[KERNEL][Nexus 6] ElementalX-N6-1.05 [29.03.2015]
  • [size=18] [/SIZE]
    [size=18]Features[/SIZE]
    • Easy installation and setup with AROMA installer
    • Best balance of performance and battery life
    • No unnecessary tweaks and hacks
    • Advanced color control
    • Permissive selinux option
    • USB fastcharge (optional)
    • Sweep2sleep (optional)
    • Sweep2wake and doubletap2wake (optional)
    • Wake Gestures support
    • MultiROM support
    • disable fsync (optional)
    • adjustable vibration strength
    • sound control
    • Underclock or overclock CPU
    • Full user voltage control
    • CFQ, deadline, noop, SIO, FIOPS and BFQ i/o scheds
    • NTFS read/write and exFAT support
    • init.d support
    • No forceencrypt
    [size=18]Installation[/SIZE]
    flash in TWRP recovery
    [size=18]Download[/SIZE]
    Android 5.1
    http://elementalx.org/devices/nexus-6/
    [COLOR=#000000]Android 5.0.1/5.0.2[/COLOR]
    AFH
    [COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.[/COLOR]
    [COLOR=#ff0000]ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht[/COLOR].
    [size=10]Quelle[/SIZE]
    21 Mal editiert, zuletzt von Spevil (9. April 2015 um 12:32)
  • [size=18]Changelogs[/SIZE]
    1.05
    -add multirom support (@tasssadar)
    -fix installer (default i/o sched is deadline)
    -various fixes and optimizations
    Ältere Changelogs
    1.04
    -elementalx gov: use more freqs
    -default i/o sched is deadline
    1.03
    -update hotplugging for all cores online
    -update installer to work with more ROMs
    1.02
    -elementalX governor: remove input boosting and replace with active floor frequency
    -reduce hsic wakelock
    -default i/o sched is FIOPS
    -various tweaks and optimizations
    1.00
    -rebase on lollipop-mr1 (Android 5.1)
    -prevent touches during phone calls
    0.28
    -add KCAL advanced color control (savoca)
    -revert 5GHz wifi fix
    0.27
    -revert custom thermal
    -add 5GHz wifi fix (yank555)
    -tweak elementalx governor
    0.26
    -add permissive option
    0.25
    -add Wake Gestures support
    -allow stock vibration level
    -sensor_ind wakelock toggle
    -update installer
    -reduce wlan wakelock
    -wake gestures: remove debug output
    -increase default max screen off frequency
    0.24
    -Revert "staging: binder: Change binder mutex to rtmutex"
    0.23
    -elementalx gov: apply input boost per-cpu
    0.22
    -update installer to use existing ramdisk
    -changes to elementalx governor
    -remove cpuboost
    -leave two cores online during screen off
    0.21
    -disable mpdecision
    -add hotplug driver
    -revamp elementalx governor
    -noop is default i/o scheduler0.20
    -reduce default vib strength and make 0 disable it
    -revert increase cache freq and bandwidth for boost freq
    0.19
    -adjust vibration strength control
    0.18
    -add vibration strength control
    0.17
    -various tweaks and optimizations (mostly CAF)
    -interactive update and tuneup
    -ensure cpu-boost is enabled
    -increase cache freq and bandwidth for boost freq
    -built with linaro 4.9.1 toolchain
    0.16
    -compile with linaro 4.9.1
    0.15
    -interactive is default governor
    -update installer
    -add BFQ, FIOPS and SIO i/o scheds
    0.14
    -disable thermal-engine
    -add in-kernel thermal throttling
    -fix USB fastcharge
    0.13
    -ElementalX governor default
    -fix simple-ondemand
    0.12
    -power saving tweaks
    0.11
    -everything back to stock
    -add fauxsound support
    0.10
    -elementalx is default governor
    -slight tweak to elementalx governor
    -make wake gestures more sensitive
    0.09
    -revert disable s2w in phone calls
    -minimize s2w idle drain
    -re-enable elementalx governor
    -add debugging info to kernel logs
    -revert some commits to get closer to version 0.06
    0.08
    -remove elementalx gov
    -re-enable cpu-boost
    -disable cpu-boost while using ondemand
    0.07
    -haptic feedback for stock dt2w
    -prevent touches during phone calls while s2w is enabled
    -add elementalx governor
    -add USB fastcharge
    -update installer
    -update ramdisk for Android 5.0.1
    -fix simple-ondemand GPU gov
    0.06
    -fix max frequency
    -add max screen off frequency
    -update installer
    -sepolicy: add profile service as system service
    0.05
    -aroma installer and configuration
    -optional haptic feedback for s2w/dt2w/s2s
    -lower starting GPU freq to 240MHz
    -increase overclocking to 3033MHz
    -more tweaks and optimizations
    0.04
    -added RGB colour control
    -BFQ i/o scheduler
    -Makefile adjustments
    0.03
    -do not force encryption (for real this time)
    -fix sweep2sleep area
    -remove ROW i/o scheduler
    0.02
    -add sweep2sleep
    -add sweep2wake
    -make doubletap2wake compatible with standard apps
    -overclock CPU to 2.9GHz
    -user voltage control
    -NTFS r/w support
    -exFAT support
    0.01
    -row i/o scheduler
    -lz4 compressed kernel
    -linaro 4.9.1
    6 Mal editiert, zuletzt von Spevil (9. April 2015 um 12:33)
  • Version 0.12 ist verfügbar...
    Nachdem ich ja super sot-Zeiten damit bekommen habe, aber leider (und es wird sehr viel bei Xda davon berichtet) einige SOD vorhanden sind - auch bei mir (einmal sogar mit 40%Entladung über Nacht) - hat @flar einiges an dem govenour umgeschmissen und neu gemacht.
    Test war v0.11 mit aber schlechtem idle darin
    Back to stock mit Version 0.12
    FEATURES
    Easy installation with Aroma installer
    overclock/underclock
    CPUuser voltage control
    RGB color control
    USB fastcharge
    Optimized for battery/performanc balance
    ElementalX CPU governor
    optional sweep2wake and doubletap2wake
    optional sweep2sleep
    /li>NTFS r/w, exFAT support
    option to disable fsync
    optimized linaro 4.9.2
    3 Mal editiert, zuletzt von vergilbt (27. Dezember 2014 um 14:33)
  • Update!!
    More experimentation, trying to smooth things out a bit by ensuring cpu boost is enabled and adding some CAF updates to interactive. Also increased the cache freq and bandwidth for touchboost freq. More tuning to come, I'm still getting used to interactive. This one is built with Linaro (for real).
    Download:
    ElementalX-N6-0.17 (beta)
    Changes:
