Rom Features:
ZitatAlles anzeigen
- Open Delta Ota Updates
- JustArchiBuild Optimizations
- Cm Theme Chooser with all bug fixes
- Hover with floating window
- Peek
- Auto brightness Configuration
- Advanced Power Menu
- Battery light
- PA QS Tiles Customization
- PA Pie 2.0
- PA recents clear all Button
- PA Battery Icons
- Expandable Volume Panel
- Gapps Backup Script
- IME selector notification Enable/Disable option
- Incoming call in Background
- Incall vibration options
- Integrated Supersu in Settings
- Lokscreen Slider Shortcuts
- Lock screen see through
- Lock screen Blur
- Lock screen wallpaper
- Notification Light Customization
- Nav bar Height customiztion
- Navring shortcuts
- Notification Count
- Quick unlock
- QS swipe to switch
- Quick Settings Pull Down
- Slim Clock customization
- Smooth Progress Bars
- Statusbar Double tap to sleep
- Screenshot: Quick delete
- Status bar: Date/Time actions
- Statusbar brightness control
- Two line layout for statusbar Date/time
- Volume wake/music control/safe headset & cursor control
- etc...
Kernel Features
ZitatAlles anzeigen
- Based on Linux kernel version 3.4.x
- Linaro 4.10
- Ofast Optimizations
- Graphite Enabled Memory Optimizations
- Thermal Enhancement by Motley
- DT2W
- BLX
- Faux Gamma Control
- Faux Sound
- Kexec Patch
- Fastcharge
- Voltage Control
- MP Decision
- IntelliPlug
- HotPlug
ZitatAlles anzeigen
Build 17:
- ProgressBar: Remove color options from settings
(Smooth progressbar is now themeable,so no need of any color settings )
- Fix crashes upon confirming On-The-Spot dialogs
- Configurable Dialpad key padding
- blacklist: normalize phone numbers to E164 standard
- blacklist: relax phone normalization
- Upstream Theme engine commits
- Updated French translations
- Enforce convertability to a valid E164 number on insert or update.
- InCallUI:
(Full screen incallui is now completely transparent
Fixed glowpadview bottom margin)
- Revert: Clock on lockscreenBuild 16:
- ProgressBar: make progress bar color themeable
- On-The-Spot: Add Gif support
- Update Pie QS Icons
- Update the volume panel color to match Hover
- Add proximity wake-up toggle
- Option to hide Adb notification icon
- Battery light rework (Battery led colors can be configured now)
- Settings: Use a seekbar preference to allow setting arbitrary animation scale values
- Open app when clicking on icon in App Info screen
- Clock on lockscreen
- ART: Picked up some commits from master
- InCallUI: Tweak button background color value (Used black color for 'classic incoming call screen style')Kernel:
- Linux 3.4.104Build 15:
- National Data Roaming
- Pie Settings
- Pie tile: add LongClick to go to Pie settings
- Rotation tile: Longclick action
- Percent Battery: Add charging Animation
- Only show status bar blocker view if nav bar is translucent.
- Upstream Theme Engine commitsChangelog Build 14:
- Extend SwipeHelper to support vertical gestures
- HOVER: Implement hide only on swipe up
- Hover:Long Press Actions (Long Press on hover button opens Hover Settings)
- Add option to Restart SystemUI to Development Settings
- Keyguard: do not play sounds while phone call is active
- NFC: getNdefMessage() should throw exception if no tag in field.
- Revert:NavigationBar Customization
- Add Spanish translations
- Update French translations
- Keyguard: update correctly track title and info if screen turns on
- Fix problem where PhoneWindowManager waits for keyguard to draw
- libhwui: Fix a native crash with patch caching
- show LTE instead of 4G
Build 13
- Add Percent only Battery icon
- Remove CM VoicePlus
- Fix translucent navigation bar layout on tablets in landscape.
- Reworked Quiet Hours (Bringing it inline with Omnirom)
- DocumentsUI: Add a standalone File Manager
- DocumentsUI: Add all bug fixesChangelog Build 12:
- NavigationBar Customization
- TrafficMeter: fix monitor visibility when wifi or mobile data is disabled
- SystemUI: NavbarEditor: Fix saveKeys logic
- Fix glitch appearing when using translucent system bars in landscape.
- BootMessage: show more info in boot dialog
- Merged French translations
- Hover: Fix switch state being out of sync.
- Peek: Actionbar Switch
- See through: Actionbar switch
- DeskClock: Add a few layout color redirections for Theme ChooserKernel:
- Synced with showp1984's s2s & s2w
- Bi-directional Sweel2sleep
- Added Sweep2dim
Changelog Build11:
- TeloRadio
- TeloRadio: optimizations
- SystemUI: hide up arrow NavRing indicator if no targets present
- Fix SuperSU and SuperUser hiding
- Revert "Allow changing theme to Holo.Light without crashing"
- Settings: Remove leftover from old theme chooser
- Settings: Fix alignment of print settings icon
- Update to new adreno drivers (08.08.2014) (Thanks@lichti1901)
- Add G3 Bionic Patch
- Add Z2 Dalvik Patch
- Replace deprecated string resources.
- Allow blacklisting calls from call log detail menu.
- Blacklist:Fix Dialer FCChangelog zu: Build 10 contains many upstream Theme Engine commits.Some other theme related issues are fixed as well..
Changelog 17/07:
- Merge tag 'android-4.4.4_r2
- Added all latest Theme Chooser upstream commits from cm
- Google Dialer
- Volume Panel rework design
- Wake of Power connect/disconnect notificationChangelog 18/07:
- Theme Chooser bug fixes
- Speed up booting on multicore devices.Changelog 19/07:
- Added App Ops
- Rearranging & organizing of Settings Menu
- Added Quick boot
- DownloadManager:Add support pause/resume/stop notifications
- Parallel shutdown
- Add Navigation menu for Telephony
- Added Chinese Location LookupChangelog 22/07:
Clean flash is recommended on this build
- PA Pie 2.0 (includes all bug fixes up till date)
- PIE: Add themeable colors support
- Theme chooser upstream commits
- Hidden Battery Option
- Long press recents to switch to last app
- add switch to last app as navigation ring target
- Reset custom user preferences (For Clear all recents,Pie & Long press to switch to last app)
- On-The-Spot: Add clear all recents button to user preferences.
- Reimplementation of Navbar height & making it work nicely along with Pie
- Other fixes here & there in the buildChangelog 24/07:
- Network traffic meter
- Add battery level around unlock ring
- Add missing permission for NavRing kill app, stop fc's
- Add fastscroll to the Manage applications screen
- Theme Chooser upstream fixes
Changelog 28/07:Code:
- Framework: Make the dialog divider color themeable
- SystemUI: Allow themeing of the "no recents" label
- SystemUI: Seperate system bar BGs for themes
- Added some more upstream theme chooser commits
- Hover Master Switch
- Status bar activity indicators settings
- Option to enable Notification Light when screen is on
- instant led test
- Navbar Custom Glow Time
- incallui: make navigation bar translucent + other fixesChangelog 29/07:
- Dropped CM Calculator
- Dropped CM LatinIME
- Development shortcut in StatusBar and Recent Panel
- Make incoming call screen style configurable
- Don't expand the contact picture behind the call buttons during call.
- SystemUI: Follow CM changes for system bars [PS3]
- HOVER: Fix status bar icon size
- Some more cm theme choose upstream fixesKernel:
- Linux 3.4.100
- MP decision, IntelliPlug and HotPlug Added.
- Voltage Control added.Changelog 8/08:
- Fake ID vulnerability fix
- Quickpulldown PA Style
- Hardcode quick pulldown from right status bar side.
- frameworks/base: Update quick launch shortcut icons/resources
- Hover: exclude from insecure lockscreen (1/2)
- Port "Framework Track Control : Switch from broadcast to audio service"
- Lockscreen VolCtrls : Don't raise volume on skipTrack
- Disable safe headset volume warning
- VolumePanel: Fix Theme Engine support with On-The-Spot dialog
- Allow translucent navigation bar in landscape mode.
- Launch Heads Up in floating window
- Remove Slim QuietHours
- Framework: Show advanced reboot menu only if device is unlocked
- Fix hot reboot in powermenuKernel:
- Latest FauxSound & Intelliplug patchesChangelog 11/08:
- Add NFC QuickSettings Tile
- HOVER: touch to hide
- Frameworks: bring back all lockscreen Widget Settings
- Framework: disable keyguard widget frame
- Framework/base: Lockscreen maximized widgets
- TrafficMeter: added option for auto-hiding on inactivity
- QuickSwipe: swipe anywhere to flip
- Quicksettings: Fix battery tile showing 0% in certain conditions
- Quicksettings: Update all of the battery tile, not just mModel refresh
- Volume Rocker: Hardcode music track seek option
- Revert: Headsup
- MultiUser: Bring support to our features
- Prevent lock/unlock sound during music playback
- Frameworks: Increasing Ringtone
- Frameworks: Advanced low battery indicator options (1/2)
- Theme card lockscreen targets
- AppOps: Improve listing of apps
- Themeable pager tab strip
- Blacklist: Avoid crash when dialog dismissed via back button.Changelog 14/08::
- Base: Blacklist support
- HOVER: A few improvements
- ProximityWake: Squash and port from CyanogenMod
- Base: Configurable rotation
- Swap volume buttons when the screen is rotated by 90 or 180 degrees
- Add an option to change the device hostname (1/2).
- QuickSettings: onlongclick: Change autorotation tile longpress to enter display settings
- Bring back Quiet Hours
- Added some more upstream Theme Engine commits
- Settings: add development animation transition mode 0.75
- Settings: correct 0.75 animation scale for other lanuages and add 0.25Kernel:
- Linux 3.4.103
Installation:
* Daten löschen / Factory Reset
* Installieren der ROM-zip
* Flash-Gapps
* Neustart
* Genießen!
[COLOR=#ff0000]Edit: Im Bezug auf Themen ... Um Probleme zu vermeiden ... Ein Neustart ist nach dem auswählen eines Theme ratsam ![]()
Edit zu Open Delta Update[/color][COLOR=#ff0000]: Im Internen Speicher findet ihr den Ordner "OpenDelta" in dem ist der Ordner "FlashAfterUpdate", nachdem Update enthalten. Dort könnt ihr zip-Datein rein packen die nach dem UPDATE Automatisch geflasht werden!
[/COLOR]
Download:
ungültiger Link
Rom Source: [DLMURL="https://github.com/SimpleAOSP"]SimpleAOSP[/DLMURL]
SimpleAOSP: droid-hive link
Kernel Source: [DLMURL="https://github.com/SimpleAOSP/android_kernel_lge_mako"]Stuxnet kernel[/DLMURL]
Toolchain Source: [DLMURL="https://github.com/UBERUTILS/linaro-arm-eabi-4.10"]UBERUTILS/linaro-arm-eabi-4.10[/DLMURL]
xda: Furnace
g+: droid-hive link
Credits
AOSP
CM Team
PA Team
AOSPAL Team
Sparksco
Rascarlo
Gnome
BaNkS
Chochiwpg
snak3ater
