@ctfrommn
the time service provider bug seems to be still presentGesendet von meinem Nexus 5 mit Tapatalk
Hier kein Problem. Welche Gapps nutzt du?
@ctfrommn
[QUOTE = "consumer-house, post: 123395, Members: 1884"] [USER = 2957] ctfrommn [/ USER]
The Time Service Provider bug Seems to Be Still present [ATTACH = full] 25427 [/ ATTACH]
Sent from my Nexus 5 with tapas talk [/ QUOTE]
I dont recall ever saying it was "fixed". I never got around to adding the fix back after I started over. It will be added in the next build.
And why cant I get quoting other posts to work right?
The Time Service Provider bug Seems to Be Still present [ATTACH = full] 25427 [/ ATTACH]Sent from my Nexus 5 with tapas talk [/ QUOTE]
You just have to hit zitieren
Slim Minimal Gapps
Its not a Gapps issue ... stock AOSP has no Time Service apk in it.
[QUOTE = "mikaole, post: 123400, Members: 2206"] You just have to hit quote [/ QUOTE]
Hmmm, just simple enough to work
YESS! Velocity rom That's a long time ago. Thanks Chad (and Mikaole)
Update
Neues build online
Danke. Das Systemdatum passt nun[emoji106]
This is one quiet forum
great to see chad back & Rom is super smooth
Rom is working great! Thanks Chad!
Update
Neues build online
.. .yes, but it´s caused by a great performing rom so quiet here: No bugs, no posts
It´s different to xda, where anyone is bashing, posting on rom-issues where are user-issues, feature-requests where the dev a millon times said "no requests"...and so on.
So, you see...this is an adult forum, no school-boys. We are respectful, still make jokes and everything is fine.
Your rom is the fastes out there. That´s good.
There are only a few features build in. That´s your way...and that´s okay.
For me the could be two or three more. But I don´t ask or suggest, because of your statement that you only build in the things you use.
If I want more things, I will flash other roms.
So: keep on going your way. And if you want to get input from us for useful features...we are here :-p
I´ve still two or three in my brain
greets!
Neueste Version offline genommen.
Gibt Probleme mit dialer und messanger
Nicht flashen
Zu spät, schon geflasht....
Hast du auch fc bei dialer, wenn du telefonieren willst?
Ja, dialer fc, messenger noch nicht probiert....
Sorry about that ... its fixed and im sure mikaole with upload it soon. Going forward these will be tested better before being linked here.
No problem at all, flashed the build before
