Es haben sicher schon einige mitbekommen >> Wer Euphoria mit dem Stock Kernel betreibt >> bitte diesen Kernel nutzen, er wird in dem nächsten Update "eingepflegt"... ![]()
ZitatAlles anzeigenI'm not very happy with stock kernel regarding battery drain and heat, for 5.1 I had go back to using stock mpdecision which boosts for way too long creating heat and drain
Here's a new kernel for anyone who wants to test
[size=14]eos-hammerhead-exp-01-04-2015.zip[/SIZE]
7.8MB Apr 01, 2015 | 03:29PM-updated interactive governor (default)
-in-kernel touch-boost
-mpdecision binary from oneplus oneYou will notice it uses lower frequencies a lot more which will help with both drain and heat, it might feel less smooth compared to the kernel included in the ROM but I'm willing to sacrifice a little smoothness.
This kernel will probably be included in the ROM after I make some tests.
Edit: source code for kernel https://github.com/Altaf-Mahdi/hammerhead
