Update Cataclysm May 21. Android 5.1.1 r3. LMY48B.
 Zitat von atl4ntisAlles anzeigenHello, it's been a while since latest update, was eagerly waiting for 5.1.1.
Should be fine to dirty flash it over latest Cataclysm releases.
New bootloader and radio are not included, they're not mandatory though.
No delta update since this is a new android version.
Download is available on AFH and will be also on BB overnight/tomorrow.MD5: 4a26a23987feecc512fc9d87be61f3ed
SHA1: 23b3ef2df383aebfd165a389de33cfc9723eb051
May 21, 2015: Sources updated to android-5.1.1_r3 (LMY48B).
May 11, 2015: Added Ringer Mode custom intents for Normal/Vibrate/Silent.
May 02, 2015: Cataclysm Settings app shortcut: will allow to join Cataclysm live chat on AppChat.
Apr 25, 2015: Smart Timeout: disable while on secure lockscreen.
Apr 24, 2015: Prevent soft reboot caused by getCameraInfo() stock bug.
Apr 16, 2015: Global Force headsup notifications along with per-app settings.
Apr 16, 2015: Reintroduce Global Wake on notification along with per-app settings.
Apr 16, 2015: Don't hide Rotation tile if disabled from accessibility.
Apr 16, 2015: Fixed NFC Tile disappearing.The big deal here is the update to 5.1.1.
Other then that there are a couple of fixes, improvements and users requests.
I've decided to disable Smart Timeout on secure lockscreens to avoid conflicts with Face Unlock.
I've added some custom intents to manage the ringer mode from the outside. You'll find them on OP or on the bottom of this post.
I've also added a shortcut for Cataclysm settings.
It's just a shortcut of a few kb, it can be removed at installation time using the custom installation option.
Now with a beta out i'm planning to add some new stuff in the coming weeks.
About translations: i can't deal with diff requests, explanations, bad formatting etc etc cause unfortunately i don't have the time for.
Every release will just attach the strings (not just the new, the whole strings) on the release notes post (this one). It's up to you to translate them correctly, keep track of what's changed, etc etc.
If you're up to and you can deal with it on your own, just send them to the mail in Cataclysm settings --> about.
Malformed, wrongly translated, not working overall zips will be rejected without any further info.
I'm expecting them to working out of the box.
I'm sorry for it but it's either this way or no translations at all.
Download auf afh und basketbuild
