[ROM & KERNEL][HH][5.0.2] crDroid Lollipop [20150227]
  • crDroid is designed to increase performance and reliability over stock Android for your device also attempting to bringing many of the best features existent today. We're mainly based on CyanogenMod so use custom kernels compatible with them!
    #include
    * Your warranty is now void.
    * I am not responsible for bricked devices,
    * thermonuclear war, or you getting fired because the alarm app failed. Please
    * do some research if you have any concerns about features included in this ROM
    * before flashing it! YOU are choosing to make these modifications, and if
    * you point the finger at me for messing up your device, I will laugh at you.
    All the source code for crDroid is available in the Github repo. And if you would like to contribute feel free to pull a request.
    "Rom features"
    • Nav bar tweaks (on/off toggle and custom dimensions);
    • Battery text mode (from cm);
    • Battery icon options (from cm);
    • Media scanner behavior on boot;
    • HSPA + icons on status bar;
    • SlimRoms heads up customization;
    • Traffic metter on status bar;
    • Gesture lockscreen;
    • Gesture anywhere (launch apps and activities from custom gestures);
    • Weather display on expanded status bar;
    • Wakelock blocker;
    • Left handed navbar option;
    • XuiMod toast animations;
    • AOKP custom system animations;
    • App circle sidebar;
    • CPU info overlay option in development settings;
    • [Connect/disconnect notification support;
    • Long click support on quick settings;
    • Screen recorder;
    • Animated rotation tile;
    • Wake up on plug;
    • Development shortcut;
    • Performance settings from CyanogenMod;
    • Clock and time clickable in expanded status bar;
    • Notification ticker;
    • Quick unlock;
    • PIN keypad shuffler;
    • Custom lockscreen shortcuts;
    • Answer calls with hardware home button;
    • Status bar clock tweaks (right, center or hide clock with many dates formats to show. Custom colors included);
    • Notifications counter;
    • Volume keys wake the device;
    • Ability to hide the alarm clock icon from status bar;
    • Dialer Lookup;
    • Profiles form CyanogenMod (new merges and lollipop style);
    • Protected apps (using trebuchet launcher);
    • Filter spam notifications;
    • CyanogenMod SuperUser;
    • Clear all button in recent panel with custom option (hide, top right or top left);
    • Disable search bar in recents;
    • Privacy guard from CyanogenMod with new Superuser access through it!!!;
    • Ability to hide superuser status bar icon;
    • Quick settings pull down with one finger (right, left or off);
    • Smart pull down;
    • Configurable 0, 90, 180 and 270 degree rotation;
    • Toggle to not allow quick settings on secure lockscreen;
    • Brightness control through status bar;
    • Double tap status bar sleep;
    • Data activity indicators;
    • Call blacklist support;
    • Increasing ring tone;
    • In call vibrations;
    • Ambient display (DOZE features);
    • Advanced reboot menu;
    • Option to hide adb notification;
    • Screen shot quick delete with confirmation;
    • Long press back to kill with configurable timeout;
    • Volume button custom actions (skeep track, wake screen, adjust sound and keyboard cursor control and swap volume buttons);
    • Less frequent notifications sound;
    • Advanced keyboard features (auto rotation with timeout, disable full screen, selector notification, show enter key, volume key cursor control);
    • New Eleven music player and AudioFX from CyanogenMod;
    • Among others. For more infor visit our github
    "Kernel features beyond CyanogenMod ones"
    • Faux sound control
    • Faux fast charge driver
    • Franco Voltage control
    • Sweep 2 wake
    • Sweep 2 wake style
    • Sweep 2 wake / double tap 2 wake power key toggle
    • Prevent touches during phone calls
    • Multi rom support
    Apps you can use to access custom kernel features
    [DLMURL="https://play.google.com/store/apps/details?id=com.dsht.kerneltweaker"]Kernel tweaker[/DLMURL] - FREE!
    Faux clock - PAY!
    Trickster mod - PAY!
    or viist here and choose as your like
    Kernel features can also be activated echoing parameters in right places. It requires a little more knowledge and a script creation to always activated them at boot
    Screenshots
    HERE
    crDroid official website
    http://url%3dhttp//crdroid.org/
    First time installing crDroid to your Nexus 5, or coming from another ROM:
    - Make sure you're running a proper working Recovery (CWM or TWRP)
    - Copy GApps and crDroid zip to your internal SDCard
    - Boot into Recovery
    - Flash crDroid zip
    - Flash GApps zip
    - Flash SuperSU (not mandatory. We have CyanogenMod su access inside)
    - DO A DATA WIPE / FACTORY RESET
    - Reboot
    - Don't restore Apps using Titanium Backup!
    Upgrading from earlier version of crDroid:
    - Copy crDroid ZIP to your internal SDCard
    - Flash crDroid zip
    - Reboot
    Builds and Changelog:
    https://plus.google.com/communities/...03b2d?hl=pt_br
    HERE
    Google Apps:
    HERE
    Don't expect any support if you:
    - are not running stock crDroid-kernel
    - have installed any mods such Xposed!
    - have modified system files
    Special thanks:
    - Google
    - CyanogenMod
    - SlimRoms
    - @kufikugel
    - AOSPA (Paranoid Android)
    - OmniRom
    - NamelessROM
    - @0xD34D
    - @temasek
    - @faux123
    - @show-p1984
    - @neobuddy89
    - @flar2
    - @Tasssadar
    - @Mazda
    - Many others... (if you're feeling upset being out of the thanks list just send a PM )
    Mazda
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    [size=14]~~~~~~~~~~~~[/SIZE]
    4 Mal editiert, zuletzt von MuggelPu (24. Januar 2015 um 21:57)
  • ROM & OP Update ...
    New build is up and with a TON of new features: https://plus.google.com/+CristianoMatos/posts/fPCVaMJbTt6
    Now the changelog is a download txt file with 100% of Info's.
    Enjoy!
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Spoiler anzeigen
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
    crdroid-5.0.2-20150207-hammerhead -> Download
    Changelog -> Download
    https://plus.google.com/11595262895995…sts/GzDL37dqwus
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Update ...
    crdroid-5.0.2-20150219-hammerhead -> Download
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
  • Zitat
    Following my way of think and also my hidden compromise with all users, I'm here to inform that crDroid will soon die.
    I'm really glad for a ton of friendships made in android world and a bunch of real good friends!
    Thanks to all of you boys and girls
    I'm not having fun anymore and it means I need to stop
    I really wish a best life to all of you!!!
    https://plus.google.com/+CristianoMatos/posts/fZF4hiGP9y7
    Nextbit Robin
    Nexus 5X
    Nexus 9
    SHIELD TV
    Chromecast
