naja, jetzt zu spät, aber egal. beim nächste mal dann neue
Diskussion zu GApps aka "Gapps Sammlung"
...ich habe auch keine Probleme mit denen vom 16.05.
Slim Mini Gapps
Weiß zufällig jemand, warum alle Websites für die Slim Gapps keine Gapps mehr drin haben? :confused:
Es werden gerade neue gebildet, darum sind die Seiten leer.
Perfekt. Danke
Banks GApps Update
5-19-15
-Google Play Services 7.5.62 (1927436-43*)
-Removed 160 density for arm Google Play Services becuase there isn't a valid Google Play Services version for it so it will get universal
-Removed Google Play Services -470 version because it is for x86 targets
-Moved -430 to arm Google Play Services universal as the proper one for itDownload
http://fitsnugly.euroskank.com/?rom=banks&device=gapps
BaNkS-dynamic-gapps-L-5-19-15
md5sum:a740b7a2bb66d163e0e1c80a1ddbe297
built by: BaNkS -
Banks GApps Update
5-21-15
-Google Play services 7.5.66 (1939950-43*)5-22-15
-Google Play Services arm64 fixes
-Remove newer versions of Google App and Google Play Services in /data exists -
Gapps von [size=14]Chet Kener - DL Link im Zitat...[/SIZE]
ZitatSTOCK N5 Based Gapps - May 21, 2015
Hey folks, so due to the latest weird things happening with Play Services I've taken the time to extract a minimal gapps packages out of the N5 5.1.1 LMY48B factory image. This may seem ironic but even though this is from the factory that came out yesterday all of these apps are already out of date. HOWEVER, I have had no FCs after upgrading all of my apps so long as this gapps package is found in my system. This gapps packages WILL require a CLEAN INSTALL if coming from other gapps and is only meant for the Nexus 5. Furthermore, this is not meant to be a permanent solution to the weird Play Store issues this is just a band-aid for the time being.
Thanks to Micheal Banks for the installation and layout which I borrowed from him!
What does this contain?
-Nexus 5 Factory 5.1.1 LMY48B Based Gapps (Not meant for other devices)
-Play Store
-Play Services
-Google App (Search) for "OK Google" everywhere feature
-Core Google syncing apks
-FaceLock for SmartLock feature
-Swypelib
-All files Lovingly Deodexed
-All corresponding libs/files/etc. for the above to work properly
-Nothing more and nothing lessInstructions
1. MAKE SURE YOU WIPE DATA, SYSTEM, CACHE, DALVIK!!!!
2. Flash on your N5 (other devices you can attempt at your own peril) after you Flash the ROM.
3. Live long and prosper!Download Link
Das ist aber sicher nicht multiDpi fähig, oder?
Gesendet von meinem CatHelix
Jein er sagt ja, er hat von Banks Hilfe "erhalten" und seine sind MULTI DPI fähig also würde ich sagen >> eigentlich ja... Aber probiert hab ich die Chet gapps noch nicht.
Gibt auch neue SlimGapps. Keine Ahnung ob damit die Probleme der Playdienste behoben sind.
Elite Test 360Ich hab die Slim Mini vom 15. druff, da klappt alles.
Mirko könntest du mir bitte deine Slim Gapps zukommen lassen
Oder auch gerne hier für jeden.
Irgendwie ist das mit den Gapps im Moment ziemlich blöde. -
Echt blöd, hier sind noch mal meine Slim zero gapps vom 16.5.:
https://docs.google.com/file/d/0Bzr7_J…sp=docslist_api -
Hätt ich eh gemacht, nur keine Zeit bis jetzt.
Läd hoch, Link kommt gleich.
Hat jemand die heutigen SlimGapps probiert? -
Hier findet ihr die SlimGapps Mini vom 15.
rovo89 -
Im Gapps Sammel Thread diverse Links erneuert ... z.b. Google Apps Pack ARM64 Full & DU Mini 5.0.x & 5.1.1
Hätt ich eh gemacht
Laut xda berichten stürzen die neusten von heute auch ab. -
O.k., danke
. Da bleib ich bei den vom 15.
Falls jemand ältere, aber funktionierende Micro Gapps von Paranoid benötigt
pa_gapps-modular-micro-5.1-20150315-signed.zip
Bei mir laufen die immer...
https://docs.google.com/file/d/0BwhIwe…sp=docslist_api -
Slim gapps haben sich verändert, es gibt jetzt nur noch 2 Pakete:
Slim zero und
Slim mini. Danko hat somit weniger Arbeit mit und im Grunde hatte eh niemand das große Paket geflasht, weil man die apps über den playstore beziehen kann. Die neue Übersicht über die Pakete ist hier:
https://docs.google.com/file/d/0Bzr7_J…sp=docslist_apiEDIT:
Himmel, wieso kann man von Tapatalk aus keine Anhänge hier hochladen?EDIT 2:
So, jetzt mit eingebundenem Bild. -
