[ROM] Nexus 5 Purity
  • Erste offizielle Purity auf 5.1 erhältlich
    https://plus.google.com/10465223212761…sts/2m8NRmP7fcB
    FEATURES
    - Aosp Android Lollipop 5.1
    - Art - Bionic tweaked
    - Rro & layers support
    - Lookup settings
    - Notifications Tile
    - Silent Mode
    - Navbar rings
    - Privacy Guard
    - Qs long click support
    - Quick Unlock
    - Navbar customization (power menu in navbar included)
    - Power menu customization
    - longpress recent switch to last app
    - Killed orange bars in battery saver mode
    - Statusbar brightness
    - Power notification settings
    - Disable QS on secure lockscreen
    - Data Roaming settings
    - Battery icon options
    - Volume key music controls
    - Volume wake
    - Close all button location
    - QS pulldown
    - Notification - battery lights
    - Optimized png
    - Per app controls for LP keyguard notifications
    - Advanced Reboot Menu
    - Double tap to sleep
    - Clock & Data customizations
    - Volume adjust sound
    - Display rotation
    - Clock & Time clickable in statusbar
    - IME selector notification toggle
    - Long press back kill app
    - Volume media controls
    - Expanded Desktop
    - Lockscreen shortcuts
    - Safe headset volume
    - Screenshots quick delete action
  • Zitat
    Coming soon to Purity U2D, with a major overhaul ;)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
  • noch der Changelog
    Download
  • Und jetzt offiziell...
    New build released!
    http://htcfanboys.com/download/Dario…st&folder=80931
    Purity - 23/05
    Updated source code to 5.1.1_r3
    - Art:
    Revert ART: prevent patchoat from symlinking with dummy files …
    Revert ART: patchoat gets gzip support for compressed odex files
    - Build:
    Revert build: Add option to compress precompiled odex with gzip
    - Device_lge_hammerhead:
    hammerhead: Give unpriviledged users write perms to USB storage …
    hammerhead: Fix apps2d to usb storage
    - Device_moto_Shamu:
    motorola-shamu: Use new 3gb dalvik heap and hwui …
    Enable USB OTG Shamu
    - Frameworks_base:
    Fix typo
    Allow prevention of doze notification color inversion Doze 2.1 for …
    Re-add missing ellipsis string …
    SystemServer: Skip TorchService construction if no flash feature dete… …
    Fix another off-by-one error in computeEllipsis …
    SystemUI: improve dpad arrow key state logic …
    Fix bugs regarding delay the dispatching of non-wakeup alarms …
    Fix for infinite loop in RemoteViewsAdapter …
    Fix bug of unnecessary wakeups after completed syncs. …
    Remove the window whose client process has died or become zombie …
    Don't relayout based on a window that isn't visible …
    Fix racing condition of mTouchExcludeRegion …
    Measure absolute value of pointer motion distance …
    Adjust display inversion matrix to account for luminance …
    fix return value scale of notifyANR() …
    Frameworks/base: Fix old code in MediaPlayer …
    Frameworks/base: Fix null-pointer access …
    base: Nat464: unregister network observer when we stop! …
    Context leaks in EditText causes out of memory …
    Remove some useless debug spam. …
    Fix lost singleton provider after force-stopping user or package. …
    Don't apply animation clip to dialog activities …
    Use the correct parent size to initialize animations …
    Framework: StatusBar Ticker (1/2) …
    Fix typo in Spanish AOSP translation …
    (1/2) Battery: add dotted circle variant …
    Mobile data tile: open network settings …
    base: kill some log spam …
    Improve Recents-View …
    Fix navbar on tablets
    Fix no vibration during shutdown. …
    optimize wallpaper load,avoid show black wallpaper. …
    Torch: remind user flashlight is still on …
    Unset frame listener before tearing down GLThreadManager. …
    TorchService: improve state management …
    Re-add dump() method to TorchService.
    - Frameworks_native:
    Revert installd: Add gzipped odex support
    Add 3GB dalvik heap and hwui memory
    - Settings:
    Update: Ita translations
    Update: Hr translations
    Settings: Update sync widget state …
    Used fixed size for app icon width in default sms dialog …
    Settings: StatusBar Ticker (2/2) …
    (2/2) Battery: add dotted circle variant …
    Add Europe/Istanbul timezone …
    Add Europe/Madrid. …
    Add Pacific/Noumea. …
    Settings: Fix wifi developer options summaries
    - Vendor_purity:
    APNs: 716: added Claro, Entel; 732: Fixed COMCEL …
    APNs: Add MVNO HoT Austria Internet and MMS APN configuration …
    APNs: moar MVNO's …
    APNs: Separate Simyo ES' entry (default and mms) …
    apns: Added APN configuration for Suop MVNO (Spain) …
    Added several APNs, updated a couple carrier names …
    Split Smartfren MMS out …
    Add authentication parameters to MVNO NL APN configuration …
    Updated Telekom RO APN to reflect their recent name change …
    Added APN for Costa Rica ICE Kolbi …
    Removed obsolete internet APN for Indosat …
    Fix typo and build …
    Fixed typo in APN config for Nicaraguan networks. …
    Added Eagle Mobile MMS apn configuration. …
    apns-conf.xml: (DK) merge BiBob and Telenor APNs. remove mvno values. …
    Update Smartfren APN protocol to IPV4V6 …
    Update APNs for Smartfren
  • Neues Build ist verfügbar
    New build online! If you like my work, support me ;)
    PayPal: ferrettipasquale@gmail.com(friends/family option)
    http://htcfanboys.com/download/Dario…_2015-08-05.zip
    Purity 05/6
    Revert to 5.1.1_r5 code
    Bionic:
    Restored bionic tweaks lost in the previous merge
    Frameworks_av:
    MPEG4Extractor: one more null check in MPEG4Source:[emoji14]arseChunk …
    Guard against codecinfo overflow …
    Prevent reading past the end of the buffer in 3GPP …
    Prevent integer underflow if size is below 6 …
    Fix integer overflow when handling MPEG4 tx3g atom …
    Fix integer underflow in covr MPEG4 processing …
    Prevent integer overflow when processing covr MPEG4 atoms
    Frameworks_base:
    autobrightness: Fix the brightness dialog is not work when first enab… …
    frameworks: display: shorten automatic brightness debounce …
    Increase brightness faster if ambient light is brightening quickly. …
    SystemUI: Crash fix from bad camera values. …
    Guard in short-circuit evaluations for stringSplit methods. …
    base: check nullability of ConnectivityManager#getNetworkCapabilities() …
    animateNoDamage failed to remove from current frame list …
    hwui: add extension to support unpack operations in OpenGL ES 2.0 …
    It: update
    Hr: update
    [1/2] base: storage notification enhancement …
    frameworks/base: Fix USB media removed notification to be dismissable …
    Revert "Make "SD Card removed" notification dismissible if the remove… …
    Add icons to battery saver notification (dismiss & turn off) …
    base: Battery saver enhancements …
    Frameworks_webview:
    Update to 44.0.2403.90
    Settings:
    It: update
    Hr: update
    [2/2] Settings: storage notification enhancement …
    Settings: add Kiev time zones to picker …
    Remove hardcoded textAppearance for better theme support. …
    Update iconography to VectorDrawable and adjust coloring.
    Vendor_purity:
    apns: zero-length items are evil and break auto-selection …
    Clean up MEO/TMN APNs …
    Remove 'preferred' no-op …
    Update APN for China Telecom …
    Fix Rogers APN …
    APN fine tuning …
    rendang: Remove unwanted APNs
    Gesendet von meinem Nexus 6
  • Und weiter geht's!!
    http://htcfanboys.com/download/Dario…_2015-08-06.zip
    Purity 06/6
    Updated sources to 5.1.1_r9 code
    Build:
    Build Browser2 & BookmarkProvider (Built for testing, you can disable-remove it)
    definitions.mk: look for definitions.mk in device/*/build also
    hammerhead: Fix typo
    DownloadProvider:
    DownloadManager : Only remove stale id if download is not deleted
    External_jpeg:
    Enable neon optimization for 32bits.
    Frameworks_base:
    Add support for QC's time_daemon …
    Fix NPE in NetdResponseCode.InterfaceClassActivity
    ProcessList: revert to aosp state
    RRO: idmap: fix sorting of overlays.list
    InCallUI:
    InCallUI: Unbreak heads-up disabled incoming call.
    Settings:
    Remove duplicate import[/SPOILER
