Läuft!!!
Läuft!!!
--- update --- update --- update ---
Changelog
05.05.2014
android_frameworks_base
-Add android_system_label to symbols.xml
-Fix Javadoc link for getModifierBehavior()
-PackageManager: Fix concurrent access to shared state
-Send Media button events as foreground Intent
-Bluetooth:Settings:Handled ACTION_STATE_CHANGED intent at boot time
-Bluetooth: Adds check to verify Bluetooth adapter state
-QuickSettings: fix long press on LTE Tile
-QS: Add TD-SCDMA support to the LTE toggle tile
-Revert "Set some GC parameters only for dalvik"
-Fix a NPE when putting a null-Bundle in an Intent
-idmap: Don't log spam "CREATING STRING CACHE"
-Return system theme when SecurityException is caught.
android_build
-Switch to SM GCC 4.9.1 for the Kernel
-Switch to SM GCC 4.10 for the Rom
-TARGET_USE_O3
-Adjust crremote & crrebase to new domain
-releasetools: Modify regex for radio files
-build: Don't build video editor libraries
-releasetools: Add a newline for radio flashing scripts
-Colorize javac errors
android_vendor
-apns-conf: Add TalkTalk APN
android_packages_apps_Settings
-Total and available fields missing in Settings storage menu
-Data traffic details: use proper string for System UID
-Display BTH connected status correctly
TREX Settings
-Settings: Add default value for display color control (2/2)
android_packages_services_Telephony
-NetworkSettings: Don't error out with TD-SCDMA values
-use proper input type for my phone number dialog
android_packages_apps_Contacts
-QuickContact: onLongClick save item data to clipboard
... and more
Super Danke
Ist schon am installieren ![]()
Seid ihr schnell
Schon am Installieren und hoffen, dass die ständigen Reboots aufhören ![]()
Seid ihr schnell
Ich hatte keine Reboots ![]()
Schuld war sowieso der Smitty-Kernel und nicht die ROM ![]()
Aber um ganz sicher zu gehen hab ich nen Cleanflash gemacht ![]()
Leider noch die gleichen Probleme wie in den letzten 3 Versionen davor, trotz Factory Flash ![]()
Habe jetzt mal testhalber die Einstellungen geändert fürs blinken auf kurz & langsam.
Vielleicht gehts dann *hoff*
Hi Piti8576,
Hat es was gebracht die Einstellungen fürs blinken zu ändern?
Also beim Eintreffen einer Nachricht! Ich schau drauf und da blinkt meines!!
Aber mir ist schon Aufgefallen das wenn ich es nicht bemerkt habe!! z.B. wenn was rein kam und es vielleicht auch schon länger her ist weil es irgendwo rum lag und ich dann das Display einschalte sind doch Nachrichten eingetroffen und es blinkt aber nix(oder nix mehr).
Das blinken für Whatsapp und SMS habe ich direkt in den App´s aktiviert, den Rest über Display LED Einstellungen.
Aber in der Regel funktioniert es schon recht zuverlässig ![]()
Bei Dir scheint es aber wohl etwas anders zu sein………………
Das einstellen hat leider nichts gebracht, es ist genau wie bei dir.
Wenn es länger rumliegt (Nachts gut zu bemerken) und es kommen Nachrichten rein blinkt nichts.
Die letzte ROM wo es wirklich immer bei mir blinkt ist die vom 26.04. da gibt es keine Probleme.
Jetzt ist die Frage ob die LED einen eigenen Dienst hat der beendet wird, oder ob es an etwas anderem liegt.
Ansonsten rennt die vom 05.05 aber sehr sehr gut.
Seit einigen Stunden werden mir meine zuletzt geöffneten Apps nicht mehr angezeigt. Sie verschwinden einfach und der RAM Circle befindet sich nicht mehr wie eingestellt unten rechts sondern unten links und lässt sich auch durch einstellen nicht mehr an einen anderen Platz bringen...
Jetzt hänge ich beim Google-Logo fest... Bootloop...
edit: Nein, doch nicht! Hat ungefähr 3x gestartet, bis endlich die TREX Bootanimation erscheint...
Ganz sicher ist Factory Image flashen !! Daten sichern auf extra Datenträger nicht vergessen ![]()
Vielleicht sollte man diese Option auch in Betracht ziehen... Schaden kann's ja nie ![]()
Ist es normal, dass bei jeder Berührung des Displays beide Kerne erstmal auf 1228 MHz hochtakten? Habe den Eindruck, dass die Akkulaufzeit schon mal besser war.
Habe den Build vom 5.5. mit unveränderten Kernel drauf.
Ist doch gut das er erst auf volle Leistung geht so steht sofort die Leistung an.
Bei Bedarf geht er ja runter, finde ich besser wie umgekehrt.
Akkulaufzeit hat sich bei mir nicht geändert, ist genauso wie unter Fancy oder Franco.
edit:
Schickes Avatar, kommt mir sehr bekannt vor ![]()
Die Akkulaufzeit hat sich bei mir auch nicht merklich verändert, ist genauso wie immer!
Aber das GNEX rennt wie der Teufel :smirking:
edit:
Vor allem, auch die Nicknamen sind auf den ersten Blick ähnlich. Habe mich schon gewundert, warum der fragen Steller auf seine eigene frage ne Antwort gibt :D. Wie gesagt, auf den ersten Blick ![]()
Отправленно с моего Nexus 5
Die Akkulaufzeit muss ich noch weiter beobachten...
Von der Performance bin ich auf jeden Fall begeistert. ![]()
PS: Verwechslungsgefahr mit Piti8576 ist abgemildert. ![]()
Kannst ja den Governor (Interactive) ein wenig anpassen... z.B. mit der App Trickster MOD.
Dort gibt es diesbezüglich zwei Einträge von Bedeutung:
"boostpulse_duration" = 500000
"input_boost_freq" = 1228800
Das bedeutet, dass sobald der Touchscreen einen Input bekommt, die CPU für 500000 Mirosekunden (0,5 Sek) auf 1,22 GHz taktet. Das kann z.t. unnötig sein... z.B. beim Lesen von Texten.
Meine Einstellungen sind deshalb:
"boostpulse_duration" = 100000
"input_boost_freq" = 1036800
Muss aber natürlich jeder selbst entscheiden was für ihn das Beste ist.
Da der TREX-Kernel leider kein Smart-Reflex unterstützt, kannst du auch mal probieren, die Spannungen ein wenig zu senken.
Bei mir lauft flüssig:
Kern
1100
1000
900
IVA
1185
1085
985
900
MPU
Alle -40
So nach einigen Stunden/Tagen testen hat sich das mit der LED verbessert.
Morgens blinkt die zwar immer noch nicht wenn Nachts was ankam aber ansonsten blinkt sie ca. 9 von 10 mal.
Also startet der Dienst wohl wieder von alleine wenn er beendet wird.
Das war in den Versionen davor deutlich schlimmer.
Wäre nur interessant ob es nun ein Future ist um LED und Akku zu schonen wenn die zu lange blinkt, oder ob es doch ein Bug ist.
edit:
Mir fällt gerade noch ein wozu haben wir nun eine Einstellung für die Beleuchtung der Hardwaretasten?
Habe ich da irgendwelche Tasten noch nicht gefunden
