[KERNEL][N5] UBER Kernel
  • Links
    Main: http://uber.oceighty.co/HAMMERHEAD/UBER/
    Mirror: http://d-h.st/users/cl3kener/HAMMERHEAD/KERNELS/UBER
    Cheers!
    Cl3Kener
    Kernel Changelog
    03c842c stereo call recording support
    7181fbe Prevent touches during phone calls
    ee674aa i2c: Drop missing things to 19.2 MHz
    adb3859 Does anyone even read these changelogs anyways?
    a4c8ba5 Make sure to like the OP if you haven't already.
    Uber Config v1.3 Changelog
    - Config now included in Release Kernels as well! (Cl3Kener)
    - Custom Gamma Profiles (@Williamsss)
    - SDCard cfgs (@Williamsss)
    - Min # of CPUs Online (Cl3Kener)
    - Minor Clean ups (@Williamsss)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
    Einmal editiert, zuletzt von MuggelPu (12. September 2014 um 12:26)
  • Update
    TWRP
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Gizmodo
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • =Cl3Kener;55874692][size=12][size=14]October 7th, 2014[/SIZE]
    Well things are really kicking here at UBER! Let me tell you about some of the new things that are happening!
    Basketbuild - I signed up for Basketbuild and I am VERY impressed with them! It has great download speeds and a clean and neat appearance. I believe I'll be dropping Dev Host and going with them as the UBER kernel mirror. Check it out my latest N5 files here: OPPO Forum
    Kernel Compression Change - I've decided to shrink the kernel by XZ so that it is now only 2/3 the size which will allow for faster uploads so I don't sit around typing really long messages for you to read. (I'm sure you'll all be grateful.) Although LZ4 is a faster compression than XZ when it came to booting with uber.cfg and everything else differences in boot time was negligeable (like 1 maybe 2 seconds tops on a 50-60 second boot) LZ4 make a noticeable difference on legacy devices but the raw power of the N5 can uncompress boot.img fast regardless of compression. BTW, kernel compression does in no way influence performance it only influences boot time because it has to be uncompressed and loaded to ram.
    Nvidia Power savings - I grabbed a series of patches from NVIDIA to help improve battery. They made changes to some critical blocking code paths which will allow the CPU to relax instead of being stuck spinning. This should lower the load average and power consumption and increase you battery a little bit more. I haven't noticed any change in performance so I'd say these patches are awesome!
    Better cpuidle
    - Besides the Nvidia stuff I also grabbed some upstream changes dealing with cpu idle in hopes to improve battery life.
    Optimized Memcpy - I grabbed some patches meant to improve memcpy or copy of information into memory on Krait-based processor.
    EXT4 Speedup - You can see I grabbed a commit to help speed up some EXT4 functions.
    Fauxsound config explanations - update faux sound explanations so they make more sense. Hopefully that will help some of you.
    Upstream fix for longtime Kernel regression
    - This commit is cool because I saw it upstream before any other N5 developer. It appears vfs was getting slower since 3.2.y and this fixes that and was made by Linux Torvalds himself. https://github.com/Cl3Kener/UBER-…8b22ba83361691b
    Okay well I could keep going since there were some pretty cool little things here and there. You'll see this is quite a long changelog but my time is almost up. Kernels are almost uploaded.
    Anyhow,
    Enjoy the updates!
    [size=14]
    Links
    [/SIZE]
    Mirror: OPPO Forum
    Cheers!
    Cl3Kener
    [size=14]Kernel Changelog[/SIZE]
    [/SIZE]
  • sparksco
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • https://plus.google.com/10438486723571…sts/Syy1wzgUKBH
    Amazon hid a full app store in its Android app for six weeks and no one noticed
    theverge.com
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • [COLOR=#ff0000]INFO
    [/COLOR]
    [COLOR=#000000]
    How to get uber.cfg working on Lollipop
    Many are complaining about not having uber.cfg work for them. There is an easy fix for that. Go into SuperSu menu and enable su during boot by checking the box.
    That fixed the issue for me!
    [/COLOR]
    [COLOR=#000000]
    Lukas Becker[/COLOR]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • [COLOR=#ff0000]UBER-L Test builds (All Toolchains and Versions)[/COLOR]
    [COLOR=#ff0000]
    [/COLOR]
    [COLOR=#000000]
    [/COLOR]
    [COLOR=#000000]
    https://plus.google.com/10438486723571…sts/ikpanzMyuMM[/COLOR]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • [COLOR=#80ff00][size=24]UBER-L Official Release Build - November 12, 2014[/SIZE][/COLOR]
    [size=24]
    [/SIZE]
    [size=14]As we welcome android Lollipop I have decided to build all UBER-L kernels almost immediately. There weren't many changes in the official kernel source release and it merged right in without a single conflict so I'm feeling confident that it will be smooth sailing.
    For those of you that are not aware, in order to have working ROOT in L you need a ramdisk with a modified selinux policy (see herehttp://www.androidpolice.com/2014/10/20/cha…-a-requirement/)
    What that means is that you'll need to flash a stock kernel with ROOT selinux policy fixes in order to have working root with UBER because UBER use the ramdisk that comes with whatever ROM you flash. This allows for greater ROM compatibility but now with more security in L it adds one more step for those of you wanting to run rooted stock. Once all of the custom ROMs start putting up builds you'll find uber won't break any of the different rooting methods thanks to the current ramdisk snatching install.
    I don't currently have a ROOTED stock kernel but I'm sure one will appear here rather quicklyAFH Mirror #2. I guess Chainfire release cf-autoroot so you can probably use that too. Whatever the method you just need to make sure you have root obtain in the stock kernel you flash before flashing UBER. (There are some links to things in comments below)
    Also, if you want to have uber.cfg work on L you need to install busybox after rooting. Search play store for busybox and use an app to install it. That should allow cfg to work.
    Anyhow
    Enjoy!
    Downloads
    http://uber.oceighty.co/HAMMERHEAD/UBER-L/
    or
    Basketbuild Mirror #1
    Changelog
    https://github.com/Cl3Kener/UBER-L/commits/master[/SIZE]
    https://plus.google.com/10438486723571…sts/355Sd8tKU3F
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • [COLOR=#ff0000][size=18]Test UBER-L Kernel - November 16, 2014[/SIZE][/COLOR]
    Okay so I did a complete kernel rebase last night and this morning. I updated the kernel to 3.4.104. There seems to be some sort of negative stigma regarding 3.4.y kernel updates. I've noticed kernel developers and user alike spread false information about kernels that use kernel.org updates as "not as stable" or "bleeding edge." Both of these notions are FALSE. Every release from kernel.org is considered stable. Here is an example of a post from Greg KH on the subject of 3.4.100 saying this is a "stable review cycle"kernel.org. Allkernel.org updates undergo a review process and are safe to merge and use. If you see anyone posting anything about these updates being "not stable" please kindly correct them and help combat the false information circulating forums and G+.
    As part of the test kernel, I've also removed a few things that I think may be causing Screen Freezes. Hopefully that will fix problems for the people that are having them.
    I've updated uber.cfg files to be a bit more stable (although you'll notice a slight reduction in performance due to the nature of these changes you'll need to reenable some of the memory optimizations yourself under section 9 of the cfg)
    Let me know if you still are having screen freezes!
    Download Link
    [DLMURL]http://uber.oceighty.co/HAMMERHEAD/UBER-L/TEST/UBER-L-N5-SM-4.9.3-11-16-2014-Test.zip[/DLMURL]
    https://plus.google.com/10438486723571…sts/VWd9Mayb7Dn
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Zitat
    November 17th, 2014
    Well I've finally figured out a fix for those of you experiencing screen freezes. Kernels from today should work for you.
    I've also spent several hours merging 5000+ commits from kernel.org bringing this kernel back to version 3.4.104. I also did a full kernel rebase on the 3.4.104 base. You can find my stock fused with kernel.org branch here:https://github.com/Cl3Kener/UBER-L/commits/merged. I went commit by commit to ensure proper merging of all updates. There were many fixes/improvements relevant to this device (although there were also many for other devices that were not relevant to us at all). Kernel.org really is a mixed bag but it's worth ensuring we have the latest improvements, security patches, etc.
    Speaking of kernel.org: There seems to be some sort of negative stigma regarding 3.4.y kernel updates. I've noticed kernel developers and users alike spread false information about kernels that use kernel.org updates as "not as stable" or "bleeding edge - beware!." Both of these notions are FALSE. Every release from kernel.org is considered stable. Here is an example of a post from Greg KH on the subject of 3.4.100 saying this is a "stable review cycle" supported builds. All kernel.org updates undergo a review process and are safe to merge and use. If you see anyone posting anything about these updates being "not stable" please kindly correct them and help combat the false information circulating forums.
    In this update I've also updated uber.cfg files to be a bit more stable (although you'll notice a slight reduction in performance due to the nature of these changes you'll need to reenable some of the memory optimizations yourself under section 9 of the cfg) I've removed functions no longer supported and added a couple more. Some of the most notable changes were 1) I removed frandom support (doesn't work for Lollipop), I removed backlight dimmer (use adaptive brightness instead), I added arch power toggle, I added a gentle fair sleepers toggle, I changed Drop_Caches values back to 0 (since the value of 3 agressively dropped all caches which take longer to rebuild in ART so it causes lag initially when you open apps although performance is great after you get past the lag) I changed FS_DELAY value to 0 just to ensure there would be no data loss caused by this feature while we are still in the testing phase of Lollipop (I may revert this change later).
    Just so we are on the same page these are all of the features that made the 3.4.104 rebase:
    Links
    Main: http://uber.oceighty.co/HAMMERHEAD/UBER-L/
    Mirror: #HT
    Kernel Changelog
    http://hastebin.com/uwiqogasis.dos
    (Much too long for XDA character limits)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • https://plus.google.com/10438486723571…sts/jTuGWwVC9HD
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • [size=14]Update auf 3.4.105 & mehr ...[/SIZE][size=24] [/SIZE][size=8](Ist der neu? Nein mit Perwoll gewaschen!) :moustach:[/SIZE]
    Lollipop Links
    Mirror: Mirror #1
    Kitkat Links
    Mirror: Mirror #1
    Happy Flashing und so ;)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • INFO zu Bye Bye GCC 4.10 :P
    "UBER Kernel Update - GCC 4.10 Kernels to be removed"
    https://plus.google.com/10438486723571…sts/1ibkANEBpoN
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Lollipop Links
    Mirror: Business Insider
    Kitkat Links
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Bissl INFO ;)
    [COLOR=#ff0000]Linaro Toolchain Wars - arm-eabi vs. gnueabi[/COLOR]
    https://plus.google.com/10438486723571…sts/MVYvonN2mf2
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Zitat
    Kernel Changelog
    adea4a2 Revamp spinlock ASM code
    be115df sched: Reduce overestimating rq->avg_idle
    Lollipop Links
    Main:http://uber.oceighty.co/HAMMERHEAD/UBER-L/
    Mirror:Hier
    Kitkat Links
    Main:http://uber.oceighty.co/HAMMERHEAD/UBER/
    Mirror:Hier
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Kernel Update und gaaanz viel INFO auf g+ ...
    Mobilegeeks.de
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Kernel Update ... UBERTC ;)
    - Merged latest Color Drivers for N5 (neobuddy)
    - Changed Toolchains from SaberMod (Now partially closed source so that you cannot build for yourself anymore) to an AOSP-based open source toolchain called UBERTC. Many patches from Linaro have been included in source and also some GCC build fix patches from SM to allow for the latest toolchain components. All sources are GPL and can be found https://github.com/UBERTC/. New toolchains have less of a tendency to lag in scrolling and other screen transitions in comparison to SaberMod and I think are better suited for UBER.
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
