Jetzt wo er nicht mehr bei XDA ist müssten ja Replica erlaubt sein hehe
Cataclysm + Elemental X
ZitatAlles anzeigen
All right crew!Just pushed Code_Blue r923 for Nexus 5
This is for Lollipop 5.1 ROMs only.
The zip uses anykernel installer, this means it uses previously installed ROM kernel Ramdisk.
If already have Code_Blue or ROM default kernel installed just flash over.
If you come from other kernel dirty flash you ROM and flash Code_Blue after.Nexus 5 Changelog:VomerTweaks - The perfect balance of performance and battery life!
Keep it real, keep it true, keep it#Code_Blue
ZitatBack to the heavyweight jam
I decided to reopen the thread after some thinking and some nice talks I had with several people.
[COLOR=#ff0000]I do this for fun[/COLOR], so behave and don't let me regret it.
:X3::X3::X3::X3::X3::X3::X3::X3::X3::X3::X3::X3::X3:
...und nu >> :speechless:
Auf xda ist nun definitiv Schluß mit dem Code_Blue Kernel!!!
Nun läuft alles ausschließlich auf Google+
ZitatAlles anzeigenSo the news: I will no longer contribute in xda and my kernel work will continue here.
I'm tired of all the stuff that daily happens and I just can't continue there.
Some old saying says "if you're not happy just change", so that's exactly what I did.
So if you like my (and my team) work , stay tuned and spread the word.Some things will change: I don't know if I will continue making weeklys, I will push out stuff when I feel like it. This project just keeps draining me by the day and I need to get my head straight.
Other thing is to ask for you to follow the damn community rules once and for all.
1. Post in the correct section. And Releases / Announcements are only for me
2. Tag you post with your device name like [Nexus 5] for instance
3. When you get help and it's solved, put a tag like [SOLVED] on the beginning of your original post
Die Drama Queen öhm ne ... ich meine der Dev hat sich nochmals zu Wort gemeldet >>
ZitatEverything that has a beggining has an end
I will not continue this thread for the time being, those of you that want to follow my wicked endevours, you can find me at G+.
Gibt men neuen Kernel... Elekirgendwas Super das Ding ![]()
Bricked Cataclysm
...aha... wo haste das denn gelesen? Link bitte!;)
3.10-zen12 boot.img (install via fastboot/twrp IMG) Download
Code_Blue r934 (hammerhead)
-Full rebase: welcome to barebone edition era
-blu_active: add missing bits
-defconfig: update and cleanup
-f2fs: upstream changes and fixes
-improve memory access performance for 8974
-memutils: memcpy, memmove optimization
-fs/namei.c: fix potential memory leak in path_lookupat
-crypto: arm/aes update NEON AES module to latest OpenSSL version
-vfs: upstream changes and fixes
-Makefile: tell gcc optimizer to never introduce new data race
-Fix gcc-4.9.0 miscompilation of load_balance() in scheduler
-Disable -fconserve-stack on ARM v2
All right crew!
Just pushed Code_Blue r938 for Nexus 5
This is for Lollipop 5.1.* ROMs only.
Changelogs on website
On this release I added a new tunable to blu_active (thanks stratosk for the idea), which exposes low_load_down_threshold (on earlier builds the value was hardcoded).
The default is 10 which keeps freqs at 300MHz if the load is lower than 10%. This also improves the ripple on the 3 lower freq steps.
Keep it real, keep it true, keep it #Code_Blue
[size=18]Code_Blue r938 (hammerhead)[/size][size=18][/SIZE]
>> blu_active: add low_load_down_threshold
>> crypto updates and optimizations
>> msm: mdss: KCAL: Remove MODULE_DESCRIPTION
>> LZ4 : fix the data abort issue
>> ARM: move VFP init to an earlier boot stage
Update auf r949
http://www.engstk.org/code_blue/hammerhead/
All right crew!
Just pushed Code_Blue r240 for Nexus 6 & r949 for Nexus 5
Wicked!
Changelogs @ website
Changelog ist im OP ![]()
Update..
Code_Blue r952 (hammerhead)
-> Merge 5.1.1 updates
-> idr: fix a subtle bug in idr_get_next()
-> blu_active: upstream CM updates
-> Installer optimizations and RD updates
OP aktualisiert
Bringt es was wenn ich den Read Ahead auf 1024kp stelle?
Code_Blue r955 (hammerhead)
>> Build with SaberMod 4.9-06072015 toolchain
>> Merge Android M1 developer preview goodies
>> defconfig: enable CONFIG_PARTIALRESUME
>> gpio-msm: remove logging of wakeup reason
Es gibt dort auch nen M-Kernel
Entwicklung eingestellt, Downloadlink ist tot... Zitat des Devs bei G+:
"Everything that has a beginning has an end.
I will no longer develop Code_Blue kernel.
I'm tired of all the crap and lack of respect on the kernel scene, so since it isn't fun anymore, this is it.
It was a nice ride, want to thank you all for the support, may we meet again in the future.
Over and out."
Jaja, ist ja nicht das erstemal das jemand mit der Entwicklung aufhören will. Der kommt wieder wenn Ihm genug Leute bis zum Anschlag hinten rein gekrochen sind und wieder Hunderte von Euros gespendet haben. Nur heiße Luft..
Ich erinnere nur an seine kaputte SSD. Dort meinte er auch das er nicht weitermachen könne - und schon prudelten die Euros, Dollars , Rubel etc. und wie von Zauberhand ging die Entwicklung weiter.
Gibt andere Kernel ( Elemental, Hellscore...) Es braucht keinen Code Blue. Und bevor er sich beschwert das Ihm kein Respekt gezollt wird, soll er mal drüber nachdenken was das für Kindergarten ist sein Git geheimzuhalten. Gibt eh nix was geheim ist oder neu ist. Die paar Commits die er ändert, ändern andere auch und ein so großen Unterschied im Alltag machen die auch nicht.
Sucht euch neue Kernel und trauert nicht etwas nach was sowieso wiederkommt!
Peace!
