Es ist selten das ich mal auf einer Version hängen bleibe, aber 398 ist echt top.
Dem kann ich nur zustimmen
Der 398 in Verbindung mit dem DU ist Performant und gleichzeitig noch Akku schonend.
Code_Blue r414
- blu_plug: use input boost, __ref to lighten the driver, rework input touch boost, minor fixes
- ARM: fix user unalignment prefetch abort, add seccomp syscall
- ARM: gic: Bring inline with upstream, use a private mapping for CPU target interfaces
- ARM: bitops: prefetch the destination word for write prior to strex
- arm: hammerhead: gpiomux: Pull down the UART suspend gpio
- ARM: dts: msm: i2c: change clock rate to 19.2 MHz
- qup_i2c: Initialize I2C resource before registering, Fix for unhandled IRQ, export qup_i2c_init_driver, Improve implementation of PM callbacks, Handle scenario if runtime PM is disable, Verify that mem resource exists prior to redirection
- cpuidle: check for need_resched() after the idle entry trace event
- Revert "msm: mdss: Turn off backlight while power off", "makefile: build with -Ofast", Revert "GPU: optimize build with -Ofast", "ARM: dts: hammerhead: Change i2c clock rate to 19.2 MHz"
- Sync RAMdisk with tunables change (input boost levels, lower thermal levels, set thermal tunables that are used on kernel)
- Use Piereligio_v7 gamma profile
Nexus 5 - Purity - hellscore
Opener mit Erlaubnis von @Eisbaer-Dan aktualisiert.
Hey guys!
Just pushed r422, some new stuff for your hammerheads to test :cool:
I added new touch firmware, some cpu_idle fixes from nVIDIA (can improve bat or not we'll see) and blu_plug fixes and improvements.
Now, blu_plug doesn't lock cores on screenoff: it will hotplug cores normally so people that need a little more power can have it.
The ones that don't need it (if load is low), it will stay in one core like previously. But you can set any amount of max_cores in screenoff, can set 1 like on previous builds or set higher if you need to. RIght now it's max 4 cores in screenon, max 2 cores in screenoff.
I also fixed max freq was not setting properly when using powersaver_mode.
Get involved, test, play, donate, help, contribute.
You keep the spirit alive!
Keep it real, keep it true, keep it Code_Blue
Hier noch der Changelog
Code_Blue r422
- blu_plug: reworked screenoff function to hotplug working without core lock, fix powersaver not resetting max freq
- arch: arm: lib: optimize memcpy for cortex-A15
- ext4: Speedup WB_SYNC_ALL pass called from sync(2)
- ACPI idle, CPU hotplug: Fix NULL pointer dereference during hotplug
- cpuidle: move field disable from per-driver to per-cpu, add checks to avoid NULL pointer dereference, remove unused hrtimer_peek_ahead_timers() call, remove cross-cpu IPI by new latency request, Fix finding state with min power_usage, Get typical recent sleep interval, Set residency to 0 if target Cstate not enter
- sched: Fix hotplug vs. set_cpus_allowed_ptr()
- kernel/smp.c: quit unconditionally enabling irqs in on_each_cpu_mask().
- genirq: Introduce irq_do_set_affinity() to reduce duplicated code
- arch: arm: TLB invalidate if power collapse gets aborted
Nexus 5 - Purity - ElementalX
Ist schon drauf
bei mir auch,
mal sehen
Opener schon aktuell.
Da @Eisbaer-Dan im Umzugstress ist war ich mal so frei.
Dann will ich den doch auch mal wieder testen. Bislang schon länger den Uber genutzt [emoji6]
Bin seit längerem mal wieder auf dem Code_Blue... Läuft wie Hulle...
Nach 12h bei 1h SOT noch 75% [emoji108] [emoji4]
Nexus 5 - Purity - Code_Blue
Ich finde auch das der 422er mit einer der Besten ist.
Code_Blue r438
- Compressed with LZ4-r123
- HID: input: generic hidinput_input_event handler
- introduce for_each_thread() to replace the buggy while_each_thread()
- arm:lib: Correct Neon Flags
- vfs: fix bad hashing of dentries
- msm: msm_bus: Suspected fix for deadlock
- kthread_work: wake up worker only when the worker is idle
- ARM: make kernel oops easier to read
- Revert CPU_idle patches, nVIDIA memory optimizations and some I2C patches
[size=18][Code_Blue r450]
[/SIZE]
[size=14]
All right crew!Going to push what probably is the last hurrah for KK branch...
Hope we are all enjoying Lollipops in the next monthMilestone 7 is up for AOSP an CAF, enjoy!
You keep the spirit alive!Keep it real, keep it true, keep it #Code_Blue
[/SIZE]
[size=14]
- Milestone 7 release
- power: Avoids bogus error messages for the suspend aborts.
- blu_active: Check actual freq before setting new freq
- ARM: Fix undefined instruction exception handling
- ARM: 8165/1: alignment: don't break misaligned NEON load/store
- arch: Introduce smp_load_acquire(), smp_store_release()
- Disable -fconserve-stack on ARM v2
Update + Infos
ZitatAlles anzeigen
[COLOR=#ff0000]Code_Blue r600[/COLOR]All right crew!
Are we ready for the Lollipop?
After some months of beta testing, I think that my L branch is ready for mainline release branch.
Want to thank my beta crew and early adopters users, you keep the spirit alive!I rebased my source and removed quite some cruft: it's leaner and meaner than ever
So, feature wise I removed from KK is Simple GPU governor and USB automount (use stickmount, stock ROM doesn't have storage controls to unmount which is dangerous)
I changed the thermal driver back to franco , which is msm_thermal v2 compatible now and I prefer it.
I changed fast charge, now is in USB mode up to 900mA with MTP on, with higher levels on AC charger also.
The rest, just test and enjoyI don't support custom(or modded) Lollipop ROMs for now, only Stock from Google (Vomer zip is fine also).
Lollipop has lot's of new stuff, so we need to be patient and wait for regular and root apps to be fully compatible, so my advice on L is: keep it lean and just install what you really need.I use Chainfire root method which works good and it's more than enough for now.
I have made my opinion on in both l-preview thread and G+, but I'm curious to see how the scene is going to react to root and other security changes when Lollipop can be built from source. Resumed here
Just waiting for November Lollipops
here
Ca we flash r600 over a 4.4.4kk rom? Sorry but i didn't follow closely the "L development".
[COLOR=#ff0000]
Nope, L branch is for Lollipop only. KK died on r450[/COLOR]
Voting
ability to set low balance notifications and automatically add money to your account
Code_Blue r620
- Merged Lollipop 5.0 (LRX21O)
- defconfig: Disable /dev/diag
- Revert "Revert "Revert "hammerhead: Enable /dev/diag"""
- workqueue: trivial fix for return statement in work_busy(), exit rescuer_thread() as TASK_RUNNING, add missing smp_wmb() in process_one_work(), reimplement work_on_cpu() using system_wq
- jiffies: Fix timeval conversion to jiffies
- cgroup: refactor allow_attach function into common code
- tracing/syscalls: Ignore numbers outside NR_syscalls' range, Fix perf syscall tracing when syscall_nr == -1
- msm: mpm-of: set wakeup interrupt as NO_SUSPEND
- qcom: mpm-of: fix bug in finding the pending interrupts
- msm_bam_rmnet: Fix potential memory corruption
- sched/cpuidle: reduce IPI store. Backport upstream 3.16 scheduler updates
- tick: Dynamically set broadcast irq affinity
- sched: Fix clear NOHZ_BALANCE_KICK, Micro-optimize the smart wake-affine logic, Implement smarter wake-affine logic, Fix select_idle_sibling() bouncing cow syndrome, add wait_for_completion_io[_timeout]
- block: Reserve only one queue tag for sync IO if only 3 tags are available, account iowait time when waiting for completion of IO request
- writeback: Fix occasional slow sync(1), fix race that cause writeback hung, fix writeback cache thrashing
- sync: don't block the flusher thread waiting on IO
- lowmemorykiller.c: convert to use for_each_thread
- introduce for_each_thread() to replace the buggy while_each_thread(), (fix)
der letzte Kernel für KitKat ist der 450er, deshalb lass ich den Titel auf dem 450 stehen, alle weiteren Changelogs dann bitte im L-Thread posten
Ups, sollte eigentlich auch in den anderen Thread [emoji85]
is ja kein Problem, dort hab ich es jetzt gemacht
