Ergänzung zum Linaro Thread!! Die Eingangs Beschreibung von xda-developers kann ich ohne Abänderungen übernehmen!!Dank des Einverständnisses von LaboDJ!!!
Features:
- Based on Franco Kernel
- F2FS-ALL support in the installer, you don't need 2 versions anymore!
- This is an AOSP based kernel, so it won't work with CAF based ROMs like CM11
- Aroma Installer with selectable options (sound, colors, wake gestures...)
- O3 flag, hard ABI, Linaro, VFP and many others Cortex-A15 Optimizations
- Tweaks to make it compile with gcc 4.9.2
- Fixed most of the warnings
- Upstream with Linux kernel 3.4.x
- Init.d Support
- Battery Life eXtender, LCD_KCAL drivers
- FAT usb OTG outomount, for other FS use stickmount app
- Turned off many debug and logging option
- Added Faux sound, Franco sound is not included, I prefer Faux solution
- Sl[AOU]b allocators optimizations and fixes
- Lz4 compressed kernel and RamDisk for faster boot (with lz4 r123)
- Added sweep2wake, doubletap2wake, sweep2sleep
- s2w/dt2w: Powerkey toggle, Prevent touches during phone calls, Timeout option, Bidirectional sweep2sleep, Omnidirectional sweep2wake...
- Wake gestures interface (requires this xposed module)
- Optional haptic feedback for gestures
- Logitech unifying receiver support
- ExFat 1.2.9, NFS and F2FS kernel support
- lib/string & lib/memcpy: use faser glibc version
- Rwsem backported from Linux 3.10
- Overclocked slimbus for better audio quality
- Mouse/Keyboard Driver support (you need this app and adb debug activated to use your device as a keyboard/mouse to control a pc, even in bios)
- Audio call recording support (you need this app)
- Many other fixes you can find in my git
App Support:
- Compatible with Nexus 5 gamma reverse engineering
- Compatible with franco.kernel Updater (FKU)
- Compatible with Faux Sound
Notes:
- If you want to mount usb OTG this kernel will automount only fat/fat16/fat32 filesystems, for any other file system please use StickMount App
- You can find my own compiled toolchain, optimized for Cortex A15 HERE
- s2w, dt2w, s2s+dt2w will cause an extra battery drain (~2% per hour)
- s2s only will not cause any extra battery drain
- F2FS-ALL option: if you select this option the ramdisk will be modified to work with F2FS-ALL ROMs and recoveries on the fly, it means that the kernel boot.img is created on the fly depending on the options chosen in the installer
- Don't use F2FS-ALL if you are not going to use a F2FS recovery and ROM, it will not boot
------>DOWNLOADS<------
Mirror
How to flash:
just flash in recovery, no need to wipe anything
Quelle:
Mirror
