so hier ist jetzt auch der Changelog vom letzten Update ![]()
 ZitatAlles anzeigen
09.05.2014
CM's new theme chooser
-PA's Peek with configurable wakelock time-out
-Live Volume Steps
-Battery Saver: Removed all option that didnt work properly
-Move keyguard wallpaper to system
-Quiet Hours: Add 4 state (off, timed inactive, timed active and forced on)
-Quiet hours: Option to disable system sounds
-Quicksettings: Update sleep tile and immersive mode drawables
-QuickSettings : Add BatterySaver Tile
-Option to allow a (subtle) notification vibration during calls
-Power menu Mobile data toggle
-Battery Bar
-Trebuchet launcher from CM, removed Launcher3 (Themed thanks to @snak3ater)
-Removed cm file manager
-TRDS for Dialer Settings thanks to @rush25
-Theme Browser Quick Controls thanks to @rush25
-Merged CM's new Torch app
-Settings has had a lot of improvements and fixes (too many to list)
-Lots more, read the detailed changelog-Lots of translation updates for Hungarian, German, Greek, Italian, Russian and Spanish languages
(thanks to @c@p, @senses!, @seilogeo, @toyr99, @Pixelase and @klasszsrac)*Clean flash is recommended, if you have any problems after dirty flashing make your to clean flash before reporting any bugs.
