Changes between 6.57.9 and 6.57.5
Fixes
-Fix Free Browse mode
http://d-h.st/users/rootsu/?fld_id=34576#files
THL T6S MT6582 1.3GHZ Quad Core 5.0 Zoll IPS Bildschirm Android 4.4 3G Smartphone
Fixes
ZitatAlles anzeigen
Seems many are hammering and crying in their support threads about updates
[COLOR=#ff0000]To make it clear, I added announcement to head of OP: "End Of Support"
I also update project status: No Longer Updated[/COLOR]As I mentioned before, I have a lot of new important projects in my real life. I am very happy to abandon this project for real life alternatives.
CWM is a dead project for now, until some dev resurrects it. I was about to do, until these new projects came.Current version will probably work a while for many devices. Some devices with new ROM installers could have issues. Just use TWRP or the CM Simple Recovery
If the current version works for you, there is no reason you don't use it though. No need to bitch in all threads because it doesn't work for you. Just move on to other alternatives.
ungültiger Link
Na l toll. Dann war das ein Wink des Schicksals, dass ich die Liquid T-Rex gestern nur mit Twrp installiert bekam...
Wie angekündigt ist nun auch der xda Thread zu diesem Recovery dicht.
[COLOR=#404040]R.I.P[/COLOR]
Project Status: No Longer Updated[/COLOR]As I mentioned before, I have a lot of new important projects in my real life. I am very happy to abandon this project for real life alternatives.
TWRP Materialised for Nexus 4
