[ROM][N5] Lollipop Dream [CM12][Linaro&ODEXED][Build 25]
  • No BS about extreme performance.
    No BS about extreme battery life.
    No BS build.prop tweaks.
    No BS. Period.
    Under the hood
    CyanogenMod Lollipop 5.0.2 (LRX22G)
    ROM compiled with Linaro toolchain (4.8)
    CM kernel (source):
    Compiled with Linaro toolchain (4.9)
    "Features"
    addon.d / backup tool support
    Advanced reboot menu
    Alarm icon - hide from status bar
    Ambient display (Nexus 6)
    AudioFX
    Back button app kill
    Battery icon options (circle, portrait, landscape)
    Battery percent inside or next to battery icon
    Battery saver mode: choose any color for system bars
    Blacklist
    Brightness slider status bar
    Busybox
    Cache scrolling improvements
    Cell Broadcast Receiver
    Clear all recents
    Clock & date customization (Slim)
    CPU and memory info (About phone menu)
    Display rotation: 0, 90, 180, 270 degrees
    Double tap status bar to sleep
    Eleven music player
    init.d support
    LED battery/notification customization
    LockClock
    Nav bar height/width customization
    Notification count on status bar
    Notification filter
    Performance settings
    Power menu customization
    Power saving improvements when screen is off
    Privacy guard
    Proximity wake option
    Quick unlock
    Quick pulldown
    Quick settings: Clicking on clock or date opens alarms or calendar
    Quick settings: Customization
    Quick settings: Disable pulldown on secure lockscreen
    Quick settings: Long-press most tiles brings up settings
    Quick settings: Notification toggle
    Quick settings Notification tile: Long-press enters silent mode
    SELinux status (About phone menu)
    Status bar weather
    SuperSu in settings
    Tethering modification (DUN) (no guarantees!)
    Theme engine
    Volume rocker music controls
    Volume rocker wake
    Wake on plug/unplug
    Wallpaper chooser
    Numerous minor performance and stability tweaks
    So much more...
    Removed from CM base:
    CMWallpapers
    CM OTA updates
    "Changelog"
    Install
    New users
    Nandroid backup
    Check MD5
    Normal wipe in TWRP
    Flash ROM
    Flash GApps
    Flash SuperSu (beta 2.27 or higher)(optional)
    Reboot
    Update
    Nandroid backup
    Check MD5
    Flash ROM
    Flash GApps
    Reboot
    Download anything missing from Google Play.
    ROM Download
    [MOD] CM DSPManager Universal ZIP (Lollipop 5.0)
    [COLOR=#ff0000]Do not dirty flash over AOSP version![/COLOR]
    Gapps Sammlung
    SuperSU Stable & BETA
    CM Themes Sammlung
    FAQ
    "Klick"
    Q Why doesn't my phone wake up for calls?
    A Proximity wake is enabled. Turn it off.
    Q Why isn't one of my Google Apps working?
    A Flash a different gapps package.
    Q Why can't I access my SIM PIN?
    A Look here
    Still having a problem? Logcat, or it didn't happen!
    From your phone:
    Link
    From your PC:
    Link1
    Link2
    Link3
    Credits
    CyanogenMod, Google, OmniKang, OmniROM, PA, Slim
    Thanks
    Big thanks to oldbbman for testing!
    Quelle
    [B][B][B][B][B][COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.[/COLOR]
    [B][COLOR=#ff0000]ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/COLOR]
    [/B][/B][/B][/B][/B][/B]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
    35 Mal editiert, zuletzt von MuggelPu (24. April 2015 um 14:47)
  • 20141121
    Update to LRX21V
    Custom settings menu
    Volume rocker wake
    Quick password unlock (not PIN - not yet)
    Added AdAway
    Stock boot image (not permissive - no longer needed)
    Minor tweaks and fixes
    Download link and updated install instructions in the OP.
    Enjoy!
    [size=12]Quelle[/SIZE]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    Einmal editiert, zuletzt von MuggelPu (22. November 2014 um 15:04)
  • power aware cpu scheduling
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM und OP Update ;)
    Have fun...
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM & OP Update ... Have Fun!
    20141203 [Build 6] (view post)
    Updated to Lollipop 5.0.1 (LRX22C)
    Reverted to image-based ROM zip
    (now with 500% faster flashing!)
    Removed Launcher3
    Added Google Home launcher
    Fixed addon.d derp
    Proprietary vendor blob update
    Sprint fixes ???
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Spoiler anzeigen
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Up und Date und so :P ;)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Build 10 online ... OP aktualisiert.
    Sony 1
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • 20150116 [Build 11]
    Added cLock widget (LockClock) shortcut to custom settings
    Fixed persistent location icon
    Battery icon style code update
    I will most likely [COLOR=#ff0000]rebase to CM[/COLOR] now that they have their theme engine up and running again (those of you that know me, know I like theming ).
    I will post some "pure CM" test builds to make sure everything is working before I start making modifications.
    cm-12-20150116-UNOFFICIAL-hammerhead
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM und OP up to Date ;)
    info:
    [COLOR=#ff0000]Ab BUILD 12 nun CM12 als ROM-BASE!!! Clean Flash nötig!!! [/COLOR]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM & OP sind nun up to Date ...
    Schaut doch auch mal beim Dev vorbei ;) und klickt THX
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM & OP Update ... :moustach:
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM & OP Update
    Kernel now compiled with Linaro 4.9 toolchain
    (ROM still Linaro 4.8)
    I finally figured out how to separate the ROM and kernel toolchains for CM. So we are back to 4.9 for the kernel.
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Build 19 Online
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Build 22 online & OP Update...
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
