Und der r51 v2-test gleich hinterher ElementalX-N5-0.40
- New aroma installer!
- Irq fixes
- Bidirectional sweep2sleep
- Omnidirectional sweep2wake
- Wake gestures interface (requires xposed module)
- Optional haptic feedback for gestures
- Fixes some gcc 4.9.1 warnings
- Lowered digitizer voltage (it should help with dt2w/s2w batery drain)
- Updated ramdisk
- Minor fixes
Notes:
- In this version you can't apply s2w/dt2s/s2s/pwrk option on boot with s2Boot folder (like in 2nd post guide)
- You can apply s2w/dt2s/s2s/pwrk set on boot option using the installer
- You can change s2w/dt2s/s2s/pwrk options by reflashing or by editing the file /etc/linaro.conf and rebooting
- Please don't select wake gestures option yet, it will break s2w/dt2w
- Thanks to @flar2 for the installer idea and new gestures feature
