ZitatAlles anzeigenHello everyone,
i'm very happy about Jun 20 Stable release. It's the most perfect iteration bugless/feature wise of Cataclysm since i started developing it so i don't have really much to add/fix.
I've made just few changes so i'm gonna release them anyway instead of waiting indefinitely for new things to be added.
This update is very tiny (9M and a cache wipe is not needed and it won't wipe it by itself.
I'd tagged it as stable but changed my mind as i don't want to release a new big zip for such few changes.I've made a new Status Bar section within the options. If you don't find some settings you may want to check it.
I understand that the DeepSleep on Stats tile alone doesn't give any valuable information as it is.
My goal was mostly to show if the device sleeps or not, nothing else.
Resetting it after a charge wouldn't still give any important information as you still have to check the screen on time for any comparison.
Will evaluate if it's a keeper or not.
For more detailed informations you should rely on some third party app.
Downloads are available on OP.
Flash over Jun 20 stable only.MD5: 1b5dde06480b994cf5ce499fbbec41c1
SHA1: a5803d3c87615579508d93fa59afb236a2f49c39
 ZitatAlles anzeigenJul 02, 2015: Lockscreen: double tap to sleep.
Jul 01, 2015: Fixed possible Smart Radio white list settings FC on first launch.
Jul 01, 2015: Lockscreen: Allow cropping wallpaper vertically.
Jul 01, 2015: Color picker: less cryptic default button.
Jun 26, 2015: Longpress status bar settings wheel for Cataclysm settings.
Jun 25, 2015: Hide bluetooth status bar icon when disconnected.
Jun 25, 2015: Wake on notif: make pocket extraction detection optional.Attached new strings for translators. Thanks!
