[ROM-L][LRX22G] LiquidDark [SaberMode 4.8.4 Graphite GCC]
  • --- Update ---
    LTR-LP-2015-01-23-maguro
    [size=24]Changelog[/SIZE]
    * device/samsung/tuna/
    b4f3c96 Revert "tuna: tune lowmemorykiller for 1gb ram"
    bb579dd Revert "tuna: tune lowmemorykiller values"
    * frameworks/base/
    e788ae2 Revert "Squash revert of caf and add Sony's RRO patches"
    5cfe0b7 Squash revert of caf and add Sony's RRO patches
    11da5fd Height of the bottom navigation bar
    8e9ae00 black notification_overlay icon
    8e05c7b Merge branch 'lollipop' of https://github.com/TREX-ROM/android_frameworks_base into lollipop
    1c4c9d7 new notification_overlay icon
    84a4188 update style (notification text)
    * packages/apps/Settings/
    7999648 settings: navigation_bar_height_min_percent">0<
    01-22-2015
    * android/
    bf7223c cm: Use PCRE and libselinux from CM Github
    * bootable/recovery/
    1965c23 Revert "minui: graphics_fbdev: Fix BGRA panels regardless of depth"
    5e6490b Allow f2fs to reserve bytes for footer when formatting
    09d5866 power: Adjust cpu freq and interactive governor settings
    c038c2d memtrack: Add fake memtrack module to get rid of logcat spam about not being able to load memtrack module
    f060457 overlays: Set ambient display to disabled by default
    cf4c21a BoardConfig: Misc fixes
    * frameworks/base/
    a9164d7 Revert "Keyguard: Create lockscreen weather, move weatherimpl to utils."
    1ed1d63 Keyguard: Create lockscreen weather, move weatherimpl to utils.
    401ce40 SystemUI: reset timeout when expanding volume panel
    1fffdbb SettingsProvider : Add functions for delimited strings
    938e005c frameworks/base : testNoManagedUsersIfLowRamDevice failure
    3dcfe63 Fix null pointer exception in KeyguardUpdateMonitor.
    17370ec SystemUI: Fix the wrong speech in TalkBack application.
    bdbc22d OBEX: Include NameHeader in final PUT Server Response
    d96f882 frameworks/base: Add HVGA camcorder profile
    7cc51e9 AppOps: fix "contact" delete ops check failed
    11f6929 Keyguard: Avoid null pointer exception
    3186b2ca Phone: Sprint MWI Quirk: Phantom message wait indicator workaround (1/2)
    b0c9dd5 Fix warning
    216e307 Prevent copyNativeLib of package scanning to reduce booting time.
    093220e SystemUI: Fix user profile activity overlapped by status bar panel issue
    b68b22f Framework: Fix GSM signal strength
    9743bb7 USB: AppOps: always show "USB connection" when usb connected
    b2da8cc Fix "ghost" weather display in expanded status bar
    21c95bc AppWindowToken: Handling IndexOutOfBoundsException
    8d22aad Clean host static libaapt
    11ae854 Show Optimizing app dialog on first boot
    863c24f ConnectionSettings: Add 4g as connection options for profiles (1/2)
    d9b5051 SystemUI: Create expandable volume panel.
    45785f8 Implement linked volumes and add upgrade path.
    4ed765c Hide GlowPadView warnings
    b013d2c Themes: Restructure resource cache [1/2]
    cc90bfa storage: Don't list removed volumes in storage list
    aff7af4 Delay Explicit GC from the SystemServer.
    4da25a5 [1/3]frameworks/base: add "Accept all files" option for incoming files via BT
    * frameworks/native/
    f489ba3 frameworks/native: surfaceflinger: Add Group cache
    8437d5c sf: Enable tilerender feature only if needed
    * packages/apps/Bluetooth/
    ff411b7 [2/3]Bluetooth: add "Accept all files" option for incoming files
    * packages/apps/Calculator/
    d8e8418 Calculator: Remove unused strings
    cfdbfbb Add some simplified chinese translations
    * packages/apps/Calendar/
    629086e Calendar - Bug fixes in DeleteEvents activity
    836ee44 Calendar : Respond to calendar events share intent
    * packages/apps/Mms/
    e66e51f Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    a1bb02a Revert "Shorten "Quick Reply" string"
    b07ad37 Mms: cleanup resources
    c7f7afb Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    2925096 Settings: Enforce non-blank profile names
    9b1f9fa apn: Update the add actionbar icon
    d096cb1 Settings: MSim: fix carrier name display
    5823ef7 Settings: Improve battery percentage title
    ca507f6 Tablets don't need to link volumes they don't have
    c81a7bc blacklist: make it possible to unblacklist phone/messages via checkboxes
    7e48642 Profiles: Add 4g as connection options for profiles (2/2)
    e974920 Settings: Create unlinked and linked notification & ring volume options.
    4ee7caf Settings: add a way to fill a profile from the current device state
    4a20be5 [3/3]Settings: add "Accept all files" option for incoming files via BT
    * packages/apps/ThemeChooser/
    c099c04 Clean up string resources
    LiquidDark für Nexus 4|Nexus 5|Nexus 5X|Nexus 7|Moto E|Moto E 2015|Moto G 2013|Moto G 2014|Google Android One
    Community G+
  • [size=14]LD-LP-20150129-1938-liquid_maguro & LD-LP-gapps-minimal-maguro-20150129[/SIZE]
    [COLOR=#ff0000]-------------------------------------------------------------------[/COLOR]
    Es ist das letzte Build für Maguro, weil ich es verkaufen werde.
    Ich danke euch für die Unterstützung und Treue zur Rom.
    !!!! F U L L W I P E !!!!
    01-29-2015
    * android/
    70837cb add Wallpapers
    * build/
    df8d8e0 testing end
    b9d502a Update main.mk
    680a506 derp
    fe26e66 testing 2
    ff99327 testing
    79ab865 Download Center: new url gapps and supersu
    feb1890 Update notification icon to new paint bucket
    * packages/apps/Wallpapers/
    53d620b change url to the wallpaper
    09d32bc update Url
    19332e6 Update thumbnail.xml
    53b1bfe change name (strings de)
    b663ce6 change sdcard_dl_location
    c50b530 change name
    * system/core/
    13d53a4 fs_mgr: Allow ext2/3/4 to mount as ext4
    * vendor/liquid/
    d48f335 change default_wallpaper for low Display
    3c41dd5 build Wallpapers
    01-28-2015
    * android/
    ba5504d Revert "add updater"
    1afe918 add updater
    * build/
    53c5157 derp
    de9ab38 fix dalvik
    f33c902 Dalvik: disabling verify-bytecode
    11283fb derp
    897c660 fix 2
    5f004fb fix
    662f1ad fix build error
    6768acc derp
    15eff11 change ASCII art
    a0242b0 change script.Print
    * frameworks/base/
    d69f84c Update styles.xml
    fd6cafb Update colors.xml
    976b549 notification_guts_text_color
    e0d7c63 Fix for corruption when numFds or numInts is too large.
    3250a13 Surface: Ensure synchronisation of copyBlt
    e7e6006 Surface: Always consume fence fd in queueBuffer
    0ef3f49 settings: update logo
    7a43a1b Revert "add updater 3/3"
    231f04a Revert "Update device_info_settings.xml"
    9d96f6b settings: change logo
    d5fbd22 Update device_info_settings.xml
    a9658cf add updater 3/3
    445e464 change Download Center strings
    7a31b60 Remove SL gapps add SuperSu in Download Center
    25acd16 new Uri SuperSu
    5a2ab7d Rename L-TR Downlaods in Download Center
    38163bb add Slim gapps (beta) for lollipop in Download Centere
    f2a14c1 clean up "Download Center"
    9d024da remove xposed
    f1b2298 Downloads to trex
    dfd80e8 LiquidSmooth Download Center
    * system/core/
    b08cf09 android_reboot: execute recovery pre command while rw mounted
    * vendor/liquid/
    f0e7b8b Revert "add updater 2/3"
    f81d1d5 change default wallpaper
    3721fe4 more fix backup on dirty flash
    2682f63 add updater 2/3
    01-27-2015
    1fc30d3 recovery: fix another misspelling of "file_blocks" as "block_size"
    1c271df Switch to arm-eabi-4.8 (SM)
    * external/icu/
    dc29137 Updated ICU stub data file
    cec6820 icu: Add Luxembourgish ICU files
    8384da6 icu: Add Asturian ICU files
    * frameworks/base/
    0a200ec Telephony: Add getLteOnGsmMode() method (1/2)
    f3f079f Revert "WindowManagerService: Fix On-Screen keyboard popups when hw-keyboard is present"
    908d252 Themes: Check common resource paths at java layer
    073dcc1 Themes: Allow setting a default theme
    ba27f98 Themes: Watch all app crashes for problematic themes
    4c0adc9 Move non-AOSP symbols to liquid_symbols.xml
    4877664 Revert "Remove CM Theme Engine"
    2b52465 Revert "Squash revert of caf and add Sony's RRO patches"
    04a65f9 change android-logo-mask
    ebbdb55 Revert "SurfaceFlinger: Make secure display ifdefs more narrow."
    * hardware/libhardware_legacy/
    f7d1831 wifi: add semco for Samsung BCM43569
    * kernel/samsung/tuna/
    ca31951 tuna: add back vmalloc=768M
    * packages/apps/Contacts/
    652b1f0 Contacts: Impove CAF strings
    aa1856f Remove leftover blacklist code
    423309e Revert "Support adding contacts to blacklist and whitelist"
    e42b291 Contacts: fix exporting SIM contacts the first time
    78b0971 Contacts: move CAF strings to cm_strings
    * packages/apps/ContactsCommon/
    2e4215a Add overloads to scaleIn() and scaleOut() to receive an AnimationCallback
    a5a5514 ContactsCommon: fix exporting SIM contacts the first time
    31ecfcf ContactsCommon: move CAF strings to cm_strings
    * packages/apps/Dialer/
    c8dc1f6 Fix animation glitch
    a734e17 Remove extra call stats header
    80b9314 Fix regression in recent call filtering
    9d0c786 Port "filter by date range" from call stats page to call log
    66d8527 Revert "Dialer: support "add to black/white list" in call detail"
    5cd5092 Dialer: Remove Chinese CAF translations
    df243b3 Dialer: Improve CAF strings
    31e715a Move string addition to cm_strings
    5f82c37 Dialer: Fix T9 for Hebrew
    8221808 Return match positions to enable highlighting for CN smart dial
    b9ad8d4 Add setting for t9 search input locale
    370bd0b Read option for t9 search input locale and refresh smart dial db when locale changes
    581d9c7 Dialer: Refactor SmartDial for additional languages
    622908f Add Korean smart dial map
    d562d46 Hebrew T9 for Dialer
    c40c4d4 Dialer: Add Greek T9 support
    13f765f Russian T9 for Dialer
    c113b00 Separate blacklist from missed filter in history/stats
    f929e82 Merge code and add CallStats in multi sim
    fa4cea8 Dialer: move CAF strings to cm_strings
    8498d99 Dialer: modify AOSP RU translation
    * packages/apps/InCallUI/
    c8366f8 Contact details on incoming call (1/2)
    c23d203 InCallUI: Use correct string for blacklist menu action
    14b8ffc Fix up cm_strings structure
    41d4872 InCallUI: move CAF strings to cm_strings
    c556b10 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    * packages/apps/PhoneCommon/
    83e6244 Add AnimationCallback parameter to scaleIn() and scaleOut()
    166b7e2 PhoneCommon: Set untranslatable
    8dd2840 Refactor dialpad layout to support t9 search in multiple languages
    3ed02ab Fix up cm_strings structure
    b03df24 PhoneCommon: move CAF strings to cm_strings
    * packages/services/Telephony/
    7a64ef0 Phone: Enable LTE for GSM LTE phones (part I)
    * vendor/liquid/
    9a2086c Revert "Add basic Layers Permission and prebuilt apk"
    9dc7b93 new notifications sound (dinosound)
    01-26-2015
    * external/bluetooth/bluedroid/
    4aad8dc bluedroid: Fix CAF commit 25c965cdcd99f1e495284802785cfb104b19b05c
    * frameworks/av/
    a6ab7f8 Fix id3 parser crash
    1d44178 Fix bugs don't remove track of DirectOutputThread
    3ed4ff8 Fix bugs regarding looping play issue with sharedBuffer
    0b97100 stagefright: add Samsung S3D support
    * frameworks/base/
    bf38956 change LiquidDark logo mask
    e9c1c6b black notification_overlay icon
    * frameworks/opt/telephony/
    549c941 Telephony: Add getLteOnGsmMode() method (2/2)
    * hardware/ril-caf/
    e43a8f1 rild: enable tombstone on RIL crash
    * kernel/google/msm/
    43b4486 flo: disable radio iris
    9b33598 Handle change from boolean to int preference
    * packages/apps/DeskClock/
    26aa536 Automatic translation import
    88f8801 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    f0d411a Set notification color.
    c1e616a change strings
    83abef9 Switch to new Logo (settings)
    819d387 SuperSU change in setting menu
    * packages/apps/SlimLauncher/
    6ccc41f Automatic translation import
    * system/core/
    74b61dd healthd: remove useless gotos in set_backlight_on
    e978018 healthd: fix LED color on 100%
    210b74a healthd: more descriptive LED path opening error message
    9942c54 healthd: remove useless goto in charger mode
    * vendor/liquid/
    c2495f8 Merge branch 'lollipop' of https://github.com/t-rex600/android_vendor_liquid into lollipop
    4215bd2 new default Wallpaper
    01-25-2015
    * android/
    0ee5703 remove Anonymous Stats and updater 3/3
    7bca10a Update README.mkdn
    d5202ba Fixes BLE remote device address type after LE connection
    * external/ffmpeg/
    4f1bd57 Clean up some build-time warnings
    * frameworks/av/
    6195593 nuplayer: Add cached lookup of track duration
    918ae2c audio: Support for compress offload recovery
    644eec2 Revert "Track volume should be maintained even if track is restored."
    * frameworks/base/
    8869b7a SystemUI : Move shortcut helper instantiation before updateVisibility
    dac852f SystemUI: Lockscreen shortcut customization
    95413a7 DcTracker: Handle null waitingApns properly
    d9ee106 Settings : Lockscreen shortcuts
    c1b0a29 update Theme Icon Color
    44bcb50 Revert "Remove Theme settings"
    d4ec59f remove Anonymous Stats and updater
    * packages/services/Telecomm/
    e945528 Add back phone notification LED settings backend (1/2)
    680b920 Telecom: Don't connect bluetooth audio when incoming call is answered.
    * system/extras/
    f0f66cd mkimage for OMAP
    * vendor/liquid/
    4646ff5 Fix Build error
    19abf8f derp Sony Bravia
    d67011c Add S4's
    f1df303 remove Anonymous Stats and updater 2/3
    f00b99a new release Name (zip) LiquidDark
    2c7fdb4 remove Anonymous Stats
    8d1a6ee X-Reality
    8502c1f Build without BOOTANIMATION
    fb1a30e update SuperSU 2.45.zip
    01-24-2015
    * android/
    8451b90 Fix Provider Contacts
    cf6c6b4 derp
    699c1cc README: to dark
    ed08fea mtdutils: Fix mounting partitions by-name
    66c8cfd recovery: Fix a couple bugs in sideload cache logic
    * external/strace/
    c478edc Build a static strace utility
    * frameworks/base/
    90e880f white text in Notifications window
    df2d2da Dialog Material Dark UI showBootMessage color black
    74c318b Revert "Revert resource themeing in preparation of CM-12.0 theme engine"
    62ad804 WindowManagerService: Fix On-Screen keyboard popups when hw-keyboard is present
    ac1acbb bootanim: Add continuous splash support
    741a356 libgui: add support for Samsung external gralloc usecases
    * hardware/qcom/audio-caf/msm8974/
    5ef2da5 msm8974 hal: Remove platform and baseband check for CSD init.
    e1b2003 Calendar: Add some simplified chinese translations
    806cf8a settings: navigation_bar_height_min_percent to null better for SlimPIE
    30d9872 Revert "Revert resource themeing in preparation of CM-12.0 theme engine"
    4c3d5b0 Revert "Settings: Use a higher quality image"
    01-23-2015
    * android/
    bc17e60 Dark UI repos to trex
    7fef682 Device to trex
    739d7ee Base repos to trex
    81bc4b7 Update README.mkdn
    0e73b8c Update README.mkdn
    c0eb001 update Readme LiquidSmoothBlack
    9bd0e7b Go back to tracking upstream repos now that we have dark theme reverted
    744ec25 install: Allow f2fs to reserve bytes for footer encryption
    980fb9c Calculator: add CN translations
    651f0ce Calendar - Fix the title in Year View on tablets.
    4c021e1 Remove Theme settings
    5729c6c Revert "Contacts/Dialer/InCallUI: Dark theme, (7/7):"
    35bc50a Contacts/Dialer/InCallUI: Dark theme, (7/7):
    6ed2756 Remove hard-coded CDMA roaming mode restrictions.
    * vendor/liquid/
    c4abc63 change release Name (zip)
    Community G+
  • Funktioniert das laden jetzt eigentlich, wenn das Handy aus ist? Und gibt es noch ein fix zu den dark gapps?
    Ob das Handy geladen wird, weiß ich nicht, es wird nur ein nicht animiertes Batterie-Symbol ohne Prozente angezeigt. Beim Anschließen des Kabels im ausgeschaltetem Zustand lädt das Handy öfter ins Recovery Modus... Dark Gapps funktionieren auch nicht. Man könnte aber Google Play Dienste flashen oder zu flashende Gapps mit APK ergänzen, dann können alle Apps installiert werden. Ich habe das aber nicht getan. Gegen die Werbung habe ich Adaway installiert.
    Also, stabil ist die ROM nicht, es gab schon öfter freeze und Abstürze.
    Ich wünsche Dirk viel Erfolg und glaube, dass die Ära meines gnexe langsam endet... Auf Stock zurück und verkaufen. )
  • update
    [size=14]LD-LP-20150222-1424-liquid_maguro[/SIZE]
    [size=14]Ich habe ein Build compiliert für maguro aber nicht getestet, müßte aber laufen :thumbup:[/SIZE]
    c19bc64 tuna: switch to dlmalloc
    aabad7b omx: remove duplicate OMX headers and refer to originals where needed
    dd65eb2 tuna: add dumpdcc
    12223f3 tuna: new custom toolchain fixed toolchain prefix
    02-21-2015
    * external/libpng/
    b2ac695 More spam
    * frameworks/opt/net/wifi/
    8fd5ac8 WifiStateMachine: Tone down logging
    * hardware/qcom/wlan/
    d3701c8 qcwcn: Tone down logging
    * system/vold/
    e207e22 vold: cryptfs: Check return values
    02-20-2015
    eb41137 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    70b0d37 Per conversation notification settings/ringtones
    1080bb1 Mms: Port custom notification vibrations
    * packages/providers/ThemesProvider/
    fe573ef close cursors when through with them
    02-19-2015
    3e62590 bluetooth: a2dp: Fix return value from out_set_parameters
    83824ce bluetooth: Reduce logging verbosity
    * frameworks/base/
    662da0c Headsup: squashed update (1/2)
    0be838e eCryptfs: Remove buggy and unnecessary write in file name decode routine
    1d91c65 netfilter: conntrack: disable generic tracking for known protocols
    8a0f46e Automatic translation import
    * packages/apps/BluetoothExt/
    2caafde Automatic translation import
    dac2b10 Automatic translation import
    797c203 Automatic translation import
    * packages/apps/Camera2/
    d0e8547 Automatic translation import
    * packages/apps/CellBroadcastReceiver/
    f33bd50 Automatic translation import
    * packages/apps/Eleven/
    fd06a77 Automatic translation import
    * packages/apps/Gallery2/
    6df83bf Gallery2 - Add support to pass in a playlist along with video to play
    0b4fd45 Automatic translation import
    a67f0c1 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    3321ba0 Automatic translation import
    3c25a41 remove nonsensical file
    55b7abf Headsup: squashed update (2/2)
    * packages/apps/SoundRecorder/
    a05a722 Automatic translation import
    * packages/apps/Stk/
    49f9566 Automatic translation import
    * packages/apps/Terminal/
    589aa46 Automatic translation import
    bada620 Automatic translation import
    * packages/apps/UnifiedEmail/
    244c1b2 Automatic translation import
    * packages/providers/DownloadProvider/
    f16323c Automatic translation import
    09d05e9 Automatic translation import
    * packages/services/Mms/
    8d5b7bd Automatic translation import
    f67e928 Automatic translation import
    * packages/wallpapers/LivePicker/
    75d5257 Automatic translation import
    * prebuilts/gcc/linux-x86/aarch64/aarch64-linux-android-4.9/
    043743c 02-18-2015
    02-18-2015
    fff47ff bluetooth: a2dp: Fix autostart failure due to transient incall error
    4a7b0de bluetooth: a2dp: Don't drop PCM data when limiting data transfer rate!
    0c3a3f1 bluetooth: a2dp: Properly shutdown datapath on write failure
    45e877a bluetooth: Fix race condition in GKI timer callback
    7de248b bluetooth: Use /dev/alarm (if it exists) for monotonic us time
    * frameworks/base/
    d01998c Expose call creation time to link call recordings with recent call log (1/2)
    18cf350 Revert "Keyguard Landscape: Fix Glowpad and SIM Pin Layout for sw360dp devices"
    * hardware/qcom/keymaster/
    ca6561a keymaster: Export HEAP_MASK flag for msm8610 target
    5215e13 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    e88a890 Update other_sound_settings.xml
    26042b8 remove
    a422cdc derp steps
    c14bc95 Update sound_settings.xml
    08371b2 fix volume steps
    95ace59 Allow theming status bar and nav bar separately
    45bef2f Remove checkboxes for components that are not in the theme
    e55256b Move checkboxes for applied components under a 'Applied' header
    ad39a70 Don't add applied components and disable their checkboxes
    725d76f Expose call creation time to link call recordings with recent call log (2/2)
    ... and more
    Community G+
  • update
    LD-LP-20150305-1546-liquid_maguro
    * frameworks/base/
    7312468 Themes: Add config change flag for font change
    bcd1f18 Themes: Drop timestamp and add change request type
    ae6e01d Themes: Add RequestType to ThemeChangeRequest [1/3]
    793b50e Themes: Use ThemeChangeRequest when resetting theme
    587d194 Themes: Update ThemesContract with install state [1/3]
    394917c Add customization for Quick Settings [1/2]
    808b1f9 Revert "Themes: Make resolver list fully themeable"
    8712124 SystemUI: Remove redundant and broken setText on temperture view.
    22db847 Keyguard: Create lockscreen weather, move weatherimpl to utils.
    aef66c0 Themes: Make resolver list fully themeable
    7326f4c Themes: Making DocumentsUI fully themeable
    fcde574 Merge 'fix'
    66370a0 Themes: Check if updateConfiguration should be called
    be00667 Close zips when through with them
    * packages/apps/LockClock/
    f41e624 cLock: update to a new material icon
    7c43941 Automatic translation import
    827e300 Automatic translation import
    c0fbde3 Automatic translation import
    7579cd2 settings: Darker UI customization for Quick Settings
    05e38f5 Add customization for Quick Settings [2/2]
    03-04-2015
    f7afaa4 bluedroid: Add wiimote pairing support
    415bfa7 bluetooth: a2dp: Rework locking
    * frameworks/av/
    79c1aca libmedia: Fix crash during mediaserver restart
    99c8319 mpeg2ts: Add support for parsing HEVC stream in MPEG2 TS container
    61b2505 nuplayer: Fix crash in video only HLS streams
    14bb487 libmediaplayerservice: update NuPlayer scoreFactory for http://
    bc07960 audio: Handled openOutput error for Tunnel/LPA Usecase
    5dee3bc audio: Set OutputFormat of AudioMixer to PCM16
    cccb375 audio: Fix issues during device switch
    26e81b1 audio: Fixed mBytesRemaining when partial buffers are sent
    6acc081 stagefright: use NuPlayer for http://
    7cbaf6f audio: Send USB connection events only for USB accessory
    bc0a8f4 audio: Added fallback mechanism for Tunnel Mode
    * frameworks/base/
    eecb0ba fix Build error
    797b3d7 DisplayDevice: Backwards compatibility with old EGL
    1093935 libgui: squashed update for readding ICS and JB_MR0 support
    * hardware/libhardware/
    57bf795 fix: memory leak
    8c03bb6 Make calculator behavior more predictable
    a70bd84 BASH-25: avoid NPE on Calculator's widget
    eee6374 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    7292dca Mms: move mailboxmode classes to the proper location
    e9c6085 Themes: Add RequestType to ThemeChangeRequest [3/3]
    cebe749 Themes: Add RequestType to ThemeChangeRequest [2/3]
    d56651e Themes: Update ThemesContract with install state [2/3]
    03-03-2015
    35ef108 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    73cf152 Themes: Update ThemesContract with install state [3/3]
    59c6157 Add value for TARGET_API in insertSystemDefaults
    03-02-2015
    * external/e2fsprogs/
    23e9eca resize: allow static build
    d4cf4d4 Merge branch 'cm-12.0' of https://github.com/CyanogenMod/android_packages_apps_Mms-caf into lp5.0
    57cde33 Restore old tap-to-wake state after call
    03-01-2015
    * frameworks/av/
    96eb154 NuPlayer: Buffering improvements for http progressive playback
    28a2460 MSIM fixes.
    ... and more
    Community G+
