GBWhatsApp update auf 2.10
https://plus.google.com/+AbdelrahmanEh…sts/Qhw6NsXi7D1
Gesendet von meinem Nexus 6
Wie kann man bei Gbwhatsapp eine XML Datei einfügen und wo hin für Hintergrund und so wie es bei der plus Version ging!!????
Hey Guys , This is WhatsFapp v1.25 with CRACKED SECURITY and CODE CLEANED so is fast as well..
Base is same as before but next update will have updated base and will be released in some days.
So why waiting , start customizing it and do post your mods in communities of all selfish devs. ![]()
Credits to :-
+AndRoid 4Us for providing me the security crack.
And
+Infinity Cracker (Me) to clean its code and make it fast.
Aroma-shopping
Was heißt denn "cracked Security"? Ich meine nicht die Übersetzung sondern, was soll das bringen?
Grob mit Google übersetzt:
Whatsfapp had signature security due to which we were not able to mod it.
Whatsfapp hat(te) eine Signatur mit der es nicht möglich war/ist es zu modifizieren.
https://plus.google.com/+AbdelrahmanEh…sts/XR7U2NXFuGd
[ Update ] GBWhatsApp 2.20
What's new in v2.20
⏩ [ Fix ] crash in English Language
⏩ [ Add ]
⏩ [ Add ] option to change bubbles color in conversation screen
⏩ [ Add ] option to edit theme of pop-up notification
⏩ [ Add ] option to edit theme of widget
GBWhatsApp features :-
Based on 2.12.170
Ban proof
supports calls
hide your ( last seen )
privacy mods
themes mods
counter statistics for groups
media preview without loading
send video to size 30 MB instead of 16 MB
send 90 images at once instead of 10
change your status and add to 250 characters instead of 139 characters
abbability to press on links on chat screen without save sender number or group admin number
abbability to press in links on your friends states
The possibility of distinguishing between normal messages and Broadcast messages
hide the name and the date when copy more than one message
the possibility of copying friends status
change the app icon and notifications
and many other features .. discovere it by yourself ..
2.30 von GBWhatsApp ist verfügbar
https://plus.google.com/+AbdelrahmanEh…sts/GvbPZBKpzWo
Und wieder ein Update von GBWhatsApp auf die Version 2.40
https://plus.google.com/+AbdelrahmanEh…sts/VTza2sG6eMe
2.50von GBWhatsApp
https://plus.google.com/+AbdelrahmanEh…sts/FafHPYSuetw
2.60 GBWhatsApp
https://plus.google.com/communities/104098678844850408919
Kann jemand mal n paar Screenies von GB hier posten. Mich interessieren eigentlich nur die Icons / Grafiken in zB den Einstellungen. Manche arabischen waren so grässlich, die konnte ich einfach nicht drauf lassen.
Aktuell gibts ja nur noch GB, oder?
Danke, da werd ich wohl demnächst auch wechseln.
Mit aktuell meinte ich mit den Plus Features :). MD releaset ja neue Versionen via Twitter, wenn ich mich nicht verschaut habe.
MD müsste bei den Communitys dabei sein.
Ist von Brian Valente.
Bei GB kommen auch ständig neue Features dazu. ![]()
Jo ich hab die auch in meinen Abos, aber er postet nur noch Twitter Links ;). Deswegen auch der Wechsel zu GB, bis mal was neues kommt.
Hab neulich GB getestet, aber dank Layers Theme konnte ich die Einstellungen nicht lesen - schwarz auf schwarz oder weiß auf weiß ![]()
Dann hast du irgendwas falsch gemacht.
Absolut null Probleme damit.
Hast du mal das Overlay von WhatsApp weg gelassen??
Hier auch keine Probleme!! Funktioniert super
Kann man nicht viel falsch machen [emoji14].
WA war gar nicht dabei, das ist wohl ein System / Framework Overlay, selbes Problem bei Dropbox und YouTube zB auch :D. Es handelt sich meist um die Einstellungen der Apps. Ist ne andere Baustelle, hab kein Theme gefubden das wirklich befriedigt.
