BOKROM - Built with Optimizing Kit ROM
Below are my personal builds of the following ROMs
- AICP 10.0/11.0
- AOSP 5.1/6.0/7.0/7.1
- CM 12.1/CM 13.0
- Dirty Unicorns v9/v10
- Euphoria-OS
- OmniROM
- PA 5.1
- Purity
- Resurrection Remix
- SlimLP
- Temasek
- Terminus
These unofficial ROMs are fully odexed (compressed) and have been compiled with UBERTC 5.3.x. Most have variants where the latest GApps (minimal/full) are selectively added.
Disclaimer
Quote:
Your warranty will be VOID after installing a custom ROM.
Get notified yourself that I am not responsible for bricked devices, dead SD cards,
thermonuclear war, or you getting fired because the alarm app failed.
Please do some research if you have any concerns about features included
in this ROM before flashing it! YOU are choosing to make these modifications,
and if you point the finger at me for messing up your device, I will laugh at you.
ROMs Features:
- Latest/nightly build from respective upstream sources
- Minimal GApps just sufficient for installing apps from the Play Store or with most apps replaced with GApps alternatives
- MultiROM Support (Primary and Secondaries)
- Fully odexed for battery saving during frequent nightly upgrades (base ROM only takes less than 30 seconds to completely boot after wiping its cache)
- Compiled with UBERTC 5.3.x (for "Performance")
- LCD Density set to 445 (exact DPI of N5) instead of 480
- CM 12/CM 12.1- Option to hide su indicator (Settings->Status Bar->Hide su indicator)
- Option to disable scrollingCache (Settings->Performance->Scrolling cache). Currently set to Default/Force disable for smoother scrolling
- Option to display network traffic in the status bar (Settings->Status Bar->Network traffic)
- AOSP 5.1- Volume rocker to wake up device (Settings->Display)
- Miscellaneous battery issue fixed
- RRO Layers 3
- CMFileManager
- Video green line fixed
- Option to reboot (from CM)
- Privacy Guard (from CM & EOS)
- Option to enable root access (Settings->Developer options->Root access)
- Option to display battery percentage (from CM)
- Option to display network traffic in the status bar (Settings->Display->Status Bar->Network traffic)
- PA- Volume rocker to wake up device (Settings->Display)
- Euphoria-OS- CMFileManager
- Battery Bar (from RR)
- Clock font style and option to show second (Settings->Status Bar)
- Recent panel show Memory Bar (Settings->Multitasking)
- Show WiFi network activity
- Purity- Zen mode buttons in Power Menu
Kernel Features: Replace all AOSP-based and CM-based kernels, otherwise ROMs stock kernels will be used (compiled with UBER-Linaro 5.2.1)
- Gamma Control/Display Color Calibration
- FauxSound/Franco Sound
- Kexec Patch for MultiROM
- Fast Charging with USB
- Voltage Control
- Others will be added in the future as I see fit
Downloads: ROMs are arranged by latest updates first
To receive update notifications please follow this pushbullet channel.----------------------------------------------------------Special Download: Android 6.0.1 Marshmallow Recovery Backup MOB30H-backup-20160503-bokrom-hammerhead.zip (752.3MB) MOB30D-backup-20160412-bokrom-hammerhead.zip (752.5MB) MMB29X-backup-20160407-bokrom-hammerhead.zip (752.5MB)Instructions (Tested only with TWRP MultiROM. Working as primary & secondary ROMs)
- Download above backup zip file and extract to your device recovery backup folder
- Boot in recovery mode
- Backup System, Data and Boot partitions (Original System)
- As primary rom: Restore from the extracted backup folder
- As seconadry rom: Advanced->MultiROM->Add ROM->Next->Backup->Select from the extracted backup folder
- Reboot and enjoy
Caveat: Stock kernel is not KEXEC enabled.
Quote:
- xxx-yyyymmdd-bokrom-hammerhead.zip - plain xxx ROM
- xxx-yyyymmdd-bokrom-gapps-hammerhead.zip - xxx ROM with minimal GApps added
- xxx-yyyymmdd-bokrom-gapps-full-hammerhead.zip - xxx ROM with more GApps added
AOSP 7 (Nougat) ROMs
- Work with both Multirom primary and secondary (just ignore error messages)
- Tested with OpenGApps
- Built-in Root (Settings->Security->Apps and ADB)
- Superuser Manager (Settings->Security->Manage root accesses)
- Volume rocker wake up (Settings->Display)
- Volume keys keyboard cursor (Settings->Languages & Input)
- Advanced Reboot
- Substratum (currently 7.0 only)
AOSP 7.1 ROMs: aosp-7.1-20161108 NDE63X *** UPDATED ***
- bokrom-hammerhead (386.6MB)
- bokrom-gapps-hammerhead (472.4MB)
AOSP 7.0 ROMs: aosp-7.0-20161005 NRD90Z
- Updated: NRD90Z
- Fixed: Missing Stk App
- Added: Volume keys keyboard cursor (Settings->Languages & Input)
- ROM is now multirom secondary-friendly when installed in primary (no more restorecon)
- bokrom-hammerhead (354.2MB)
- bokrom-gapps-hammerhead (484.9MB)
AOSP 6 (Marshmallow) ROMsAOSP 6.0.1 ROMs: aosp-6.0.1-20160608 MOB30M
- bokrom-hammerhead (352.8MB)
- bokrom-gapps-hammerhead (473.3MB)
Resurrection Remix M ROMs:
ResurrectionRemix-M-v5.6.9-20160522 Marshmallow
- bokrom-hammerhead (352.5MB)
- bokrom-gapps-hammerhead (477MB)
OmniRom 6.0.1 ROMs: omni-6.0.1-20160504 Marshmallow
- bokrom-hammerhead (320.3MB)
- bokrom-gapps-hammerhead (443.2MB)
AICP 11.0 ROMs: aicp-11.0-20160504 Marshmallow
- AOSP Based- bokrom-hammerhead (348.5MB)
- bokrom-gapps-hammerhead (471.3MB)
- CAF Based- bokrom-hammerheadcaf (348.7MB)
- bokrom-gapps-hammerheadcaf (471.4MB)
CM 13.0 ROMs: cm-13.0-20160504 Marshmallow
- AOSP Based- bokrom-hammerhead (350.6MB)
- CAF Based- bokrom-hammerheadcaf (352.1MB)
- bokrom-gapps-hammerheadcaf (474.8MB)
Temasek 13.0 ROMs: temasek-7.7-13.0-20160504 Marshmallow
- bokrom-hammerhead (359.4MB)
- bokrom-gapps-hammerhead (479MB)
Dirty Unicorns ROMs: DU-v10.1-20160503 Marshmallow
- bokrom-hammerhead (331.7MB)
- bokrom-gapps-hammerhead (478.2MB)
AOSP 6.0.1 ROMs: aosp-6.0.1-20160405 MHC19Q
- bokrom-hammerhead (304.7MB)
- bokrom-gapps-hammerhead (423.1MB)
AOSP 6.0.1 ROMs: aosp-6.0.1-20160308 MMB29V
- bokrom-hammerhead (306.3MB)
- bokrom-gapps-hammerhead (424.5MB)
Slim 6.0 ROMs: Slim-6.0-20151127 Marshmallow
- bokrom-hammerhead (274.7MB)
- bokrom-gapps-hammerhead (415.3MB)
CM 12.1 ROMs: cm-12.1-20151022
- AOSP Based- bokrom-hammerhead (312.5MB)
- bokrom-gapps-hammerhead (407.5MB)
- bokrom-gapps-full-hammerhead (569.7MB)
- CAF Based- bokrom-hammerheadcaf (314.1MB)
- bokrom-gapps-hammerheadcaf (409.1MB)
- bokrom-gapps-full-hammerheadcaf (571.2MB)
Resurrection Remix ROMs:
Resurrection-Remix-LP-v5.5.8-20151022
- bokrom-hammerhead (326.8MB)
- bokrom-gapps-hammerhead (424.3MB)
- bokrom-gapps-full-hammerhead (586.8MB)
Temasek ROMs: temasek-18.1-12.1-20151022
- bokrom-hammerhead (330.6MB)
- bokrom-gapps-hammerhead (426.9MB)
- bokrom-gapps-full-hammerhead (589MB)
SlimLP 5.1.1 ROMs: Slim-5.1.1-20151015
- bokrom-hammerhead (246.8MB)
- bokrom-gapps-hammerhead (343.7MB)
- bokrom-gapps-full-hammerhead (517.4MB)
Euphoria-OS ROMs: Euphoria-OS-1.1-20151013
- bokrom-hammerhead.zip (264.1MB)
- bokrom-gapps-hammerhead.zip (360.8MB)
- bokrom-gapps-full-hammerhead.zip (523MB)
Dirty Unicorns ROMs: DU-v9.7-20151012
- bokrom-hammerhead (260.2MB)
- bokrom-gapps-hammerhead (356.9MB)
- bokrom-gapps-full-hammerhead (534.9MB)
Purity ROMs: purity-20151002
- bokrom-hammerhead (213.7MB)
- bokrom-gapps-hammerhead (310.4MB)
- bokrom-gapps-full-hammerhead (541.7MB)
AOSP 5.1.1 ROMs: aosp-5.1.1-20151001
- bokrom-hammerhead (238.2MB)
- bokrom-gapps-hammerhead (335MB)
- bokrom-gapps-full-hammerhead (545.7MB)
AICP 10.0 ROMs: aicp-10.0-20150924
- AOSP Based- bokrom-hammerhead (311.4MB)
- bokrom-gapps-hammerhead (408.1MB)
- bokrom-gapps-full-hammerhead (568MB)
- CAF Based- bokrom-hammerheadcaf (312.9MB)
- bokrom-gapps-hammerheadcaf (409.7MB)
- bokrom-gapps-full-hammerheadcaf (569.5MB)
OmniROM ROMs: omni-5.1.1-20150923
- bokrom-hammerhead (253.7MB)
- bokrom-gapps-hammerhead (350.4MB)
- bokrom-gapps-full-hammerhead (543.1MB)
PA 5.1 ROMs: pa-5.1-20150922
- bokrom-hammerhead (236.2MB)
- bokrom-gapps-hammerhead (333MB)
- bokrom-gapps-full-hammerhead (541.1MB)
Terminus ROMs: terminus-20150829
Latest RRO Layers commit merged
- bokrom-hammerhead (216.9MB)
- bokrom-gapps-hammerhead (310.9MB)
- bokrom-gapps-full-hammerhead (530.6MB)
Team UB ROMs: tub-12.1-20150616
- bokrom-hammerhead (319MB)
- bokrom-gapps-hammerhead (413.7MB)
- bokrom-gapps-full-hammerhead (565.8MB)
CM 12.0 ROMs:
- cm-12-20150504-bokrom-hammerhead.zip (305.7MB)
- cm-12-20150504-bokrom-gapps-hammerhead.zip (390.2MB)
- cm-12-20150504-bokrom-gapps-full-hammerhead.zip (495MB)
Kernel Source
Instructions: (Tested only with MultiROM TWRP)
- For initial installation, backup and wipe data/cache/dalvik-cache
- For nightly upgrades, simply wipe cache/dalvik-cache
Credits:
- AICP for the AICP 9.0 source
- AOSP for the AOSP 5.1 source
- AOSPA for the AOSPA 5 source
- Cyanogenmod for the CM12/CM12.1 source
- Euphoria-OS for the Euphoria-OS 1.1 source
- OmniROM for the OmniROM source
- @varund7726 and Resurrection Remix for the RR sources
- SlimRoms for the SlimLP source
- lichti1901 for the Terminus source
- Dirty Unicorns for the DU source
- Purity for the Purity source
- Temasek for the Temasek source
- https://github.com/TheMuppets/propri...2.0/hammerhead
- https://github.com/MrTumbles/
- Cl3Kener for the UBERTC source
- Google for the GApps
- MultiROM @Tassadar
- All kernel developers whom I cherry-picked my kernel mods
Quelle:http://www.xda-developers.com
[B][B][B][COLOR=#ff0000]Wie immer übernehmen wir (Android-Port.de, der Entwickler, Ich oder andere User) keine Garantie in einem Falle des Bricks/defekts eures Gerätes.[/COLOR]
[B][COLOR=#ff0000]ALLES geschieht auf eigene Gefahr, daher schaltet euren Kopf an und handelt mit Bedacht.[/COLOR][/B][/B][/B][/B]
