[ROM][N5][LINARO GCC 5.1] KangDroid-Project!
  • Zitat
    This rom is based on CyanogenMod12.0, Modified by KangDroid.(Which is my Nickname.) I added some function based on CyanogenMod, but not stabilized. This rom will be update normaly every day(if there is no CRITICAL problem.). If i didn't upload a rom, it means there is a terrible thing on rom. Please use nicely and usefully!
    Screen Shots
    "klick"
    How do I install?
    You have to sure that it is for ONLY FOR NEXUS5(Hammerhead) and you have to install one of these recovery:CWM/TWRP/Philz/etc...
    Install from OTHER ROM
    * Boot in to Recovery mode
    * Backup if needed.
    * Wipe system/data/Cache (Factory reset is also welcome!)
    * Choose ROM which I attached.
    * Install with Gapps
    * Boot, finish. Simple!
    Install from THIS ROM(Version update)
    * Backup if needed.
    * Wipe Dalvik-cache, Cache(U can do Factory reset if you want)
    * Flash ROM & Gapps
    * Boot, Finish!
    Download´s
    ROM
    [size=14][COLOR=#ff0000]Development DB Only Available in the 2013 or 2015 XDA Style[/COLOR][/SIZE]
    XDA Forums
    Gapps Sammlung
    SuperSU Stable & BETA
    CM Themes Sammlung
    NOTICE: I changed to XDA Downloading! Enjoy Stable Downloads! And you can find previous version at the very end of bottom. All New versions could found in This Forum.(Also Previous version too!)
    Functions in this ROM
    *CyanogenMod Default Function
    * Lockscreen Shortcut Control
    * Quick Settings Reorder/Delete/Adding!
    * Quick/Smart Pulldown
    * ListView/Toast Animation/AOKP System Animation
    * Navbar dimensions control/Double tap to sleep
    * Some Recents Panel Option:SearchBar or recent button on NavBar
    * OmniSwitch Support(You can choose in Settings)
    * Screen Recorder
    * Gesture Anywhere
    * WakeLock Blocker
    * Ad Blocker
    * and A lot of stablization(Color Fade in Frameworks) and A lot of Optimization.
    * And more and more...
    Changelog
    See more ChangeLog in https://github.com/KangDroid !
    Credits
    "Klick"
    * CyanogenMod --> https://github.com/CyanogenMod
    * Liquid Smooth --> https://github.com/LiquidSmooth
    * PAC-man --> https://github.com/PAC-man
    * CrDroid Android --> https://github.com/crdroidandroid
    * Faux (kernel) --> https://github.com/faux123
    * ResurrectionRemix --> https://github.com/ResurrectionRemix
    * CandyRoms --> https://github.com/CandyRoms
    * Slim Roms --> https://github.com/SlimRoms
    * TemaSek --> https://github.com/temasek
    Thanks to these People/Teams and missing people too!
    If there is any problem, Please post in reply or Email to kangdroid@naver.com.
    [COLOR=#ff0000][B][B][B]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.[/B][/B][/B]
    [B][B][B][B]ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/B][/B][/B][/B][/COLOR]
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
    9 Mal editiert, zuletzt von MuggelPu (26. April 2015 um 01:43)
  • Build12_20150118Late online
    STOCK
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM & OP Update!
    Build12_20150123Late
    Notice: I haven't tested yet. Please report bugs if you have any bug or else.
    ChangeLog
    Bug&Big Update: Please Factory reset before you flash this rom.
    Bump version to 2.1
    Up-To-Date All function, merge CyanogenMod.(Up-to-Date with CyanogenMod, Fix CM Things Themes...)
    Frameworks: More stablize
    Frameworks & Settings :[COLOR=#ff0000]PIE Control[/COLOR]
    Frameworks & Settings: EuroPhia OS QS Settings(abit)
    Settings: Fix entry for Keyboard Settings
    Settings: A lot of Korean Translation
    Settings: More LCD Density Entries
    See details on Settings-->DeviceInfo-->ChangeLog
    candy5-RC.v0.9.4-20150124-OFFICIAL-mako.zip
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM & OP Update ;)
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • [size=18]KangDroid-Project! 2.5 Build13_20150208 Late[/SIZE]
    ChangeLog
    Bump version to 2.5
    Common: Merge CyanogenMod.(Commit ALL CyanogenMod Changes)
    Frameworks & Settings: Up-To Date Nav Ring customization
    Frameworks & Settings: Add timeout option for Heads Up
    Frameworks & Settings: Ability to disable a lockscreen shortcut
    Frameworks & Settings: Navigation bar button color
    Frameworks & Settings: "Touch to hide" for Heads Up.
    Frameworks & Settings: Navigation Bar Button color Customization(See BugList)
    Frameworks & Settings: Add Haptic Feedback when touch QS Tiles(You can disable at Notification Drawer Settings.[QS Settings] )
    Frameworks & Settings: Remove Function:LS Weather Disabler/enaber
    Frameworks & Settings: Remove Function:Hide Camera and Dialer Button
    Download
    kdp-2.5_20150208-UNOFFICIAL-hammerhead.zip
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Build14_201502010Late
    Notice: I haven't tested yet. Please report bugs if you have any bug or else, Screenshot will be updating on my KDP Facebook page. Not here,(It is too hard to update regularly)
    7
    FaceBook Page Opened! You can also see update and working progress, and changelog and Screenshot there! FaceBook Link
    ChangeLog
    "Klick"
    V2.5_0210:
    Common: Security En-Hancement.
    Frameworks & Settings: Trying to fix screen shot sound settings, Fixed in Sound/OtherSounds Settings
    Frameworks & Settings: Re-Update Option to disable search bar in recents, and Fix SearchBar "doesn't show".
    Frameworks: QS Tile Stablization.
    Frameworks & Settings: QS--> Option to show four tiles per-row.
    Frameworks: Re-Work Battery saver bar color feature.
    Frameworks & Settings: Add Battery saver, Brightness, sync, ScreenShot, Screen-Off, Expanded Desktop and some more toggles.(Just Add A lot of toggles)
    kdp-2.5_20150210-UNOFFICIAL-hammerhead.zip
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    Einmal editiert, zuletzt von MuggelPu (12. Februar 2015 um 19:54)
  • Build15 20150215-Late
    7
    Sorry for late update Uploading speed was tooo slow..
    ChangeLog
    "Klick"
    V3.0_0214
    Common: Bump to V3.0
    Frameworks & Settings: StatusBar Greeting
    Frameworks & Settings: No more DOZE, Now "ACTIVE DISPLAY" --From Omnirom(Including pocket mode etc..)
    Frameworks & Settings: Add the ability to hide superuser status bar icon(WARNING: USE AT OWN RISK)
    Settings:Re-Arrange Settings(Quite a lot of settings are re-organized: Spent 3h for this)
    Settings: Add KangDroid-Project Info Settings(Spent 8h for this today)
    kdp-3.0_20150215-UNOFFICIAL-hammerhead.zip
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Build20 20150305-Late & OP Update ...
    ALSO, Update Progress or Notice will be on FaceBook. DO NOT ASK ME ABOUT WHY THERE IS NO UPDATE. REASON WILL BE IN THAT PAGE.
    ChangeLog
    "Klick"
    V3.8_20150305
    Common:
    Update OtaUpdaterCentre(Some credits!)
    Up-To-Date CyanogenMod
    Enabled Call Recording(YES!!!!!)
    Direct Call
    Settings(Fixes):
    Force Expanded Notifications
    Greeting label timeout
    Re-Implement QS Colors
    QS colors master switch
    Add QS: Ambient Display
    Smart Control centre(In Main KDP Settings) and Direct Call
    Frameworks(Improve of System):
    Common Frameworks--> Improve System
    Enabled Call recording in Frameworks
    QS: fix qs main tiles settings not refreshing tiles
    QS: add a little delay when toggling expanded desktop
    Direct Call
    Option to ignore the last app when clearing recents.
    Notice:
    1. You have to Enable Advanced mode to enable KangDroid-Project Settings.(You will see changes after release.)
    Advanced mode is in:Settings/Device Info
    2. KangDroid OtaUpdater Was added, Therefore, XDA Thread will update once a week, but OTA Will update daily or 1times per 2days. SO PLEASE UPDATE TO THIS VERSION AND GET A OTA. DO NOT SAY ME WHEN IS UPDATE.
    3. There will be a update tomorrow, Make sure you set to Root permission to 'ADB and Application' not only 'Application' and DO NOT SELECT ANY OF OPTION LIKE WIPE CACHE OR DATA. RECOVERY WON'T FLASH ANYTHING.
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • ROM (Stable Version RC1) & OP Update ...
    "Info & Changelog"
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Des nenn ich mal Update ... u.a. >> GCC5.1 / OTA Funktion uvm.!
    STABLE-BUILD2 20150501-Late
    Notice: No bugs so far. Please report bugs if you have any bug or else. OTA Updater has been Added. Update will available for Every Monday Wednesday and Saturday.
    MUST_READ:
    Beta Release willONLYon Project FACEBOOK and OTA, Every Monday and Wednesday. With Short ChangeLog. Stable Build (which is Saturday's version) will come out every saturday, in Facebook/OTA and XDA.
    Notice:
    1. OTA Just added. This OTA Will update ROM every Monday, Wednesday, even RC Version, Saturday.
    2. OTA Updater is in: Settings --> Device Information --> KangDroid-Project Information --> Update KangDroid-Project
    Download @ xda
    kdp-5.3-RC2-20150502-hammerhead.zip
    BIG Thanks to: @Kryten2k35 for origin of OTA Updates App Source Code.
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
