Das hier wird eine Auflistung von momentan verfügbaren SlimRom- Builds welche von verschiedene Usern auf XDA zur Verfügung gestellt werden.
twistedSLim von letmedanz
twistedSLIM v2.2 - rebornChangelog:
- Latest Slim Source *
- RRO1 & RRO2 *
- Viper 4 Android
- SuperSU pre-built *
- Layers app pre-built *
- Present Layers app in twisted tweaks, more added features moved to tt *
- Expandable Volume Panel with option to unlink notification volume *
- Customizable Battery Indicator
- Customizable Network Indicator
- Customizable Quick Settings
- Added some cool QS like Compass *
- Adjustable NavBar
- Long press Back to kill app
- Long press Recents to switch apps
- Clear All Recents
- Disable search in Recents
- Modded BootMsg Dialog Box
- UI optimizations
- Performance Optimizations
- Twisted Tweaks
- New twisted Tweaks logo *
- Partition Info
- Added Battery save options
- Systemwide Font Change
- twisted BootAnimation
- Am sure i've missed something outConvenient Settings that are now Default:
Development Settings - On
Longpress back to kill - On
Block non market apps - Off
Lock & Unlock Sound - On
Low Battery Sounds - On
Wireless Charging - On
Unlink Volumes - On
DTMF tones - Off
Vibrate with Ring - On
Guest User - Off
Download
Garrykd
Extras:
RRO 2 (Layers) compatible
RRO2 Layers: show an Interface-Themes entry if Layers app is installed
Add options for battery icon and text in status bar (thanks @Yank555)
Let InCallUI handle proximity sensor for incoming calls
Doze trigger options
Add LCD density settingDownload
Es gibt 2 Versionen zum Download dark UI und light UI
Ezio84
- CM Eleven, AudioFX and Terminal source sync
- Slim source sync
- Theme support: RRO layers v2 support
- Show a "Theme" entry under Settings-Interface if the Layers app is installed
- Integrated SimpleExplorer
- CM Quick Settings tiles configuration: add a lot of new tiles and fix the code
- Enable and change 3g/LTE mode if available on the device
- Slim proximity speaker feature: all recent fixes and updates
- Slim Doze Ambient Display: all recent fixes and updates
- Some aosp fw base fixesDownload
Opti-SlimLP von aow1980
Changelog: Updated 07-02-14
Rom: Sabermod 4.8.5
Optimizations: 03, Graphite, GCConly, Strict, Floop-nest, Krait
Up to date with Slim Alpha releases
NavBar Dpi
NavBar Clear Recents
Qs tiles
RRO Layers 2
Proximity Speaker mode In Call
Network Indicators
Changeable Battery Style and Text
Eleven Music Player
Testing new libs for sound
Long Press back to Kill app
Long Press recent go to last app
Framework Base Optimizations
SaberMod build info in Device InfoKernel :
Built with SaberMod 4.9.3Added Governors : Nightmare and brought Slim back
Added I/O Schedulers : Sio , Fiops, Deadline
UC to 96mhz
OC to 2.5
GPU UC to 100 and OC to 533mhz
Backlight Dimmer option
DT2W options
USB fast Charge options
various other commits to hopefully make things better within the kernel
Google+
Download
efan3719
Current build :SlimKat 8.9 with Status Bar Network Speed, and Lock Screen Wallpaper.
Download
reS28raM
ROM Compiled with latest SaberMod 4.8.5 and Optimized with -O3 Optimizations
ChangeLog
- Synced code to 3 Feb 2015
- Reverted Material Dark Theme
- Added RRO - Layers Type 2 support
- Customizable Power Menu Button on Quick Tiles Panel for people using covers
- Added Customizable circular/vertical battery icon/text by Yank555 (Thanks Mate!!!)Features:
- Compiled with latest SaberMod 4.8.5 and Optimized with -O3 Optimizations
- Disabled a lot of debug stuff into frameworks
- Support to SykoPath RRO - Layers Type 1 and Type 2
- Themed Material Black - All that white is gone (almost)
- SELinux set to permissive by default for Viper4Android
- Longpress Back Button to kill the current App
- Longpress Recents Button to go to last used App
- Customizable Network Speed Indicators on the Status Bar
- Customizable circular/vertical battery icon/text by Yank555 (Thanks Mate!!!)
- SuperSU entry into Settings if SuperSU is installed (Thanks @Chainfire)
- Option into Settings to disable the searchbar in Recents
- Show full app names while they are being optimized at boot (not themed)
- Proximity Speaker (Thanks Dankoman!!!), enable it in Dialer preferences
- Doze (ambient display) with notification timeout (Dankoman)Download
Hopper8
Features:
-Long press back to kill - I also modified the timeout to 0.5 sec from 1.5
-Long press recents to switch to last app
-Configurable battery - percentage/text/icon
-Long click quick settings to enter applicable system setting
-Add sound toggle in quick settings
-Remove colour invert from quick settings
-Launch SuperSu from settings if it's installed
-Configurable navbar height
-Squish down zip size
-Material animations for volume panel
Optimisations (SPEED!
-03 optimisations
-Graphite optimisations
-Strict aliasing
-Krait (CPU architecture) optimisations
-Remove some bloat (BasicDreams, Calendar -supplied from gapps, PicoTTs, LiveWallpaperPicker, phasebeam, phototable, browser -from -gapps, phototable, legacy camera, music - I think that's it)
-Disable some debugging
-Fix memory leaks from lollipopDownload
Bei XDA gibt es noch für andere Geräte User Builds
XDA-Thread
