If You Want Now on Tap and Oke to work, use the modified ones. If you dont use those just use the zero.
[ROM] [L] [5.1.1] Velocity Hammerhead
mikaole  -
13. Juni 2015 um 18:19  -
I tried MultiROM but unfortunately does not go goes the fash (error binary update)
Inviato dal mio Nexus 5 utilizzando Tapatalk
Are you making sure / system is unmounted? Also, Im pretty sure multi-Rom doesnt work on M.
Are you making sure /system is unmounted?
Yes, i've checked that before flashI tried MultiROM but unfortunately does not go goes the fash (error binary update)
Me too -
Have you successfully flashed an M build with multi-rom yet? Because again, Im pretty sure it doesnt work on M.
No...
Will try with another rom to see if it works..thanks man
Yea, MR just doesnt work on M yet
You are right man..I can confirm that.. -
Oh, Das klingt sehr gut und schön! [color=#C9C9C9]hulle6[/color]
[color=#C9C9C9]lg nexus 5x tasche[/color]
V 1.1 online
Hier geht es weiter
https://www.android-port.de/themen/rom-m-6…69/#post-129618Dieser kann dann geschlossen werden
