[ROM][N6][CM12] Lollipop Dream [Linaro][Build 21][15.03.2015]
  • No BS about extreme performance.
    No BS about extreme battery life.
    No BS build.prop tweaks.
    No BS. Period.
    This thread is here for all to enjoy, so a little OT is fine as long as we are talking about ROMs, mods, apps, etc. Having said that, this is not a help thread. Questions that are not specifically about this ROM go elsewhere.
    [size=18]Under the hood[/SIZE]
    AOSP Lollipop 5.0.1 (LRX22C)
    ROM compiled with Linaro toolchain (4.8)
    Stock kernel
    [size=18]Features[/SIZE]
    "Features"
    addon.d / backup tool support
    Advanced reboot menu
    Alarm icon - hide from status bar
    Ambient display (Nexus 6)
    AudioFX
    Back button app kill
    Battery icon options (circle, portrait, landscape)
    Battery percent inside or next to battery icon
    Battery saver mode: choose any color for system bars
    Blacklist
    Brightness slider status bar
    Busybox
    Cache scrolling improvements
    Cell Broadcast Receiver
    Clear all recents
    Clock & date customization (Slim)
    CPU and memory info (About phone menu)
    Display rotation: 0, 90, 180, 270 degrees
    Double tap status bar to sleep
    Eleven music playeraddon.d / backup tool support
    AudioFX
    Bug report removed
    Busybox
    Clear all recents (CM)
    CPU and memory (About phone menu)
    Eleven music player
    init.d support
    Google Camera
    Google Contacts
    Google Dialer
    Google factory image sounds
    Google Launcher
    Google Messenger
    Google OTA update removed
    LED battery/notification customization
    LockClock
    Nav bar height/width customization
    Power saving improvements when screen is off
    Privacy guard (Slim)
    Proximity wake option
    Quick unlock (PIN and password)
    Quick pulldown
    Quick settings: Long-press most tiles brings up settings
    Quick settings: Data and Notification toggles
    Quick settings: Disable pulldown on secure lockscreen
    Quick settings: Clicking on clock or date opens alarms or calendar
    Quick settings Notification tile: Long-press enters true silent mode
    SELinux status (About phone menu)
    Status bar weather
    Tethering modification (DUN) (no guarantees!)
    Volume rocker wake
    Wallpaper chooser
    Numerous minor performance and stability tweaks
    So much more (see changelog)
    init.d support
    LockClock
    Notification count on status bar
    Notification filter
    Performance settings
    Power menu customization
    Privacy guard
    Quick unlock
    Quick pulldown
    Quick settings: Customization
    Quick settings: Notification toggle
    Quick settings Notification tile: Long-press enters silent mode
    Status bar weather
    SuperSu in settings
    Theme engine
    Volume rocker music controls
    Volume rocker wake
    Wake on plug/unplug
    Wallpaper chooser
    So much more...
    Removed from CM base:
    CMWallpapers
    CM OTA updates
    Shamu specific
    Encryption optional
    Notification LED controls not yet working
    Tethering enabled
    Video working
    [size=18]Disclaimer[/SIZE]
    [COLOR=#ff0000]I do not own a Nexus 6. This ROM is based on my Nexus 5 ROM.[/COLOR]
    [size=18]Install[/SIZE]
    New users
    Nandroid backup
    Check MD5
    Normal wipe in TWRP
    Flash ROM
    Flash GApps
    Flash SuperSu (beta 2.27 or higher)(optional)
    Reboot
    [size=18]Update[/SIZE]
    Nandroid backup
    Check MD5
    Flash ROM
    Flash GApps
    Reboot
    Download anything missing from Google Play.
    Banks GApps
    PA GApps
    SuperSu Stable
    SuperSu Beta
    [size=14][size=18]Download[/SIZE][/SIZE]
    Hier
    [COLOR=#000000]Do not dirty flash over the old AOSP version![/COLOR]
    [size=14][COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.
    ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/COLOR][/SIZE]
    [size=14]
    [size=12][COLOR=#ff0000]QUELLE[/COLOR][/SIZE][/SIZE]
    14 Mal editiert, zuletzt von Spevil (24. Februar 2015 um 20:34)
  • [size=18]Changelogs[/SIZE]
    [size=14]20150315 [Build 21]
    Removed CM Account app
    Synced CM source
    [/SIZE]
    [size=18]Ältere Changelogs[/SIZE]
    "Ältere Changelogs "
    [size=14][size=14]09.03.2015 [Build 20]
    Synced CM source
    [/SIZE]
    20150301 [Build 19]
    Synced CM source
    20.02.2015 [Build 18]
    Heads up notification customization (Slim)
    Battery saver mode: choose any color for system bars (Slim)
    Status bar clock mod update & fixes
    [DLMURL="http://www.cmxlog.com/12/shamu/"]Synced CM source[/DLMURL]
    Heads up notification customization:
    -Enable/disable per app
    -Snooze and timeout configurable
    -Left swipe dismiss
    -Right swipe puts in background
    -Down swipe moves to notification drawer
    15.02.2015 [Build 17]
    Kernel now compiled with Linaro 4.9 toolchain
    (ROM still Linaro 4.8)
    [/SIZE]
    [size=14][size=14]13.02.2015 [Build 16][/size][/size][size=14][size=14][/SIZE][/SIZE]
    [size=14][size=14]Added toggle for superuser statusbar icon
    Synced CM source[/SIZE][/SIZE]
    [size=14]06.02.2015 [Build 15]
    Ambient display adjustable timeout
    Disable QS access on lockscreen
    Linked back button app kill in Buttons settings and Developer options
    Synced CM source. New features include:
    Nav ring customization
    20150131 [Build 14]
    Added LockClock shortcut to settings (More settings, under personalization)
    Removed duplicate brightness control and notification count settings
    Changed ROM zip name (less confusing)
    Nav bar customization
    More QS tiles
    Expanded desktop
    20150124 [Build 13]
    Removed new CM clock mod (kept Slim version)
    Updated notification tile settings code
    Synced CM source
    -Huge changelog
    -Many features added
    20150121 [Build 12]
    Rebase to CM12 (i.e. starting from scratch)
    ROM and kernel compiled with Linaro
    Clock and date customization (Slim)
    SuperSu in settings
    Ambient display
    Proximity wake
    Notifications tile
    Notification tile long-press enters silent mode
    Added LPD wallpapers
    Removed CMWallpapers
    Removed CM OTA updates
    Google Lollipop bootanimation
    Changed some icons
    Many minor tweaks and customizations
    Proprietary vendor blob update
    CPU and memory info (About phone menu)[/SIZE]
    [size=14]
    [Build 11][/SIZE]
    [size=14]Removed AudioFX
    Added DSP Manager
    Battery icon style code update
    Proprietary vendor blob update (lots of changes)[/SIZE]
    [Build 10.1]
    Fixed persistent location icon
    Build some audio libs from source
    Removed AOSP Contacts (again)
    Removed AOSP Dialer (again)
    [size=14][Build 10]
    Added Google Contacts
    Added Google Dialer
    Status bar weather
    QS tiles: Long-press most tiles brings up settings
    QS Notification tile: Long-press enters true silent mode
    Battery icon style code update (still wip)
    Added LockClock
    Switched to CM APNs
    Removed AOSP Dialer
    Removed MusicFX
    More stock Google sounds (added alarms and ui)
    Updated some wallpapers (including new default)[Build 9.1]
    Reverted to Build 8 proprietary vendor blobs
    Removed ConfigUpdater
    Removed Launcher3
    [Build 9]
    Updated to Lollipop 5.0.2 (LRX22G)
    Removed DSP Manager
    Added AudioFX
    Added new music player: Eleven
    Fixed color picker in landscape mode
    Fixed missing OK button for SIM PIN
    Added Google Camera
    Added Google Messenger
    Changed a few app icons
    Removed Google OTA updates
    Removed bug report
    Custom wallpaper chooser
    Sounds added from official factory image
    [Build 8]
    Quick settings disable on secure lockscreen
    Minor tweaks and fixes
    Tethering enabled
    Battery light color options enabled
    Updated proximity wake code
    [Build 7]
    Video now working
    Battery percent option
    QS: clicking on clock or date opens alarms or calendar
    Quick PIN unlock
    Hide alarm icon
    Custom settings update
    Sprint fixes
    20141203
    [Build 6] (view post)
    Updated to Lollipop 5.0.1 (LRX22C)
    Reverted to image-based ROM zip
    (now with 500% faster flashing!)
    Removed Launcher3
    Added Google Home launcher
    Fixed addon.d derp
    Sprint fixes ???
    [Build 5] (view post)
    Improved scrolling cache
    DSP Manager (Settings)
    Clear all recents
    Notification QS tile
    Mobile data QS tile
    Moved SuperSu to Settings
    SELinux status in About phone menu
    CPU and memory info in About phone menu
    Busybox
    init.d support
    Google Camera "green line" video cam fix
    Sprint data fix???
    [Build 4] (view post)
    Added global actions menu
    Quick pulldown: right side
    addon.d support
    File-based ROM zip*
    Removed all GApps
    Added back AOSP calendar & gallery
    Removed Browser, Quick Search Box, Voice Dialer
    [Build3]
    Update to LRX21V [Build 3]
    Custom settings menu
    Volume rocker wake
    Quick password unlock (not PIN - not yet)
    Added AdAway
    Stock boot image (not permissive - no longer needed)
    [Build 2]
    Update to LRX21Q
    Fixed "no recovery" issue! (root now optional)
    Added some text during install
    Replaced MusicFX (for now)
    Added Google Calendar
    Added Google Camera
    Added Messenger
    Added Play Music
    Added Google+
    Added Photos
    20141111
    Initial release [Build 1]
    LRX21O
    No orange status bar / nav bar in battery saver mode (only white status bar icon)[/SIZE]
    6 Mal editiert, zuletzt von Maestro2k5 (23. April 2015 um 23:23)
