  • [COLOR=#0000ff]++++++++++UPDATE++++++++++
    http://www26.zippyshare.com/v/3358789/file.html
    [/COLOR]
    [COLOR=#000000]Changelog 15.05.2014[/COLOR]
    [COLOR=#0000ff]android framework base[/COLOR]
    [COLOR=#000000]-AudioService: fix safe volume enforced even when disabled
    -Set ActionMode title to the number of selected files
    -Avoid SystemUI crash due to NPE
    -Revert "telephony: set additional audioparameters for incall audio (1/2)"
    -Allow 3 AT (mnc05) to roam on T-Mobile in Austria
    -FWBase - Floating Window: Welcome back
    -FWBase - Launch floating notifications from notification panel (long click)
    -Revert "Download: add to support pause/resume download by manual"
    -FWBase - Recents: Launch as Floating App
    -FWBase - Add to support pause/resume download [1/2]
    -FWBase - Fix for launch app in floating mode from recents
    -Add Missing Drawables
    -FWBase - Fixed lockscreen long press actions.
    -FWBase - Kill floating activities running in the same thread when tapping outside
    -National Roaming: Allow T-Mobile AT (MNC03) to roam on 3 AT (MNC10) in Austria
    -CM11 Themes: remove handleThemeConfigChanges[/COLOR]
    [COLOR=#0000ff]android packages apps setting[/COLOR]
    [COLOR=#000000]-make LinearColorBar themeable
    -Fix NullPointerException issue when user change
    -Move Multi Sim settings above other settings
    -Revert "Add new themes items to personalization menu"
    -Add new themes items to personalization menu
    -Add missing mdpi, hdpi, xhdpi drawables for new theme engine[/COLOR]
    [COLOR=#0000ff]android[/COLOR]
    [COLOR=#000000]-Manifest - Use AOSPA DownloadProvider instead of CM
    ...und vieles mehr...
    [/COLOR]
    [size=10]Device- [color=#660000]Nexus 6;[/COLOR][/SIZE]
    [size=12][COLOR=#4d4dff]GZR- Tesla[/COLOR][/SIZE]
  • ...o.k.....versucht...:D
    Aber im Erst: Was da alles in den Tiefen der Rom passiert, ist für mich als Dummen User eh nicht wirklich interessant...weil einfach nicht nachvollziehbar.
    Wichtig für mich/uns als Anwender ist: Was hat sich spürbar verändert, welche praxisrelevanten Features sind dazugekommen/wurden verändert.
    Vielleicht gibt´s für Euch ja eine Möglichkeit -ohne großen Aufwand- das an den Changelog anzuflicken:D
  • Bonjour
    Brauch Euren fachmännischen Rat.Probleme mit der Bluetooth Verbindung. Genauer.Bluetooth. com Prozess wird beendet. Wenn ich das pairing Gerät ausschalte und wieder einschalten.Irgendwie glaube ich merkt sich das Rom nicht den Pairing Code. Um sich automatisch mit Autoradio zu verbinden.
    Muss nach jeden ausschalten neuen Pairing Code eingeben. Um Bluetooth Verbindung herstellen zu können .Sehr unpraktikabel.Hoffe jemand kann mir weiterhelfen.
    Nexus5
    Nexus7/tilapia
    GT-N7000
    credendo vides y buena suerte para siempre
    Pixel 3 XL 64GB/crosshatch
    N6/64GB/ shamu
    Credendo vides y buena suerte
  • Habe zwar kein auto radio mit Bluetooth, aber mit meinem Headset keine Probleme mit Bluetooth. Versuche doch mal die Daten der Bluetooth Freigabe zu löschen, vllt hilft es ja ;)...
    Отправленно с моего Nexus 5
    Rom: GZR - Tesla
  • Bei mir läuft das letzte Update nicht. Es wird angezeigt: der Prozess wurde beendet ... Systemui ...
    Habe Rom und Gapps zweimal geladen und zwei mal installiert. Leider ohne Erfolg.
    Hilft wohl wieder mal nur der Holzhammer ;)...
    Rom: GZR - Tesla
  • Ich habe heute den ganzen Tag, mein Handy mit dem Bluetooth auto radio verbunden gehabt. Keine Probleme gehabt!! Hebe doch mal das Paring auf und Koppel es neu mit deinem radio!!!
  • Was ist mit dem Daten Anzeige Dings los? Mir fällt gerade der Name nicht ein. :D Alles neu aufgesetzt. Der Rest läuft soweit super! Top Arbeit Team Rex! :)
  • Egal was ich auch versuche.Für einen kurzen Moment verbindet sich das N5 mit dem Pairing Gerät. Musik etc.wird über tragen. Doch dann taucht nach zwei bis drei Sekunden das pop up Fenster auf der Prozess Bluetooth.com /Bluetooth Freigabe wurde beendet.Wenn ich dann auf OK clicke schaltet sich Bluetooth vom N5 aus.Und das wars dann mit dem pairing. Beim Note 1 mit Custom Rom keine Probleme .Bin ehrlich gerade ziemlich ratlos.
    Nexus5
    Nexus7/tilapia
    GT-N7000
    N6/64GB/ shamu
  • @alle Devs , erstmal noch einmal möchte ich mich Entschuldigen mit dem update post!! Sorry!!! Und einmal mehr muss ich sagen ,das eure ROM, top ist für das N5!;!Danke für euren support!!!
