[KERNEL] ElementalX 4.00 Lollipop
  • Small update for Android L preview (Android 5.0). Chainfire's root fix is included now, you should be able to flash over stock kernel. It works fine for me. I reverted a couple things that might have been interfering with root before. If it doesn't work for you, you'll have to install the permissive kernel first.
    [SIZE="5"]
    Android L:
    ElementalX-N5-2.01
    [/SIZE]
    Changes:
    -revert F2FS updates
    -revert app mounting tweak
    -update ramdisk
    Nexus 5 - Purity - hellscore
  • Wir sind mittlerweile bei Versionsnummer 2.03 angekommen.
    Seit der Version 2.0 wird der Kernel ausschließlich für Android Lollipop angeboten.
    Ich werde den Thread morgen Updates bzw die KitKat Kernel entfernen.
  • Update
  • "Heimliches Update" :P vom 28 Jan...
    [size=18]ElementalX-N5-2.06.zip[/SIZE]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
  • psssst ...
    :speechless: :X3:
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Update!!!
    mpdecision is default, but you can choose custom hotplugging during installation. I will add full options to the EX app next update.
    Wake gestures are back, later tonight I will release a new app based on the xposed module by @C3C076. I made a few small adjustments to the kernel to work better with wake gestures.
    I've also removed /etc/init.d/99elementalx. There is now a script added to the ramdisk to apply the settings. Let me know if this works better with the latest SuperSU.
    Also fixed a problem where the express version wasn't copying thermal conf
    Download:
    ElementalX-N5-2.07
    -remove haptic feedback when wake_gestures enabled
    -increase wake_timeout screen on duration
    -update installer
    -add hotplugging options to installer
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Update auf 2.08 - Bitte den Aroma Installer nutzen. siehe Beschreibung von flar2
  • Update 2.09 u.a. mit XPrivacy Support
  • 2.10 Update.
    Fix the fastcharge setting not being applied and updated the advanced color control.
    Look for a big update to the ElementalX app tomorrow.
    Download:
    ElementalX-N5-2.10[/urll]
    Changes:
    -fix fastcharge setting in installer
    -update advanced color control
  • ElementalX 2.11 online...
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
