Nexus 6 - WugFresh - Unlocking, rooting, relocking and unrooting simplified! (and much more!)
  • Hi Leute,
    Es freut mich euch mitteilen zu dürfen das WugFresh Tool auf für das N6 verfügbar ist.
    Wug's ist ein Toolkit mit dem Ihr eure Nexus Geräte entsperren,rooten,flashen etc. könnt.
    Dieses Tool ist die bequemste Art sein Nexus 6 zu bearbeiten. ;)
    Da das meiste auf den Bildern selbsterklärend ist brauch Ich dazu keine ausführliche Anleitung zu schreiben.
    Für Fragen die dieses Tool betreffen geht es HIER weiter.
    VERSION 1.9.8 - This program will automatically bring together all the files you need to unlock and root your device in a few clicks, or flash it back to stock and re-lock it. You can also use this program to backup/restore all your important data, flash zips, set file permissions, push and pull files, install apps, generate logcats/bugreports, and much more! With the included file association options, you can perform tasks like flashing zips, installing apps, restoring android backup files, and flashing/booting img files with just a double click! The program includes a full featured interface for automating tasks in TWRP, enhanced restore features, an in-built auto-updater/notification system, ‘any build’ mode, advanced restore features,’NRT- Live Log’ for viewing the adb/fastboot cmds that are run in the background, quick tools utilities, and tools for taking screenshots/screen-recordings. All the latest official Android builds and Nexus devices are supported. The program intelligently and selectively downloads the files it needs for your device and makes sure you are using the latest files available. The program can even auto-detect your device and build. This release brings Lollipop support, bug fixes, and more. Check out the updated changelog for a more comprehensive breakdown of the feature set and changes in this release.
    Bevor Ihr Fragen stellt bitte die FAQ lesen: Androidnext
    Mehr Informationen und Download findet Ihr hier: http://www.wugfresh.com/nrt/
    Den Changelog gibts hier: http://www.wugfresh.com/nrt/changelog/
    Habt Ihr Fragen zu der App könnt ihr diese gerne HIER stellen.
    [color=#FF0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.
    ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.
    [/COLOR]
    [size=12]QUELLE[/SIZE]
  • Support für Android 5.1
  • [size=24]Nexus Root Toolkit v2.0.5 Released! - [/SIZE]
    [size=18]Changelog:[/SIZE]
    - Rebuilt entire downloading system to utilize wget instead of AutoIT’s inbuilt InetGet functions.
    - New download system now supports HTTP/HTTPS proxy configuration. Full frontend for managing user configurations in the toolkits options menu.
    - Proxy configurations with username/password can be setup, and there is an option to re-prompt for the proxy password credentials each session.
    - Added better information messages in the flash stock interface to help user chose the best configurations.
    - Change the ‘Support Threads’ link to point the forums on wugfresh.com
    - Corrected the ‘Flash Stock + Unroot’ ‘no-force encrypt’ option to grab the no-force encrypt boot.img dependency based on the users selection of what they are about to flash rather than what they are currently running.
    - All backup & restore apps updated to the latest available versions.
    - Busybox free and Quick Reboot updated to the latest available versions.
    - SDK platform-tools (adb/fastboot) updated to the latest available version.
    - To ensure authenticity, all exe’s and installer files are now digital signed with a verified Comodo Code Signing certificate.
    - Other small fixes and general code optimizations.
    I also have been working on improving my site and adding/revising the troubleshooting info. Made the dowload links more defined, and tried to lay things out a bit better. Most notably there is a new forums section:http://www.wugfresh.com/forums/
    Moving forward I am encouraging everyone to try and utilize that as the primary means for contacting me with questions. It's much easier for me when everything is in one place and is searchable for others. I have the forums section setup with tapatalk now so I can easily manage and respond to those comments on-the-go from my phone/tablet.
    That's all for now. Enjoy! ^^
