Hast du in der Design- App (Icon schaut aus wie nen Farbeimer) geschaut? Bei mir hatte es ohne Probleme geklappt
[ROM][N5] Euphoria-OS 1.1
Starte mal neu oder wähle links mal auf zb nur Thema anwenden, dann sollte es sichtbar werden
ROM Update! Link & Changelog im OP...
ZitatWe have decided to drop OpenDelta because it wasn't reliable for a lot of users and it was quite restrictive meaning you had to be on a certain build for delta to show up, we've brought back OTACenter which is a very simple app but does the job of getting a notification out to you that an update is available. We do realise that for some users its difficult to download 200mb+ but we mostly only release once a week sometimes longer so I don't see it as a problem, delta's are good for nightlies which we are not planning on doing.
To all translators, translations are on hold for a while. We need to organise some things and then we will open a new translation section were you will always have the latest files to translate and post back so we can merge them. It will be a lot easier for us this way, +Mitch Davis will be taking care of translations so once we get started he will be doing his best to merge all translations, Thanks.
8x Euphoria Os Walls @g+
Jetzt geht es mit dem Design. Ich musste in der Design App links auf Einstellungen und dort Stil auswählen da hat es mir euphoria dark angezeigt. Danke für die schnellen Antworten
ROM & OP Update ...
ZitatAlles anzeigen04.02.2015
-Theme chooser fixes
-Quick settings: Option to show four tiles per row
-Navigation bar and rings customization
-Navigation bar cursor keys
-Option to disable lock screen shortcuts
-Fixed layout issue's in OTACenter and made it theme-able thanks to +Alexander Westphal
-New quick settings icons thanks to +Alexander Westphal
-Many more changes which haven't been mentioned here are in the detailed changelogNote: If your going to use a custom kernel make sure they have added an sepolicy addition for torch
otherwise it will not work, also there have been some theme chooser updates so if you find SystemUI
doesn't theme any more you will need a clean flash. -
Up zu dem to zu dem Date ....
Mehr im OP ...
Hab jetzt ne weile im netz gesucht aber leider nichts richtiges gefunden. Ich habe festgestellt das ich auf meiner Tastatur keine Taste für Spracheingabe mehr habe und diese auch in den Einstellungen nicht aktivieren kann. Wollte gerne Wörter einsprechen die dann z.b bei Hangouts oder WhatsApp geschrieben werden anstatt mühselig auf der kleinen Tastatur zu klimpern und mich immer zu vertippen. Früher hatte ich da halt eine kleine taste in Form eines Mikrofon aber die ist halt weg. Weis da einer einen Lösung wie man das wieder einstellen kann oder bracue ich dafür eine andere Tastatur App bzw irgendwelche extra Apps von google?
Ich nutze zur zeit die ganz normale Tastatur von der Euphoria Rom. -
Hi,
...als erstes: Keine Angst es liegt nicht an der ROM, Tastatur & co
Und als zweites welche Gapps hast du geflasht und/oder hast du die Google App entfernt oder eingefroren?Für Spracheingabe brauchst du die "Google App" <- klick mich!
Oder die alte App -> "Sprachsuche" <- mich kannste auch klicken
Und als Tipp für nebenbei ... Schau dir mal SwiftKey (Tastatur App) an! Kostenlos nun und wirklich mehr als Top!
Ich nutze die slim mini gapps zu der Rom. hab jetzt swiftkey installiert und es funktioniert alles bestens. Danke für die Hilfe
Freut mich das es funzt und SwiftKey dir gefällt...
Und nur durch installieren von SwiftKey wurde dein Problem behoben ...sry das ich so doof
frage aber eines macht mich aber Neugierig bzw Stuzig: Slim Mini Gapps haben doch Google App enthalten oder? Weiß das grad net so genau... weil dann lag es ja doch an der ROM bzw Tasta das es nicht funktionierte. -
Nope is nich mit drin
Keine Ahnung an was es lag aber mit swiftkey hat es sofort geklappt. Hab mich ja bissl belesen und anscheinend is das allgemein ein Problem das die Spracheingabe so nicht mehr vorgesehen ist seitens google. Die google App habe ich nicht installiert aber die Sprachsuche die reicht aus.
ROM & OP Update
[size=14]Euphoria-OS-1.0-hammerhead-20150214[/SIZE]
[size=14]"Changelog"
14.02.2015
-Brightness tile: long press to toggle manual/auto brightness
-Use normal timeout delay for media volume panel
-Recents clear all center option and position fixes
-Bring back Status Bar Ticker
-Create configurable default expanded desktop style
-Fix status bar activity indicators getting stuck when disabling
-Fix battery saver bars resetting to orange when device was rotated
-Settings: Hide some options for tablets
-Mms: fix loading avatar for own profile
-Mms: fix font size-All cm features fully translated into most languages
[/SIZE]
Jemand Probleme mit den Themen?
Mein notification panel und die lockscreen notificqtions bleiben immer in den stock Farben... Tausend Neustarts gemacht, Daten von der design APP gelöscht, Rom neu drüber gebügelt...
Ok ich habsLegacy Hubdroid Builds
ROM & OP Update ...
Update ist genial, endlich funktionieren die Themes. So macht Android Spaß
Nutze Mianogen
Der neue ElementalX läuft auch Super mit dem RomGesendet von meinem Nexus 5 mit Tapatalk
Haben sie vorher auch schon;-)
Aber das ambient display ist jetzt geil -
Mit einem Trick
