[Kernel][Shamu][5.0..x] Franco kernel r26[13.04.2015]
Und schon sind wir bei r16.
ZitatZitatr16"changeDate="Feb 16, 2015">
Bug fix! Fixed a bug introduced on r15 that could panic the device when it reached low battery threshold
Improvement! Decreased wlan_rx wakelock timeout
Improvement! Merged an improvement from CodeAurora regarding the DSP for audio listening
Improvement! Don't start evaluating CPU load until the device has fully booted
Bug fix! Fixed a bug that could lead cpu2 and cpu3 to be stuck on max frequency -
R17 ist da.
Pushed r17 which fixes the cpu0 bug **** and fixes a performance regression on sequential read speed. -
R18 überholt rechts...
...überholt links?
R19 war ein Renault, und der überholt bestimmt gar nicht[emoji24]
:D:D:D:D:D:D
r21 is out!
* Improvement! Improved behavior of my Hotplug driver by increasing the time between work runs to decrease load average
* Improvement! Add headphone and misc gain boost interface. Available from FKUpdater or sysfs path: /sys/class/misc/soundcontrol/
* Improvement! Add support for custom roms - systemui shouldn't crash anymore
* Improvement! Merged a patch from Motorola to decrease suspend latency
* Improvement! Merged a patch from Motorola to decrease latency when low memory killer scans through all processes to decide which one to kill
* Improvement! Merged a patch from Qualcomm to allow the internal storage daemon to schedule requests to idle CPUs to greatly improve I/O performance
* Improvement! Further tune Conservative's behavior by allowing it to scale in 10% intervals instead of the old 5% (so it will reach upper and lower frequencies one or two samples faster) and to start ramping down when the load is below 40% instead of 30% (this improves battery life)
* Improvement! Turned off a couple debugging flags on some drivers to decrease system load on certain periodic requests
* Bug fix! Fixed a bug that was wrongly calculating CPU off time and it was considering it idle time, thus system load was being reported higher than it should
* Improvement! My cat can run up and down the walls like Neo on The MatrixThis is a big update. Enjoy folks!
New franco.Kernel version for the Nexus 6
ZitatAlles anzeigen
* r22
* Improvement! Add support for Multi-Rom
* Improvement! Add ability to disable specific wi-fi wakelocks under /sys/module/wakeup/parameters/ - don't mess with them if you don't know what you're doing
* Improvement! Bump max cpu freq for the Power-saving profile from 1GHz to 1.267GHz and use Performance governor on the GPU on the Performance profile
* Improvement! Decreased load_average by making yet another set of Kernel threads to be interruptible
* Improvement! Merged a gazillion patches from upstream and codeaurora with fixes and enhancementsboot.img: http://kernels.franco-lnx.net/Nexus6/5.1/boot-r22.img
zip: http://kernels.franco-lnx.net/Nexus6/5.1/zip…nightly-r22.zip
Sent from franco.Kernel updater (Update online ...)
#becauseFKU#francoKernel
Hab die neue Version drauf mit der aktuellen Chroma. Und das flutscht... Alles läuft noch ein Tick geschmeidiger. Keine Ahnung woher plötzlich dieser Performanceschub kommt.
Jap, läuft alles super.
Momentan gibt es 50% auf die Franco Kernel App Preisnachlass.
New franco.Kernel version for the Nexus 6 - r26
Zitat* r26
* Improvement! Merged an upstream patch for the cpu scheduler which makes it idle faster if it only has at the most 1 task running on it. This should provide improved battery during usage
* Bug fix! Reverted a patch that could prevent the modem to restart its connection after losing signal
* Improvement! Merged a couple patches from CodeAurora to improve the display drivers layer
* Improvement! Merged other patches from upstream with fixesboot.img: http://kernels.franco-lnx.net/Nexus6/5.1/boot-r26.img
zip: http://kernels.franco-lnx.net/Nexus6/5.1/zip…nightly-r26.zipSent from franco.Kernel updater (New franco.Kernel version for the Nexus 6 - r26)
BTW
Franco hat eine neue App >>
[root] Servicely
https://plus.google.com/+FranciscoFran…sts/S2pyXfbuuMG
https://play.google.com/store/apps/det…ranco.servicelyZitat
Built this little app this past week because I was not happy with the current offering.Compared to Greenify or other xposed modules:
1 - It's free
2 - Kills system apps/services
3 - Better design
4 - Way smaller memory footprint
5 - Runs every X seconds instead of only when screening off. All operations are done on the background thread so system interactivity isn't affectedThere's an option to purchase a "Pro" key, but you can also use all the features for free toggling the right option.
Enjoy, share with your friends!
R27 ist raus
Gesendet von meinem Nexus 6
