OP Update ... Und Kernel Wechsel Lösung??!!
Alright, here is a zip to flash after you flash your kernel if it is distributed as a full boot image (if it in doubt, open the zip up and see if it has a boot.img in it).
This zip unpacks the boot image on your phone and opens he ramdisk and replaces it with the sepolicy, sepolicy related files, init binary and init.rc (init.rc is the main init for core functions, this is the same across all android devices while init.device.rc is the one that gets modified for a per device basis)
This also has a modified fstab for those wanting f2fs support for cache and data.
Nutzt ihr z.B. Code_Blue braucht ihr diese zip Datei nicht flashen!
Weil Code_Blue anykernel nutzt/hat.
