process again. …
    - Ensure alive process is not killedByAm. …
    - Revert "hwui: Always enable the scissor while composing layer" …
    - SystemUI: fix double tap to sleep not working with secure lock screen …
    - HeadsUp: Fix dismiss on back key press. …
    - HeadsUp: Only remove heads up if attached to window …
    - Fully fix interaction between torch and camera usage. …
    - add framework torch service …
    - frameworks/base: Fix binder parcel leak with getMetadata() API …
    - KeyChain: add explicit package for getPrivateKey. …
    - Fix crash in widget pager - DO NOT MERGE
    Kernel_lge_hammerhead:
    - msm: Improve qpnp-vibrator scheduling
    Settings:
    - Settings : Add tap/pay help url
    Vendor_purity:
    - Fix Mobistar APN settings …
    - apns-conf: Update TMO HR APN
    Nexus 5 - Purity - Linaro
    7 Mal editiert, zuletzt von razooor (21. Juli 2014 um 15:57)
  • ♦ PURITY ROM ♦ 7/08
    Frameworks_base:
    - frameworks/base: Fix the random UI corruption …
    - Mark constructor as accessible in LayoutInflater. …
    - Revert "audio: Inform audio HAL if it is a voice call initiated by Te…
    - SwipeHelper: Ignore ACTION_OUTSIDE touches …
    - improving translation …
    - Don't unnecessarily set LayoutParams on children …
    - Prevent a duplicated registration of Observers …
    - Remove java.io.tmpdir assignment in AndroidRuntime. …
    - Fixed a possible infinite loop in JsonReader#skipValue() …
    - AssetManager cookies should be int32_t and not void*. …
    - Remove unused field from AssetManager. …
    - Before requerying a cursor, check if it is closed. …
    - Cursor leakage due to cancellation signal …
    - UsbDebuggingManager: Fix multiple NPEs toggling USB debugging …
    - fix possible buffer overrun and memory leak …
    - Memory leak: parseObbFile.footer …
    - NPE in SearchManager.triggerSearch …
    - Fix appwidgets not updating …
    - Use java.util.Objects instead on internal API …
    - SystemUI: Add missing recycle calls …
    - inputdevices: update from aosp (master) …
    - improve rotation handling …
    - Fix NullPointerException in ListView …
    - Fix a bug that the RecentTask list of other’s may show up to non-prim… …
    - DocumentsUI: fix recursive delete …
    - [View] Clear Hardware-Layers before system destroys HardwareRenderer. …
    - Skip broadcasting to a receiver if the receiver seems to be dead …
    - [Bitmap] Add null pointer protection in Bitmap_sameAs() …
    - [ActivityManager] Prevent coredump file may not complete for testing. …
    - [ActivityManager] Avoid mistaking visibility by finishing task. …
    - NavTargets : Show highlight for google search …
    - ChooseTypeAndAccountActivity: Fix the Null pointer Exception of monke… …
    - DialogFragement: Add null pointer check for mDialog for protection …
    - QuickSettings : Register/unregister cast tile one time …
    - [Asset Manager] Fix memory leakage bug …
    - IndexOutOfBoundsException observed in ProcessStats …
    - Restore untrusted glStencilMask value on resume after functor …
    - [HWUI] Fix invisible views are still shown in popup window …
    - [HWUI]: fix residual line on FrameBuffer
    Libcore:
    - Add API to check certificate chain signatures
    Settings:
    - Use java.util.Objects instead of internal API
    - Settings : Dismiss glowpad view on trigger
    Vendor_purity:
    - Add China Telecom apns …
    - [PATCH] apn: fix typo on SKT LTE mmsc address
    Edit: thread ist ja schon angepasst :D
    Nexus 5 - Purity - Code_Blue
  • ...da scheint ja ne neue Purity seit gestern raus zu sein... Und keiner hat's gemerkt.
    OP ist schon lange geändert....
    Schade. Ich habe jetzt die LiquidBlood drauf... Und die läuft leider Höllen mäßig gut [emoji6]
