[ROM CM/MIUI] Weekly 3.2.22 .Multi 4.1.2 SGS by lucainno (4.2.1 JB | JOP40D)
  • [COLOR=#ff0000]Ich, Android-Port.de oder die Entwickler/Publisher der ROM oder Mods,
    [/COLOR]
    [COLOR=#ff0000]übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
    [/COLOR]
    [COLOR=#ff0000]
    [/COLOR]
    [COLOR=#ff0000]Ihr seid daher für euer Handeln selbst verantwortlich!!!
    [/COLOR]
    Original Port & Support by lucainno / xda
    [size=12]Dieses MIUI Mod basiert auf[/SIZE]
    • PLEASE NO REQUEST, NO ETA ONLY BUGS REPORTS THANKS
      MIUI.JB.I9000-3.1.25.Multi
      This is a porting of miui.ns.multi.3.1.25 android 4.1.2
      If you have the galaxy SII I9100 and Galaxy SIII I9300 be go here
      for download ROM for SGSII
    [size=12]Installationshinweis & Download[/SIZE]
    [size=12]Features & Change Log[/SIZE]
    • Post 2
    [size=36]
    [size=12]CREDITS:[/SIZE][/SIZE]
    • MIUI Italia
      miuiandroid.com
      Rtfpessosa For your script
      Stratosk (For Semaphore Kernel)
      kasper_h (For Mackay Kernel)
      Teamhacksung
    [size=12]Thanks for support[/SIZE]
  • Installationshinweis & Downloads
    [size=12]INSTALLATION
    [/SIZE]
    • INSTALLATION JB
      Raccomended for Stability: a full: wipe data, cache and
      dalvikcache, format system and cache, data and datadata
      Instal kernel devil 1.6.0 and reboot recovery If have old miui
      installed(If you have installed CM10 new partition layout installs directly with
      wipe)
      wipe data factory reset, cache and
      dalvikcache
      in mount and storage format system and cache
      install
      Reboot phone wait a minutes
      Reboot
      if have problem go in recovery (wipe data factory reset, wipe cache partition and wipe dalvikcache)
      reboot
      INSTALLATION LANGUAGE PACK AND FIX:
      Download and copy zip from sd card internal
      Go recovery CWM or enter whit (VolumeUp+Home+Power)
      Chose zip from sdcard
      Instal zip from sdcard
      reboot
      INSTALLATION FROM GALAXY S ROM STOCK & INSTALLATION - CM7 OR ANY ROM ICS
      INSTALLATION FROM GALAXY S ROM STOCK:
      Root your device and install ClockworkMod Recovery
      Or Using ODIN flash CF-Root for you firmware.
      Reboot into Recovery using 3-button-combo (VolumeUp+Home+Power)
      Do a Nandroid Backup or your choice backup application
      wipe data factory reset, wipe cache partition and dalvikcache
      Install ROM from internal sdcard
      It will restart and continue looping – remove battery
      Go back to recovery (VolumeUp+Home+Power)
      Install rom from internal sdcard
      reboot
      Finish
      INSTALLATION - CM7 OR ANY ROM ICS :
      Copy the rom on internal sdcard
      do all wipe (wipe data factory reset, wipe cache partiotion, wipe dalvikcacke)
      Go on install zip from sdcard
      Select the zip and install
      Reboot and wait a few minutes
      reboot
      You have finished
    [size=12]Downloads
    Rom[/SIZE]
    2 Mal editiert, zuletzt von Maestro2k5 (24. April 2015 um 23:22)
  • Features & Change Log
    [size=12]CHANGES :[/SIZE]
    • Kernel Mackay 0.175 BLN
      update miui 3.1.25
      Script Tweaks
      Added MultiLanguage
      4 way reboot
      Aggiunti apn
      Added (Flash Player, Titanium Backup)
      Added Miui Keyboard
      Added Kies AIR
      Added Notification Weather
    [size=12]CHANGELOG MIUI:[/SIZE]
    [size=12]WHAT WORKING[/SIZE]
    • Phone Calls
      SMS
      Audio
      Camera, Video and photo
      GPS
      Vibration
      Touchscreen
      Bluetooth
      USB Mass Storage (Internal and ext)
      WiFi Tethering
      Contact sync
      gmail sync
      Calendar sync
    [size=12]WHAT DOESN'T WORK:[/SIZE]
    • Report bugs please
    Einmal editiert, zuletzt von Maestro2k5 (21. April 2015 um 14:25)
  • Habe dieses Mod schon länger selbst nicht mehr drauf gehabt um es beurteilen zu können!
  • Ich habe den Port seit gestern drauf mit sauberem Flashing Stockrom--Root---Miui
    Bis jetzt einwandfrei und ohne Ruckler.
    Nur mein DX Battery Saver lässt sich nicht als Widget ablegen, wird in der Widgetliste gar nicht angezeigt, ganz seltsam
    Dann noch Whatsapp, hat auch erst rumgezickt, keine Verifizierung möglich, musste dann den Code eintippen, den die Ansage bereit hielt.
    Ansonsten nix zu meckern.
    Das war aber bist jetzt bei allem Miui so, anfänglich erste Sahne und nach ein paar Tagen extrem laggy, da hat das i9000 wohl doch zu wenig RAM.
    Mal abwarten, ob das bei der hier auch auftritt.
    Edit:
    Geht schon los, nur noch 9mb RAM frei ?(
    Fängt an zu ruckeln, einige Apps öffnen sich nicht mehr, irgendwie kommt mein sgs nicht mit Miui klar.
    Wird Zeit, dass mein Xiaomi Mi2 ankommt.
