These are font packs that i made for the new CM 11/ CM 12 Theme Engine. Works on devices that have/support CM11/CM12 theme chooser/engine.
I am calling this as FontLand (Borderlands fan )
I hope you guys like,love and use them
More will be added soon
Note: I am no developer or coder or genius playboy billionaire philanthropist
Though these should work on any device which supports the CM11/CM12 theme engine, i am not responsible if your device goes boom-boom because of installing these fonts
Installation instructions :
1) Download and install
2) choose by going to Settings->Themes->Fonts
Simple!!
extra step) Though usually a reboot is not required but if sometimes the font doesn't get applied overall in that case try rebooting once and all should be good and if not report it to me and I will try to solve it
Requirements to install fonts on CM12 (Android Lollipop)
Though these fonts are made for CM11 they work perfectly on CM12 too, Please make sure you have the following to avoid issues while on CM12
** If you are using the fonts on CM12 please make sure your rom have the latest update for theme engine included. If not emojis, lockscreen clock colon etc will not show up
** For now rebooting the device is required on Lollipop for the font to get applied in the drop-down menu. Trying to look into it so that reboot is not required.
Dont like the fonts?? eh??
Then choose another from the list
or provide the .ttf or .otf of the fonts and time
and you shall hopefully have it made for you too
DOWNLOAD Font apk (CM12)
FontLand
FontLand Installer app by @djdarkknight96
Fontland-Beta app (Android 4.4 Only)
"Please make sure you are connected to internet otherwise the app force closes"
This is a beta and not a final release, so any bugs,features can be added or removed as we go along
The updates mentioned in the thread for fonts are updated within the app itself. The app is NOT updated with every font update rather the new fonts are added within the app for downloading. If at all there is an app update it will be mentioned specifically in the thread and a changelog will be added in the changelog section.
FontLand App Changelog :
- Initial Beta Release on 21-Sep-2014
- Added Thumb Scroll
Please Note : I do NOT support warez/cracks etc and try to inquire about the font before i post the apk here. That is time consuming and something i dont always have a luxury of and it is a bit difficult to distinguish whether the font is free or not as on some website its stated as free and on some its not. Anyways the point is if you find that the font i posted is warez/paid and should not be here. Report it to me and i will remove it
Credits :
djdarkknight96 for the FontLand installer app. He is the creator of it and all credit goes to him. Thanks a lot my friend
codekidX and a BIG thanks to him for the guide without which this thread would not have existed!!
All font designers/developers
Google and
me
Quelle
Vorschau im Original xda Thread!!!
