Hi guys, this ROM is oriented to be as stock as possible plus some tweaks that will
make it smoother...hope you'll like it!!!
I made this choiche because:
- many of us like the sex appeal of the stock LG interface;
- it is more compatible with MODS and Themes that will come.
KERNEL:
Stock 20A Kernel with:
- SElinux set to permissive;
- init.d support
- root support
ROM:
- Rooted
- Odexed
- Zipaligned
- Busybox
- Debloated
- Various build.prop tweaks
- Splitwindow all Apps
- SD_external fix ( writable for all apps)
- Lollipop SD internal error fix ( and i wish also invisible navbar and statusbar )
- CTT Mod ( 75° values ) tnx to @Robshr
- Viper4Android support --> just install the app from HERE
Install the TWRP Recovery ( i suggest THIS that make a backup also of the modem partition, needed for downgrade to KitKat Roms )
Put the ROM file in your SD
Reboot to recovery
Flash the Rom
Quelle: XDA
