Auf Google+ ist nen Update angekündigt und FullWipe wird empfohlen
https://plus.google.com/10287365628828…sts/RBus2422LoF
6.6 ist da
PEEK: Beautify bridging layers code
Disable Camera shutter sound
C-Tool - Persistence - Add installer persistence
Theme Engine Fixed
Fixed Slim Recent On Dark C-RoM (Moved Slim/Stock Recent Option into Rambar menu on C-Tool)
Lockscreen Rotation Optional
Dismiss IME when floating window is dismissed
Fix updating of the status bar header image
On-The-Go: handle display orientation changes
Peek wake timeout
Add CPU boosting hooks
Return: Custom Carrier Label
Smart Pull-Down - Any Notification
Second Clock
CPUFreq Tile
Settings: add "Accept all files" option for incoming files via Bluetooth
And Many More...
Slim ist übrigens der Gewinner der Umfrage.
https://plus.google.com/10287365628828…sts/KwF4upNw9UL
na dann mal schaun wenn sie geswitcht haben
Grad wurde ne Umfrage zu HALO gestartet
https://plus.google.com/10287365628828…sts/hitmMfjaztB
Update: C-Rom 7.0 ist da
[DLMURL]http://get.c-rom.org/hammerhead/[/DLMURL]
http://www.c-rom.org/thread-c-rom-v7-0-845.html
FULL WIPE RECOMMENDED FOR THIS VERSION SINCE WE ARE REBASED ROM!!!!
Whats On New Base?
NO HALO!
BATTERY SAVER MODE
THEME ENGINE
PEEK
NOTIFICATION REMINDER
SHAKE EVENTS
INIT.D TWEAKS
ON-THE-GO MODE
CUSTOM TILE
APP SIDEBAR AND APP CIRCLE SIDEBAR
LOCKSCREEN NOTIFICATIONS
ACTIVE DISPLAY
OMNISWITCH
GESTURE ANYWHERE
DRIVING MODE
RECENTS OPTIONS
AND MANY MANY MORE...
Update auf 7.1 ist da jetzt auf 4.4.4
Changelog
SystemUI FC Fixed.
Theme Engine Fixed.
Wallpapers Fixed.
Added HOVER With All Options.
QuickSettings: Added ProfileTile
Protected App
Dual panel
Show statusbar in expanded desktop
Framework: add compass tile
Framework: add camera tile
Implement ad blocker
Allow disabling of FC dialogs
Expose heads up.
Add time-context headers to the notification header
New UI C-RoM OTA
Base: Allow hiding notification icons
Add option to change size of QS ribbon bar
Add Dialpad key padding
Bring back Density changer to C-RoM
Kann man ja auch mal wieder testen. Heute Abend geht's wieder nach Hause.
