ZitatAlles anzeigenTheme_addon_package updated (standard Version)
- Themed Google Play Store 5.3.5
- Themed Google App(NOW) 4.2.16
- Themed Calendar 5.1
- Themed Google Messenger 1.0.131
- Themed Google Clock
Quelle
Theme_addon_package updated (ARM64Version for Nexus 9 and other 64 bit devices)
- Themed Google App(NOW) 4.2.16 ARM 64
Quelle
CM Theme Sammlung + Div Theme Apps >> DIY / Rebuilder / Arcus
Themes Update ...
Themes & OP Update
			ZitatAlles anzeigen
Not many changes,[COLOR=#ff0000] I was busy with RRO support (still WIP, but so far so good)[/COLOR]
-Templates are now downloaded as separate files, allowing faster template updates, without the need to update the whole app.-Rewritten "saved themes" code for a better handling, and less crashing. Supporting up to 30 saved themes (can be more, but not necessary)
-Use system memory as default workspace, instead of SDcard. It should prevent crashes caused by temp files.
-Updated translations
-Fixed mobile networks text color bug.
OP Pflege >> Links erneuert, zu jedem Dev nun fast vollständig ... :moustach:
Flashable zip for DarkMTRL theme was updated:
Contains
NEW Themed Google Play Store 5.3.6 incl. new Search Bar
NEW Themed Google App(Google NOW) 4.3
Themed Calendar 5.1
Themed Google ClockBefore you ask - I tried to use the Clock app from 5.1 but that wouldnt work with 5.0
https://plus.google.com/+PatrickLoth/posts/bwDEkrVbdtz
:moustach:
Ubergizmo: Cyanogen OS 12 Will Come With An App Themer. http://www.ubergizmo.com/2015/03/cyanog…-an-app-themer/
Theme DIY
ZitatIf you were having problems with downloading the files, install themeDIY v0.71 from http://darkion.net/ThemeDIY.apk
Play store version is still using the old server. -
[size=14]Theme DIY [/SIZE]V0.78 (Link im OP) & OP Update
Zitat-No more first-run downloads (templates are included in the app, but updates still work)
-New image cropper
-Fixes
-Display errors on screen, instead of logcat.
-RRO support was dropped, due to RRO limitations. If you have background knowledge on Android/ Xposed development, and you think you can help, hangouts meNote: 0.75 is only available via direct link, play store version will be updated later.
Themes nun aktuell ... Es sind 193 kostenlose & 321 kostenpflichtige ...
App Update >>
ZitatAlles anzeigenV0.8 update!
-Removed "Material palette" panel, and replaced it with a more practical solution.
-Updated preview, show settings color instead of accentFrom 0.78
-New image cropper
-Fixes
-RRO support was dropped, due to RRO limitations. If you have background knowledge on Android/ Xposed development, and you think you can help, hangouts meAvailable on both direct link and google play store
Aktuelles Addon zu DarkMTRL by Thyrus
ZitatAlles anzeigen
DarkMTRL flashable addon updated for ARM and ARM64[COLOR=#ff0000]FLASH ONLY ON A 5.1 ROM![/COLOR]
Themed Calendar 5.1
Themed 5.1 DeskClock
Themed Google Messenger 5.1 (1.2.036)
Themed Google Play Store 5.4.10 (NEW)
Themed Google App(NOW) 4.3ARM (standard version for not 64-bit)
Integrating Layers/RRO Type 1 & 2 changes for the next buildARM64 (Nexus 9 etc)
ungültiger Link -
[size=14]5_1_Theme_Addon_DarkMTRL_Apri8[/SIZE]
ZitatFLASH ONLY ON A 5.1 ROM! ARM version - Themed Calendar 5.1 - Themed 5.1 DeskClock - Themed Google Messenger 5.1 (1.2.036) - Themed Google Play Store 5.4.10 - Themed Google App(NOW) 4.4.9 (NEW)
Flashable zips updated for DarkMTRL
- Themed Calendar 5.2 (NEW) (thanks +Andrew Traynham for the base)
- Themed Google Play Store 5.4.11 (NEW)
- Themed Google App(NOW) 4.4.10 (NEW)
ARM Version
Hier mal der Link zu XDAARM64 Version
Hier mal der Link zu XDA -
Themes & OP Update
DIY App Update 0.95 - Op up to Date
ZitatAlles anzeigenSave saved themes and uninstall previous themeDIY versions.
Almost everything was re-written. You won't notice any difference, but the new code should allow dynamic changes to themeDIY. In other words, devs can now use themeDIY to make their themes customizable. There are currently no themes that support themeDIY, but I'll post when they start showing up.
If you are a dev, make sure to read documentation on how to port your theme. [color=#000000]Ich weiß nicht wieso das jemand vorhaben sollte aber man weiß nie[/COLOR]. ;)[color=#000000]"[/COLOR]You will also notice new "material" icon, the original one was remade and materialized by +Adam Lapinski , so thanks very much to him. Make sure you check his work posted on his G+ page.
For those who get transparent header images, the problem is caused by your phone, not by themeDIY. You should reduce the size of your cropped image to something below 50KB as a starting point, then experiment further on.
Other bugs were fixed, and translations were merged (yes, I didn't pay for the translation service, hence why you can't contribute anymore...I'll do it asap)
Grab it from Play Store or direct link.
[size=14]DarkMTRL Flashable zip theme addons updated[/SIZE]
[size=14]ZitatChangelog: Added new calendar (playstore version)
For CM12s (for latest OTA, removed some apps now that CM fixed their theme issues)
ungültiger LinkFor 5.1 ROMs ARM Version
ungültiger LinkFor 5.1 ROMs ARM64 Version (Nexus 9 e.g.)
ungültiger LinkIhr wollt unbedingt eure Themes Einstellungen zeigen? Screenshots FTW
 Oder habt ihr fragen? Dann mal Auf! Auf! und mitdiskutieren...
>> CM12 Theme Smalltalk <<[/SIZE] -
