  • LD-LP-20150129-1650-liquid_hammerhead & LD-LP-gapps-20150129-dark
    !!!! F U L L W I P E !!!!
    [FONT=Georgia][size=24]Changelog[/SIZE][/FONT]
    01-29-2015
    * android/
    70837cb add Wallpapers
    ba5504d Revert "add updater"
    * build/
    df8d8e0 testing end
    b9d502a Update main.mk
    680a506 derp
    fe26e66 testing 2
    ff99327 testing
    53c5157 derp
    de9ab38 fix dalvik
    f33c902 Dalvik: disabling verify-bytecode
    * device/lge/hammerhead/
    b7f632a hammerhead: mixer_paths: Enable compander last
    8c2e363 netmgrd: give explicit read access to /proc/net
    fcfecf2 Remove obsolete dalvik.gc.type-precise
    * frameworks/base/
    d69f84c Update styles.xml
    fd6cafb Update colors.xml
    * frameworks/native/
    e0d7c63 Fix for corruption when numFds or numInts is too large.
    3250a13 Surface: Ensure synchronisation of copyBlt
    e7e6006 Surface: Always consume fence fd in queueBuffer
    * packages/apps/Settings/
    0ef3f49 settings: update logo
    7a43a1b Revert "add updater 3/3"
    231f04a Revert "Update device_info_settings.xml"
    * packages/apps/ThemeChooser/
    feb1890 Update notification icon to new paint bucket
    * packages/apps/Wallpapers/
    19332e6 Update thumbnail.xml
    53b1bfe change name (strings de)
    b663ce6 change sdcard_dl_location
    c50b530 change name
    * system/core/
    13d53a4 fs_mgr: Allow ext2/3/4 to mount as ext4
    * vendor/liquid/
    3c41dd5 build Wallpapers
    f0e7b8b Revert "add updater 2/3"
    01-28-2015
    * android/
    1afe918 add updater
    * build/
    11283fb derp
    897c660 fix 2
    5f004fb fix
    662f1ad fix build error
    6768acc derp
    15eff11 change ASCII art
    a0242b0 change script.Print
    * frameworks/base/
    976b549 notification_guts_text_color
    9d96f6b settings: change logo
    d5fbd22 Update device_info_settings.xml
    a9658cf add updater 3/3
    445e464 change Download Center strings
    7a31b60 Remove SL gapps add SuperSu in Download Center
    25acd16 new Uri SuperSu
    5a2ab7d Rename L-TR Downlaods in Download Center
    38163bb add Slim gapps (beta) for lollipop in Download Centere
    f2a14c1 clean up "Download Center"
    9d024da remove xposed
    f1b2298 Downloads to trex
    dfd80e8 LiquidSmooth Download Center
    * system/core/
    b08cf09 android_reboot: execute recovery pre command while rw mounted
    * vendor/liquid/
    f81d1d5 change default wallpaper
    3721fe4 more fix backup on dirty flash
    2682f63 add updater 2/3
    01-27-2015
    * bootable/recovery/
    1fc30d3 recovery: fix another misspelling of "file_blocks" as "block_size"
    * external/icu/
    dc29137 Updated ICU stub data file
    cec6820 icu: Add Luxembourgish ICU files
    8384da6 icu: Add Asturian ICU files
    * frameworks/base/
    0a200ec Telephony: Add getLteOnGsmMode() method (1/2)
    f3f079f Revert "WindowManagerService: Fix On-Screen keyboard popups when hw-keyboard is present"
    908d252 Themes: Check common resource paths at java layer
    073dcc1 Themes: Allow setting a default theme
    ba27f98 Themes: Watch all app crashes for problematic themes
    4c0adc9 Move non-AOSP symbols to liquid_symbols.xml
    4877664 Revert "Remove CM Theme Engine"
    2b52465 Revert "Squash revert of caf and add Sony's RRO patches"
    04a65f9 change android-logo-mask
    ebbdb55 Revert "SurfaceFlinger: Make secure display ifdefs more narrow."
    * frameworks/opt/telephony/
    549c941 Telephony: Add getLteOnGsmMode() method (2/2)
    * hardware/libhardware_legacy/
    f7d1831 wifi: add semco for Samsung BCM43569
    * hardware/qcom/display-caf/msm8084/
    f679e33 hwc: Add secure display attribute
    * packages/apps/Contacts/
    652b1f0 Contacts: Impove CAF strings
    aa1856f Remove leftover blacklist code
    423309e Revert "Support adding contacts to blacklist and whitelist"
    e42b291 Contacts: fix exporting SIM contacts the first time
    78b0971 Contacts: move CAF strings to cm_strings
    * packages/apps/ContactsCommon/
    2e4215a Add overloads to scaleIn() and scaleOut() to receive an AnimationCallback
    a5a5514 ContactsCommon: fix exporting SIM contacts the first time
    31ecfcf ContactsCommon: move CAF strings to cm_strings
    * packages/apps/Dialer/
    c8dc1f6 Fix animation glitch
    a734e17 Remove extra call stats header
    80b9314 Fix regression in recent call filtering
    9d0c786 Port "filter by date range" from call stats page to call log
    66d8527 Revert "Dialer: support "add to black/white list" in call detail"
    5cd5092 Dialer: Remove Chinese CAF translations
    df243b3 Dialer: Improve CAF strings
    31e715a Move string addition to cm_strings
    5f82c37 Dialer: Fix T9 for Hebrew
    8221808 Return match positions to enable highlighting for CN smart dial
    b9ad8d4 Add setting for t9 search input locale
    370bd0b Read option for t9 search input locale and refresh smart dial db when locale changes
    581d9c7 Dialer: Refactor SmartDial for additional languages
    622908f Add Korean smart dial map
    d562d46 Hebrew T9 for Dialer
    c40c4d4 Dialer: Add Greek T9 support
    13f765f Russian T9 for Dialer
    c113b00 Separate blacklist from missed filter in history/stats
    f929e82 Merge code and add CallStats in multi sim
    fa4cea8 Dialer: move CAF strings to cm_strings
    8498d99 Dialer: modify AOSP RU translation
    * packages/apps/InCallUI/
    c8366f8 Contact details on incoming call (1/2)
    c23d203 InCallUI: Use correct string for blacklist menu action
    14b8ffc Fix up cm_strings structure
    41d4872 InCallUI: move CAF strings to cm_strings
    * packages/apps/Mms/
    c556b10 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    88f8801 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    * packages/apps/PhoneCommon/
    83e6244 Add AnimationCallback parameter to scaleIn() and scaleOut()
    166b7e2 PhoneCommon: Set untranslatable
    8dd2840 Refactor dialpad layout to support t9 search in multiple languages
    3ed02ab Fix up cm_strings structure
    b03df24 PhoneCommon: move CAF strings to cm_strings
    * packages/services/Telephony/
    7a64ef0 Phone: Enable LTE for GSM LTE phones (part I)
    * vendor/liquid/
    9a2086c Revert "Add basic Layers Permission and prebuilt apk"
    9dc7b93 new notifications sound (dinosound)
    c2495f8 Merge branch 'lollipop' of https://github.com/t-rex600/android_vendor_liquid into lollipop
    4215bd2 new default Wallpaper
    01-26-2015
    * android/
    0ee5703 remove Anonymous Stats and updater 3/3
    c6354e0 Switch Kernel GCC 4.9-sm
    * external/bluetooth/bluedroid/
    4aad8dc bluedroid: Fix CAF commit 25c965cdcd99f1e495284802785cfb104b19b05c
    * frameworks/av/
    a6ab7f8 Fix id3 parser crash
    1d44178 Fix bugs don't remove track of DirectOutputThread
    3ed4ff8 Fix bugs regarding looping play issue with sharedBuffer
    0b97100 stagefright: add Samsung S3D support
    * frameworks/base/
    bf38956 change LiquidDark logo mask
    e9c1c6b black notification_overlay icon
    8869b7a SystemUI : Move shortcut helper instantiation before updateVisibility
    dac852f SystemUI: Lockscreen shortcut customization
    * hardware/ril/
    a28b67c rild: enable tombstone on RIL crash
    * packages/apps/Bluetooth/
    9b33598 Handle change from boolean to int preference
    * packages/apps/Calculator/
    69d885e Calculator: Add missing hdpi drawable
    * packages/apps/DeskClock/
    26aa536 Automatic translation import
    273cb7f Add Download Center
    c1e616a change strings
    83abef9 Switch to new Logo (settings)
    819d387 SuperSU change in setting menu
    d9ee106 Settings : Lockscreen shortcuts
    c1b0a29 update Theme Icon Color
    44bcb50 Revert "Remove Theme settings"
    d4ec59f remove Anonymous Stats and updater
    * packages/apps/SlimLauncher/
    6ccc41f Automatic translation import
    * system/core/
    74b61dd healthd: remove useless gotos in set_backlight_on
    e978018 healthd: fix LED color on 100%
    210b74a healthd: more descriptive LED path opening error message
    9942c54 healthd: remove useless goto in charger mode
    * vendor/liquid/
    4646ff5 Fix Build error
    19abf8f derp Sony Bravia
    d67011c Add S4's
    f1df303 remove Anonymous Stats and updater 2/3
    01-25-2015
    * android/
    7bca10a Update README.mkdn
    8451b90 Fix Provider Contacts
    cf6c6b4 derp
    769d5f0 recovery: autodetect filesystem type
    d5202ba Fixes BLE remote device address type after LE connection
    * external/ffmpeg/
    4f1bd57 Clean up some build-time warnings
    * frameworks/av/
    6195593 nuplayer: Add cached lookup of track duration
    918ae2c audio: Support for compress offload recovery
    644eec2 Revert "Track volume should be maintained even if track is restored."
    95413a7 DcTracker: Handle null waitingApns properly
    * packages/services/Telecomm/
    e945528 Add back phone notification LED settings backend (1/2)
    680b920 Telecom: Don't connect bluetooth audio when incoming call is answered.
    * system/extras/
    f0f66cd mkimage for OMAP
    * vendor/liquid/
    f00b99a new release Name (zip) LiquidDark
    2c7fdb4 remove Anonymous Stats
    8d1a6ee X-Reality
    8502c1f Build without BOOTANIMATION
    fb1a30e update SuperSU 2.45.zip
    01-24-2015
    * android/
    699c1cc README: to dark
    bc17e60 Dark UI repos to trex
    7fef682 Device to trex
    739d7ee Base repos to trex
    81bc4b7 Update README.mkdn
    0e73b8c Update README.mkdn
    c0eb001 update Readme LiquidSmoothBlack
    ed08fea mtdutils: Fix mounting partitions by-name
    66c8cfd recovery: Fix a couple bugs in sideload cache logic
    * external/strace/
    c478edc Build a static strace utility
    * frameworks/base/
    90e880f white text in Notifications window
    df2d2da Dialog Material Dark UI showBootMessage color black
    74c318b Revert "Revert resource themeing in preparation of CM-12.0 theme engine"
    62ad804 WindowManagerService: Fix On-Screen keyboard popups when hw-keyboard is present
    ac1acbb bootanim: Add continuous splash support
    a358363 Fix for landscape thumbnail images on GLES11RenderEngine
    741a356 libgui: add support for Samsung external gralloc usecases
    * hardware/qcom/audio-caf/msm8974/
    5ef2da5 msm8974 hal: Remove platform and baseband check for CSD init.
    806cf8a settings: navigation_bar_height_min_percent to null better for SlimPIE
    30d9872 Revert "Revert resource themeing in preparation of CM-12.0 theme engine"
    4c3d5b0 Revert "Settings: Use a higher quality image"
    * packages/providers/ThemesProvider/
    d8da252 Fix isPresentableTheme() logic
    * vendor/liquid/
    c4abc63 change release Name (zip)
    LiquidDark für Nexus 4|Nexus 5|Nexus 5X|Nexus 7|Moto E|Moto E 2015|Moto G 2013|Moto G 2014|Google Android One
    Community G+
  • Ich habe die Rom neu aufgesetzt, machst du keinen hast du probleme mit der Status bar und den Benachrichtigungslicht, das ist was mir auf gefallen ist !
    PS: mache auch kein gerne aber dies mal ließ es sich nicht vermeiden :screaming::D
    Community G+
  • Keine Ahnung :D bin auf MyBackup pro um gestiegen TB ging mir auf den ..., sollte aber ohne zip funktionieren da SuperSU läuft und TB nur mit SuperUser probleme hat !
    Community G+
  • warum gabs denn ne namensänderung? Habe ich was verpasst?
    Wegen Full Wipe, kann ich es trotz dem als 2nd im Multirom installieren oder ist das dann auch doof? Muss ja erst mal wieder testen, ob ich wieder das NavBar Problem habe (woran auch immer das bei mir liegt)
