[ROM+KERNEL][N5] SimpleAOSP "EINGESTELLT"
  • [LEFT]
    SimpleAOSP is a CUSTOM ROM based on AOSP, which aims at keeping AOSP as simple as it can be alongside improving it's stability and performance.
    Official Website
    xda Thread
    Google Plus Community
    [/LEFT]
    It's AOSP with useful features the way we want it.
    [LEFT]
    - Ambient Display
    - Volume Rocker Wake
    - NavigationBar Height
    - Battery Percent.
    - Quick Pulldown.
    - Blacklist.
    - Double Tap to Sleep.
    - Statusbar Brightness Control.
    - Various Clock and Data options.
    - Network Traffic.
    - Increasing Ring Volume.
    - Notification Light Options.
    - Battery Light Options.
    - Safe Headset Volume.
    - App Ops.
    - Navbar Height Customization.
    - Recents All Clear.
    - Phone lookup.
    * Wipe data/factory reset
    * Install ROM from sdcard
    * Flash GAPPS
    * Flash SuperSU
    * Reboot!
    * Enjoy
    Note
    TitaniumBackup users you need to install this test apk the play store app won't work
    ROM
    [/LEFT]
    Gapps
    SuperSU
    [LEFT]
    [/LEFT]
    [DLMURL]http://builds.hubdroid.com/SimpleAOSP-L/final/SimpleAOSP-Changelog.txt[/DLMURL]
    [LEFT]
    BaNkS
    snak3ater
    Gnome
    CallMeAldy
    Google
    SimpleAOSP Team
    HubDroid for their server
    [/LEFT]
    [B][B][B][B][B][B][COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.[/COLOR]
    [B][COLOR=#ff0000]ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/COLOR]
    [/B][/B][/B][/B][/B][/B][/B]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
    21 Mal editiert, zuletzt von MuggelPu (24. April 2015 um 17:35)
  • [size=18]News, Klatsch&Tratsch :moustach:[/SIZE]
    Von SimpleAOSP gibt es nun in [COLOR=#ff0000]3 Versionen = Normal (Legacy) / RRO / CM12 Theme Engine[/COLOR]
    [DLMURL="http://www.hubdroid.com/~CallMeAldy/SimpleAOSP/HAMMERHEAD/"]SimpleAOSP - RRO Builds[/DLMURL] / [DLMURL="http://www.hubdroid.com/~CallMeAldy/SimpleAOSP/simpleaosp-Changelog.txt"]Changelog[/DLMURL]
    [DLMURL="http://104.193.9.133/banks/Simpleaosp/Hammerhead/"]SimpleAOSP - CM12 Theme Engine Builds[/DLMURL] / [DLMURL="http://104.193.9.133/banks/Simpleaosp/Hammerhead/simpleaosp_hammerhead-Changelog.txt"]Changelog[/DLMURL]
    INFO (Offizielle Nightlies)
    Unofficial Nexus 5 SimpleAOSP Lollipop Builds by Chochiwpg
    Chochiwpg
    Unofficial Nexus 5 SimpleAOSP Lollipop Builds by Cl3Kener
    [DLMURL]https://s.basketbuild.com/devs/Cl3Kener/HAMMERHEAD/SIMPLEAOSP[/DLMURL]
    9 Mal editiert, zuletzt von MuggelPu (22. Februar 2015 um 18:35)
  • Build 3 uploaded with this changes:
    - AOSP Dialer icon had a makeover
    - App compatibility issue fixed
    [DLMURL]http://hubdroid.com/~Gnome/SimpleAOSP/Hammerhead/[/DLMURL]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Kann ich leider nix zu sagen weil ich Build 3 net inst habe im mom .... und ich nu im N9 "Wahn" bin! ;)
    Aber .... habe dazu was gelesen eben:
    Originally Posted by sykomaniac
    Try a different kernel e.g. hybrid kernel
    Thanks, that did the trick no SD card bug, no supersu binary not installed issue, just a working L
    I had the problem with SuperSU not flashing and just went back and reflashed after the initial boot. Worked out for me
    Es wird was von einem "SD Bug" gesprochen im xda Thread (schau mal dort auch bitte rein, vielleicht hilft es dir erstmal weiter) :) ...
    SimpleAOSP is ne geile ROM aber bin etwas enttäuscht - wg -> wieso sich die Jungs dazu drängen lassen jetzte scho ein Build zu "posten" etc ... naja...
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Ich freu mich wenn updates geposted werden ... aber mehr infos, changelog bzw noch nen link dabei wär net schlecht (fürs nächste mal) ;)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Habe tapatalk auf dunkel, und da ist dann die Schrift zum kopieren etc weiß auf weis,des wegen hatte ich das heute morgen nicht so schön machen können, sorry.
    Aber btw,ich bin erstmal auf die factory Version gewandert,weil mit der simple habe ich und zig andere bei xda keine mobilen Daten
  • wie du auch????? doofes L :jaded:
    hab des prob auch wg der mobilendaten ... aber seit build 1 scho ?( und das bei jeder L rom ... aber is ne andere story ...
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • was verstehst du unter neu? 2.21 gibbet scho ewig seit der ersten preview oder sind mit den echten img´s neue radio´s gekommen? weiß dat jemand? :)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Also nix neues ... ok
    THX :)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • R.I.P
    ROM ist eingestellt worden! ?(
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ... erstma wieso kannste in einem geschlossenem thread schreiben???
    dann sag ich wieso simple dicht is lol :P
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
